1 | /*****************************************************************************
2 |
3 | *
4 |
5 | * Function name : Read_DF_status
6 |
7 | *
8 |
9 | * Returns : One status byte. Consult Dataflash datasheet for further
10 |
11 | * decoding info
12 |
13 | *
14 |
15 | * Parameters : None
16 |
17 | *
18 |
19 | * Purpose : Status info concerning the Dataflash is busy or not.
20 |
21 | * Status info concerning compare between buffer and flash page
22 |
23 | * Status info concerning size of actual device
24 |
25 | *
26 |
27 | * mt: the 'if' marked with 'mt 200401' is a possible optimisation
28 |
29 | * if only one type of Dataflash is used (like on the Butterfly).
30 |
31 | * If the uC controls different types of dataflash keep the PageBits
32 |
33 | * and PageSize decoding in this function to avoid problems.
34 |
35 | ******************************************************************************/
36 |
37 | unsigned char Read_DF_status (void)
38 |
39 | {
40 |
41 | unsigned char result,index_copy;
42 |
43 | DF_CS_inactive; //make sure to toggle CS signal in order
44 |
45 | DF_CS_active; //to reset dataflash command decoder
46 |
47 |
48 |
49 | result = DF_SPI_RW(StatusReg); //send status register read op-code
50 |
51 |
52 |
53 | result = DF_SPI_RW(0x00); //dummy write to get result ### Hier hängt er###
54 |
55 |
56 |
57 | index_copy = ((result & 0x38) >> 3); //get the size info from status register
58 |
59 | // mtA
60 |
61 | /// if (!PageBits) { // mt 200401
62 |
63 | // PageBits = DF_pagebits[index_copy]; //get number of internal page address bits from look-up table
64 |
65 | // PageSize = DF_pagesize[index_copy]; //get the size of the page (in bytes)
66 |
67 | PageBits = pgm_read_byte(&DF_pagebits[index_copy]); //get number of internal page address bits from look-up table
68 |
69 | PageSize = pgm_read_word(&DF_pagesize[index_copy]); //get the size of the page (in bytes)
70 |
71 | /// }
72 |
73 | // mtE
74 |
75 | return result; //return the read status register value
76 |
77 | }
78 |
79 | /*****************************************************************************
80 |
81 | *
82 |
83 | * Function name : Page_Buffer_Compare
84 |
85 | *
86 |
87 | * Returns : 0 match, 1 if mismatch
88 |
89 | *
90 |
91 | * Parameters : BufferAdr -> Decides usage of either buffer 1 or 2
92 |
93 | * PageAdr -> Address of flash page to be compared with buffer
94 |
95 | *
96 |
97 | * Purpose : comparte Buffer with Flash-Page
98 |
99 | *
100 |
101 | * added by Martin Thomas, Kaiserslautern, Germany. This routine was not
102 |
103 | * included by ATMEL
104 |
105 | *
106 |
107 | ******************************************************************************/
108 |
109 | unsigned char Page_Buffer_Compare(unsigned char BufferNo, unsigned int PageAdr)
110 |
111 | {
112 | unsigned char stat;
113 |
114 |
115 |
116 | //DF_CS_inactive; //make sure to toggle CS signal in order
117 |
118 | //DF_CS_active; //to reset dataflash command decoder
119 |
120 |
121 |
122 | if (1 == BufferNo)
123 |
124 | {
125 |
126 | DF_SPI_RW(FlashToBuf1Compare);
127 |
128 | DF_SPI_RW((unsigned char)(PageAdr >> (16 - PageBits))); //upper part of page address
129 |
130 | DF_SPI_RW((unsigned char)(PageAdr << (PageBits - 8))); //lower part of page address and MSB of int.page adr.
131 |
132 | DF_SPI_RW(0x00); // "dont cares"
133 |
134 | }
135 |
136 | #ifdef USE_BUFFER2
137 |
138 | else if (2 == BufferNo)
139 |
140 | {
141 |
142 | DF_SPI_RW(FlashToBuf2Compare);
143 |
144 | DF_SPI_RW((unsigned char)(PageAdr >> (16 - PageBits))); //upper part of page address
145 |
146 | DF_SPI_RW((unsigned char)(PageAdr << (PageBits - 8))); //lower part of page address
147 |
148 | DF_SPI_RW(0x00); //don't cares
149 |
150 | }
151 |
152 | #endif
153 |
154 |
155 |
156 | DF_CS_inactive;
157 |
158 | DF_CS_active;
159 |
160 |
161 |
162 | do {
163 |
164 | stat=Read_DF_status();
165 | } while(!(stat & 0x80)); //monitor the status register, wait until busy-flag is high
166 |
167 |
168 |
169 | return (stat & 0x40);
170 |
171 | }
