1 | // Library includes
2 | //#include <avr/io.h>
3 | #include <avr/sleep.h>
4 | #include <compat/deprecated.h>
5 | #include <avr/pgmspace.h>
6 | #include <util/delay.h>
7 | #include <inttypes.h>
8 | #include <avr/interrupt.h>
9 | #include <stdio.h>
10 | #include <stdlib.h>
11 | #include <string.h>
12 | #include "Font.h"
13 |
14 |
15 | #define SELECT_MCP4151 PORTB &= ~(0<<PB4)
16 | #define DESELECT_MCP4151 PORTB |= (1<<PB4)
17 | #define DDR_SPI DDRB
18 | #define DD_SCK PB7
19 | #define DD_MOSI PB5
20 | #define DD_MISO PB6
21 | #define DD_SS PB4
22 |
23 |
24 |
25 |
26 |
27 |
28 | unsigned short read_adc(void);
29 | void SPI_MasterInit(void);
30 | uint8_t SPI_MasterTransmit(char cData);
31 |
32 |
33 | // Here is the main
34 | int main (void)
35 | {
36 | unsigned char CharCol_1, CharCol_2, CharCol_3, CharCol_4, CharCol_5;
37 | unsigned char pz, y;
38 | unsigned int pos;
39 | unsigned short test=0x0000;
40 | unsigned char sign; // setup all pins to outputs
41 | SPI_MasterInit();
42 |
43 | DDRD = 0xff;
44 | DDRA = 0xfe;
45 |
46 |
47 |
48 | PORTD |= (0<<PD2)|(0<<PD3)|(0<<PD4)|(0<<PD5)|(0<<PD6);
49 |
50 |
51 | int i=0;
52 | while(i<2)
53 | {i++;
54 | test=read_adc();
55 | }
56 |
57 |
58 | if (test==0x430F)
59 | sign=0x32;
60 | else sign=0x31;
61 |
62 |
63 |
64 |
65 |
66 |
67 | if ((sign<0x20) || (sign>0x7F)) { sign = 0x20; }
68 | pos = 5*(sign-0x20);
69 |
70 | CharCol_5 = pgm_read_byte(&code5x7[pos++]);
71 | CharCol_4 = pgm_read_byte(&code5x7[pos++]);
72 | CharCol_3 = pgm_read_byte(&code5x7[pos++]);
73 | CharCol_2 = pgm_read_byte(&code5x7[pos++]);
74 | CharCol_1 = pgm_read_byte(&code5x7[pos++]);
75 |
76 | while (1)
77 | {
78 |
79 | PORTD |= (0<<PD2)|(0<<PD3)|(0<<PD4)|(0<<PD5)|(0<<PD6);
80 |
81 | if (CharCol_1>0x00)
82 | {
83 | PORTD=(1<<PD2);
84 | PORTA=(!((CharCol_1&0b01000000)>>6)<<PA1)|(!((CharCol_1&0b00100000)>>5)<<PA2)|(!((CharCol_1&0b00010000)>>4)<<PA3)|(!((CharCol_1&0b00001000)>>3)<<PA4)|(!((CharCol_1&0b00000100)>>2)<<PA5)|(!((CharCol_1&0b00000010)>>1)<<PA6)|(!((CharCol_1&0b00000001))<<PA7);
85 |
86 | _delay_us(4000);
87 |
88 | }
89 |
90 | PORTD |= (0<<PD2)|(0<<PD3)|(0<<PD4)|(0<<PD5)|(0<<PD6);
91 |
92 | if (CharCol_2>0x00)
93 | {
94 | PORTD=(1<<PD3);
95 | PORTA=(!((CharCol_2&0b01000000)>>6)<<PA1)|(!((CharCol_2&0b00100000)>>5)<<PA2)|(!((CharCol_2&0b00010000)>>4)<<PA3)|(!((CharCol_2&0b00001000)>>3)<<PA4)|(!((CharCol_2&0b00000100)>>2)<<PA5)|(!((CharCol_2&0b00000010)>>1)<<PA6)|(!((CharCol_2&0b00000001))<<PA7);
