1 | /* Thermometer Connections (At your choice) */
2 | #define THERM_PORT PORTD
3 | #define THERM_DDR DDRD
4 | #define THERM_PIN PIND
5 | #define THERM_DQ PD0
6 | /* Utils */
7 | #define THERM_INPUT_MODE() THERM_DDR&=~(1<<THERM_DQ)
8 | #define THERM_OUTPUT_MODE() THERM_DDR|=(1<<THERM_DQ)
9 | #define THERM_LOW() THERM_PORT&=~(1<<THERM_DQ)
10 | #define THERM_HIGH() THERM_PORT|=(1<<THERM_DQ)
11 |
12 | #define THERM_CMD_CONVERTTEMP 0x44
13 | #define THERM_CMD_RSCRATCHPAD 0xbe
14 | #define THERM_CMD_WSCRATCHPAD 0x4e
15 | #define THERM_CMD_CPYSCRATCHPAD 0x48
16 | #define THERM_CMD_RECEEPROM 0xb8
17 | #define THERM_CMD_RPWRSUPPLY 0xb4
18 | #define THERM_CMD_SEARCHROM 0xf0
19 | #define THERM_CMD_READROM 0x33
20 | #define THERM_CMD_MATCHROM 0x55
21 | #define THERM_CMD_SKIPROM 0xcc
22 | #define THERM_CMD_ALARMSEARCH 0xec
23 |
24 | #define THERM_DECIMAL_STEPS_12BIT 625 //.0625
25 | #define THERM_DECIMAL_STEPS_9BIT 50 //.5
26 |
27 |
28 |
29 | uint8_t therm_reset(){
30 |
31 | uint8_t i;
32 |
33 | //Pull line low and wait for 480uS
34 | THERM_LOW();
35 | THERM_OUTPUT_MODE();
36 | _delay_us(480);
37 |
38 | //Release line and wait for 60uS
39 | THERM_INPUT_MODE();
40 | _delay_us(60);
41 |
42 | //Store line value and wait until the completion of 480uS period
43 | i=(THERM_PIN & (1<<THERM_DQ));
44 | _delay_us(420);
45 |
46 | //Return the value read from the presence pulse (0=OK, 1=WRONG)
47 | return i;
48 | }
49 |
50 | void therm_write_bit(uint8_t bit){
51 |
52 | //Pull line low for 1uS
53 | THERM_LOW();
54 | THERM_OUTPUT_MODE();
55 | _delay_us(1);
56 |
57 | //If we want to write 1, release the line (if not will keep low)
58 | if(bit) THERM_INPUT_MODE();
59 |
60 | //Wait for 60uS and release the line
61 | _delay_us(60);
62 | THERM_INPUT_MODE();
63 | }
64 |
65 | uint8_t therm_read_bit(void){
66 |
67 | uint8_t bit=0;
68 |
69 | //Pull line low for 1uS
70 | THERM_LOW();
71 | THERM_OUTPUT_MODE();
72 | _delay_us(1);
73 |
74 | //Release line and wait for 14uS
75 | THERM_INPUT_MODE();
76 | _delay_us(14);
77 |
78 | //Read line value
79 | if(THERM_PIN&(1<<THERM_DQ)) bit=1;
80 |
81 | //Wait for 45uS to end and return read value
82 | _delay_us(45);
83 | return bit;
84 | }
85 |
86 | uint8_t therm_read_byte(void){
87 | uint8_t i=8, n=0;
88 | while(i--){
89 | //Shift one position right and store read value
90 | n>>=1;
91 | n|=(therm_read_bit()<<7);
92 | }
93 | return n;
94 | }
95 |
96 | void therm_write_byte(uint8_t byte){
97 |
98 | uint8_t i=8;
99 |
100 | while(i--){
101 | //Write actual bit and shift one position right to make the next bit ready
102 | therm_write_bit(byte&1);
103 | byte>>=1;
104 | }
105 | }
106 |
107 |
108 |
109 | void therm_read_temperature(char *buffer){
110 |
111 | // Buffer length must be at least 12bytes long! ["+XXX.XXXX C"]
112 | uint8_t temperature[2];
113 | int8_t digit;
114 | uint16_t decimal;
115 |
116 | //Reset, skip ROM and start temperature conversion
117 | therm_reset();
118 | therm_write_byte(THERM_CMD_SKIPROM);
119 | therm_write_byte(THERM_CMD_CONVERTTEMP);
120 |
121 |
122 | //Wait until conversion is complete
123 | while(!therm_read_bit());
124 |
125 | //Reset, skip ROM and send command to read Scratchpad
126 | therm_reset();
127 | therm_write_byte(THERM_CMD_SKIPROM);
128 | therm_write_byte(THERM_CMD_RSCRATCHPAD);
129 |
130 | //Read Scratchpad (only 2 first bytes)
131 | temperature[0]=therm_read_byte();
132 | temperature[1]=therm_read_byte();
133 | therm_reset();
134 |
135 | //Store temperature integer digits and decimal digits
136 | digit=temperature[0]>>4;
137 | digit|=(temperature[1]&0x7)<<2;
138 |
139 | //Store decimal digits
140 | decimal=temperature[0]&0xf;
141 | decimal*=THERM_DECIMAL_STEPS_12BIT;
142 |
143 | //Format temperature into a string [+XXX.XXXX C]
144 | sprintf(buffer, "%2d.%04uC", digit, decimal);
145 |
146 | lcd_txt(1, 1, buffer);
147 | }
