Hallo, von http://www.national.com/an/AN/ANs1889.pdf To test a closed-loop system with an injection transformer, you must break the loop at some point. At that point, the reflected impedance at the network analyzer's A port (Figure 3) should be low, and the impedance reflected on the R port should be high. Those conditions are important, because if the closed-loop gain beyond crossover is much less than one, most of the signal injected by the transformer will show up on the R port. For example, if the impedance reflected on the R port is only nine times higher than that reflected on the A port, then only one-tenth of the signal will show up on the A port. Nine-tenths will appear on the R port, regardless of the true loop response. That situation requires an impedance buffer (i.e., a FET probe) to raise the network analyzer's input impedance above its inherent 50Ω level. Was meinen die da mit der unterschiedlichen Impedanz an Port A und B. Warum funktioniert es nur dann?
Sorry falscher Link oben hier der richtige: http://www.maxim-ic.com/app-notes/index.mvp/id/3245 der obige ist aber auch Interessant :-)