96 | _delay_us(4000);
97 |
98 |
99 | }
100 |
101 | PORTD |= (0<<PD2)|(0<<PD3)|(0<<PD4)|(0<<PD5)|(0<<PD6);
102 |
103 |
104 |
105 | if (CharCol_3>0x00)
106 | {
107 | PORTD=(1<<PD4);
108 | PORTA=(!((CharCol_3&0b01000000)>>6)<<PA1)|(!((CharCol_3&0b00100000)>>5)<<PA2)|(!((CharCol_3&0b00010000)>>4)<<PA3)|(!((CharCol_3&0b00001000)>>3)<<PA4)|(!((CharCol_3&0b00000100)>>2)<<PA5)|(!((CharCol_3&0b00000010)>>1)<<PA6)|(!((CharCol_3&0b00000001))<<PA7);
109 | _delay_us(4000);
110 |
111 | }
112 |
113 | PORTD |= (0<<PD2)|(0<<PD3)|(0<<PD4)|(0<<PD5)|(0<<PD6);
114 |
115 | if (CharCol_4>0x00)
116 | {
117 | PORTD=(1<<PD5);
118 |
119 | PORTA=(!((CharCol_4&0b01000000)>>6)<<PA1)|(!((CharCol_4&0b00100000)>>5)<<PA2)|(!((CharCol_4&0b00010000)>>4)<<PA3)|(!((CharCol_4&0b00001000)>>3)<<PA4)|(!((CharCol_4&0b00000100)>>2)<<PA5)|(!((CharCol_4&0b00000010)>>1)<<PA6)|(!((CharCol_4&0b00000001))<<PA7);
120 |
121 |
122 | _delay_us(4000);
123 |
124 | }
125 |
126 | PORTD |= (0<<PD2)|(0<<PD3)|(0<<PD4)|(0<<PD5)|(0<<PD6);
127 |
128 |
129 | if (CharCol_5>0x00)
130 | {
131 | PORTD=(1<<PD6);
132 | PORTA=(!((CharCol_5&0b01000000)>>6)<<PA1)|(!((CharCol_5&0b00100000)>>5)<<PA2)|(!((CharCol_5&0b00010000)>>4)<<PA3)|(!((CharCol_5&0b00001000)>>3)<<PA4)|(!((CharCol_5&0b00000100)>>2)<<PA5)|(!((CharCol_5&0b00000010)>>1)<<PA6)|(!((CharCol_5&0b00000001))<<PA7);
133 |
134 | _delay_us(4000);
135 |
136 | }
137 | }
138 | }
139 |
140 | void SPI_MasterInit(void)
141 | {volatile char IOReg;
142 | /* Set MOSI and SCK output, all others input */
143 |
144 | DDR_SPI =(1<<DD_MOSI)|(1<<DD_SCK)|(1<<DD_SS);
145 |
146 |
147 | /* Enable SPI, Master, set clock rate fck/16 */
148 | SPCR = (1<<SPE)|(1<<MSTR)|(1<<SPR1);
149 | SPSR=(1<<SPI2X);
150 | IOReg=SPSR; // clear SPIF bit in SPSR
151 | IOReg=SPDR;
152 |
153 | }
154 |
155 |
156 | uint8_t SPI_MasterTransmit(char cData)
157 | {
158 | /* Start transmission */
159 | SPDR = cData;
160 |
161 | /* Wait for transmission complete */
162 | while(!(SPSR & (1<<SPIF)));
163 | return SPDR;
164 | }
165 |
166 |
167 |
168 |
169 | unsigned short read_adc(void)
170 | {
171 | // select ADC wait 100 microseconds then read two bytes
172 | SELECT_MCP4151;
173 | _delay_us(100);
174 | unsigned char one =SPI_MasterTransmit(0x43);
175 | _delay_us(100);
176 | unsigned char two = SPI_MasterTransmit(0x0F);
177 | DESELECT_MCP4151;
178 |
179 | //move into 16 bit int
180 | return ((one<<8)|two) ;
181 | }
