1 | void
2 | spi2_config (void) {
3 |
4 | GPIO_InitTypeDef GPIO_InitStructure;
5 |
6 | /* Configure SPI2 pins: SCK, MISO and MOSI ---------------------------------*/
7 | GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
8 | GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
9 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
10 | GPIO_Init(GPIOB, &GPIO_InitStructure);
11 |
12 | /* Configure Slave Select Pin --------------------------------------------*/
13 | GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
14 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
15 | GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
16 | GPIO_Init(GPIOB, &GPIO_InitStructure);
17 |
18 | // set slave select to high
19 | GPIO_WriteBit(GPIOB, GPIO_Pin_12, 1);
20 | }
21 |
22 | void
23 | spi2_init (void) {
24 |
25 | SPI_I2S_DeInit(SPI2);
26 | spi2_config ();
27 |
28 | SPI_InitTypeDef SPI_InitStructure;
29 |
30 | /* SPI2 configuration ------------------------------------------------------*/
31 | SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
32 | SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
33 | SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
34 | SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
35 | SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;
36 | SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
37 | SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;
38 | SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
39 | SPI_Init(SPI2, &SPI_InitStructure);
40 |
41 | SPI_CalculateCRC(SPI2, DISABLE);
42 | SPI_Cmd(SPI2, ENABLE);
43 | }
44 |
45 |
46 | ///////////////////////////////////////////////////////////////////////////////
47 | // enable FRAM
48 | ///////////////////////////////////////////////////////////////////////////////
49 | void
50 | FRAM_enable (void) {
51 | //SPI_SSOutputCmd(SPI2, ENABLE);
52 | GPIO_WriteBit(GPIOB, GPIO_Pin_12, 0);
53 | }
54 |
55 | ///////////////////////////////////////////////////////////////////////////////
56 | // disable FRAM
57 | ///////////////////////////////////////////////////////////////////////////////
58 | void
59 | FRAM_disable (void) {
60 | //SPI_SSOutputCmd(SPI2, DISABLE);
61 | GPIO_WriteBit(GPIOB, GPIO_Pin_12, 1);
62 | }
63 |
64 | ///////////////////////////////////////////////////////////////////////////////
65 | // initialize FRAM
66 | ///////////////////////////////////////////////////////////////////////////////
67 | void
68 | FRAM_init (void) {
69 |
70 | // set write enable latch
71 | while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_TXE)==RESET);
72 |
73 | FRAM_enable();
74 | SPI_I2S_SendData(SPI2, 0x06);
75 | FRAM_disable();
76 | }
77 |
78 | ///////////////////////////////////////////////////////////////////////////////
79 | // Write Byte to Fram
80 | ///////////////////////////////////////////////////////////////////////////////
81 | void
82 | FRAM_write_byte (unsigned char b) {
83 |
84 | while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_TXE)==RESET);
85 | SPI_I2S_SendData(SPI2, b);
86 | }
87 |
88 | ///////////////////////////////////////////////////////////////////////////////
89 | // Write Byte to Fram
90 | ///////////////////////////////////////////////////////////////////////////////
91 | unsigned char
92 | FRAM_read_byte (void) {
93 |
94 | while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_RXNE)==RESET);
95 | return SPI_I2S_ReceiveData(SPI2);
96 | }
97 |
98 |
99 |
100 | void
101 | FRAM_Test () {
102 |
103 | unsigned char mod_byte= 2;
104 | unsigned int limit = 0;
105 | unsigned char byte = 0;
106 |
107 | // write data to fram
108 | FRAM_enable();
109 |
110 | // write address -> start address is 0
111 | FRAM_write_byte (0x02); // write memory data command
112 | FRAM_write_byte (0x00); // addr
113 | FRAM_write_byte (0x00); // addr
114 | FRAM_write_byte (0x00); // addr
115 |
116 | for (limit = 0; limit < 200; limit++) {
117 | if (mod_byte % 2) {
118 | FRAM_write_byte (0xAA);
119 | }
120 | else {
121 | FRAM_write_byte (0x55);
122 | }
123 | mod_byte++;
124 | }
125 |
126 | FRAM_disable();
127 |
128 | // read data from fram
129 | FRAM_enable();
130 | printf("\r\nread data from FRAM\r\n");
131 | FRAM_write_byte (0x03); // read memory data command
132 | FRAM_write_byte (0x00); // addr
133 | FRAM_write_byte (0x00); // addr
134 | FRAM_write_byte (0x00); // addr
135 |
136 | for (limit = 0; limit < 200; limit++) {
137 | byte = FRAM_read_byte();
138 | printf("%#X ", byte); // nach 0x55 0x55 0x55 läuft der uC nicht weiter
139 | }
140 | FRAM_disable();
141 | /**/
142 | }
