1 | .include "m168def.inc"
2 | .cseg
3 | .org 0
4 | ;-------------------------------------------------------------------------------
5 | ; Reset and Interrupt vector ;VNr. Beschreibung
6 | ;-------------------------------------------------------------------------------
7 | ;0x0000
8 | jmp main ; Reset Handler
9 | ;0x0002
10 | jmp ORG ; IRQ0 Handler
11 | ;0x0004
12 | jmp ORG ; IRQ1 Handler
13 | ;0x0006
14 | jmp ORG ; PCINT0 Handler
15 | ;0x0008
16 | jmp ORG ; PCINT1 Handler
17 | ;0x000A
18 | jmp ORG ; PCINT2 Handler
19 | ;0x000C
20 | jmp ORG ; Watchdog Timer Handler
21 | ;0x000E
22 | jmp ORG ; Timer2 Compare A Handler
23 | ;0x0010
24 | jmp ORG ; Timer2 Compare B Handler
25 | ;0x0012
26 | jmp ORG ; Timer2 Overflow Handler
27 | ;0x0014
28 | jmp ORG ; Timer1 Capture Handler
29 | ;0x0016
30 | jmp ORG ; Timer1 Compare A Handler
31 | ;0x0018
32 | jmp ORG ; Timer1 Compare B Handler
33 | ;0x001A
34 | jmp ORG ; Timer1 Overflow Handler
35 | ;0x001C
36 | rjmp Timer ; Timer0 Compare A Handler
37 | ;0x001E
38 | jmp ORG ; Timer0 Compare B Handler
39 | ;0x0020
40 | jmp ORG ; Timer0 Overflow Handler
41 | ;0x0022
42 | jmp ORG ; SPI Transfer Complete Handler
43 | ;0x0024
44 | jmp ORG ; USART, RX Complete Handler
45 | ;0x0026
46 | jmp ORG ; USART, UDR Empty Handler
47 | ;0x0028
48 | jmp ORG ; USART, TX Complete Handler
49 | ;0x002A
50 | jmp ORG ; ADC Conversion Complete Handler
51 | ;0x002C
52 | jmp ORG ; EEPROM Ready Handler
53 | ;0x002E
54 | jmp ORG ; Analog Comparator Handler
55 | ;0x0030
56 | jmp ORG ; 2-wire Serial Interface Handler
57 | ;0x0032
58 | jmp ORG ; Store Program Memory Ready Handler
59 |
60 | ORG: reti
61 |
62 |
63 |
64 |
65 |
66 | .equ XTAL = 3686400;H
67 |
68 | ;
69 | ; Namenszuordnung der Register im RAM
70 | ;
71 | .def LCD_1 = r16 ; LCD_Register
72 | .def LCD_2 = r17 ; LCD_Register
73 | .def LCD_3 = r18 ; LCD_Register
74 | .def temp1 = r19
75 | .def temp2 = r20
76 | .def temp3 = r21
77 | .def temp4 = r22
78 | .def temp5 = r23
79 | .def temp6 = r24
80 | .def temp7 = r25
81 | .def temp8 = r26
82 | .def temp9 = r27
83 | .def temp10 = r28
84 |
85 | ;
86 | ; Resethanling, booten
87 | ;
88 | main:
89 | ldi temp1, LOW(RAMEND) ; Stackpointer initialisieren
90 | out SPL, temp1
91 | ldi temp1, HIGH(RAMEND)
92 | out SPH, temp1 ;
93 |
94 | ldi temp1,0b00111111
95 | out DDRB,temp1
96 |
97 | ldi temp1,0b00000101 ; CS00 setzen: Teiler 1
98 | sts TCCR0B, temp1
99 |
100 | ldi temp1,(1<<TOIE0) ; TOIE0: Interrupt bei Timer Overflow
101 | sts TIMSK0, temp1
102 |
103 | sei
104 |
105 | mainloop:
106 | rjmp mainloop
107 |
108 | Timer: reti
