1 | -- I2C hardware implementation pic18f
2 | -- at 20 Mhz crystal and 100kHz bus speed master mode
3 |
4 | procedure _i2c_init is
5 |
6 | SSPADD = 0x31 -- 0b_0011_0001 -- clock = 20/(4*(12+1)) = 385kHz -- 49 for 100kHz
7 | SSPCON1 = 0b_0000_1000 -- master mode, clock=Fosc/(4*(SSPADD+1))
8 | SSPCON1_SSPEN = high -- MSSP-Modul enable
9 | SSPCON2 = 0b_0010_0000 -- sets default acknowledge bit value
10 | -- SSPSTAT = 0b_0000_0000 -- enable slew rate control
11 | end procedure
12 |
13 |
14 | -- output a start condition in Master-Mode
15 | procedure i2c_start is
16 |
17 | -- PIR1_SSPIF = low -- SSPIF Bit löschen
18 | SSPCON2_SEN = high -- Bus Übernahme anweisen
19 | while SSPCON2_SEN == high loop
20 | end loop
21 | end procedure
22 |
23 | -- i2c_restart - Sends Restart bit and waits untill finished
24 | procedure i2c_restart is
25 | SSPCON2_RSEN = high
26 | while SSPCON2_RSEN == high loop
27 | end loop
28 | end procedure
29 |
30 |
31 | -- output stop condition
32 | procedure i2c_stop is
33 |
34 | SSPCON2_PEN = high -- initiate I2C bus stop condition
35 | while SSPCON2_PEN == high loop
36 | end loop
37 |
38 | end procedure
39 |
40 | -- init the I2C
41 | _i2c_init
42 | i2c_stop
43 |
44 |
45 | -- output an ack condition
46 | procedure i2c_put_ack is
47 | SSPCON2_ACKDT = low
48 | SSPCON2_ACKEN = high -- ACK senden
49 | while SSPCON2_ACKEN == high loop
50 | end loop
51 | SSPCON2_RCEN = high -- generate receive condition
52 | end procedure
53 |
54 | -- output a nack condition
55 | procedure i2c_put_nack is
56 | SSPCON2_ACKDT = high
57 | SSPCON2_ACKEN = high
58 | end procedure
59 |
60 | -- output a nack condition and stop
61 | procedure i2c_put_nack_stop is
62 | i2c_put_nack
63 | i2c_stop
64 | end procedure
65 |
66 | -- output an ack condition and stop
67 | procedure i2c_put_ack_stop is
68 | i2c_put_ack
69 | i2c_stop
70 | end procedure
71 |
72 |
73 | -- i2c_transmit_byte
74 | function i2c_send_byte(byte in data) return bit is
75 |
76 | PIR1_SSPIF = low -- clear pending flag
77 | SSPBUF = data -- write data
78 |
79 | -- wait untill write is finished
80 | while PIR1_SSPIF == low loop
81 | end loop
82 |
83 | -- get Acknowledge Status Bit _ACKSTAT
84 | -- wich indicates that the slave has responded (or not)
85 | -- if i2c device send an Aknowledge, then ready and OK
86 | if SSPCON2_ACKSTAT == low then
87 | return true -- okay
88 | else
89 | SSPCON1_SSPEN = low
90 | SSPCON1_SSPEN = high
91 |
92 | return false -- no response
93 | end if
94 | end function
95 |
96 |
97 | -- i2c_receive_byte
98 | --
99 | -- The ACK flag indicated if the byte read must be acked.
100 | -- In general, all bytes read by the master are acked, except the last one.
101 | -- Failing to NACK the last byte read will give unpredictable results.
102 | --
103 | -- start receiving of a byte and waits till finished
104 | -- if param ACK is true, the byte is acknowledged and next bytes can be received.
105 | -- if param ACK is false, the byte is nacked and a stop *should be* sent.
106 | -- note: this behavior is inverted from the line level and orignal library, but
107 | -- consistent with the i2c_software library.
108 | --
109 | function i2c_get_byte(bit in ACK ) return byte is
110 | var byte data
111 | -- start receive cyclus and wait till full byte received
112 | SSPCON2_RCEN = high
113 | -- delay_100us(1)
114 | while SSPSTAT_BF == low loop
115 | end loop
116 |
117 | -- send Acknowledge (=low) if STOP=true=high
118 | -- and wait till finishd
119 | -- SSPCON2_ACKDT = ACK
120 | SSPCON2_ACKDT = ! ACK
121 | SSPCON2_ACKEN = high
122 | while SSPCON2_ACKEN == high loop
123 | end loop
124 |
125 | -- get read data
126 | data = SSPBUF
127 |
128 | return data
129 | end function
130 |
131 | -- -----------------------------------------------------------------------------
132 | -- start receiving of a byte and waits till finished
133 | -- if stop is set, an ACK and STOP wil be generated
134 | -- -----------------------------------------------------------------------------
135 | procedure I2C_get_raw_byte (byte out data) is
136 | -- procedure _I2C_receive_byte (byte out data) is
137 | -- start receive cyclus and wait till full byte received
138 | SSPCON2_RCEN = high
139 | while SSPSTAT_BF == low loop
140 | end loop
141 |
142 | -- send Acknowledge (=low) if STOP=true=high
143 | -- and wait till finishd
144 | SSPCON2_ACKDT = low
145 | SSPCON2_ACKEN = high
146 | while SSPCON2_ACKEN == high loop
147 | end loop
148 | -- get read data
149 | data = SSPBUF
150 | end procedure
