1 | ;------------------------------------------------------------------------------
2 | ; PROCESSOR DECLARATION
3 | ;------------------------------------------------------------------------------
4 | LIST P=12F675 ; list directive to define processor
5 | #INCLUDE <P12F675.INC> ; processor specific variable definitions
6 |
7 | ;------------------------------------------------------------------------------
8 | ; CONFIGURATION WORD SETUP
9 | ;------------------------------------------------------------------------------
10 | __CONFIG _CP_OFF & _CPD_OFF & _BODEN_OFF & _MCLRE_OFF & _WDT_OFF & _PWRTE_ON & _INTRC_OSC_NOCLKOUT
11 |
12 | ;------------------------------------------------------------------------------
13 | ; VARIABLE DEFINITIONS
14 | ;------------------------------------------------------------------------------
15 | ; example of using Shared Uninitialized Data Section
16 | INT_VAR UDATA_SHR 0x20
17 | W_TEMP RES 1 ; variable used for context saving
18 | STATUS_TEMP RES 1 ; variable used for context saving
19 | ; für waitwx:
20 | anzmin RES 1
21 | anzs RES 1
22 | anzds RES 1
23 | anzms RES 1
24 | msconst RES 1
25 | flags RES 1
26 | puls RES 1
27 |
28 | ;------------------------------------------------------------------------------
29 | ; Definitionen:
30 | ;------------------------------------------------------------------------------
31 | #define servo GPIO,5
32 | #define taster GPIO,0
33 | #define rechtsLauf GPIO,1
34 | #define wartePulsDauer flags,0
35 |
36 |
37 | ;------------------------------------------------------------------------------
38 | ; EEPROM INITIALIZATION
39 | ; The 12F675 has 128 bytes of non-volatile EEPROM, starting at address 0x2100
40 | ;------------------------------------------------------------------------------
41 | ;DATAEE CODE 0x2100
42 | ; DE "MCHP" ; Place 'M' 'C' 'H' 'P' at address 0,1,2,3
43 |
44 |
45 | ;------------------------------------------------------------------------------
46 | ; OSCILLATOR CALIBRATION VALUE
47 | ; Internal RC calibration value is placed at location 0x3FF by Microchip as
48 | ; a 0xADDLW K instruction, where the K is a literal value to be loaded into
49 | ; the OSCCAL register.
50 | ;------------------------------------------------------------------------------
51 | OSC CODE 0x03FF
52 |
53 | ;------------------------------------------------------------------------------
54 | ; RESET VECTOR
55 | ;------------------------------------------------------------------------------
56 | RESET_VECTOR CODE 0x0000 ; processor reset vector
57 | GOTO INIT ; go to beginning of program
58 |
59 |
60 |
61 | ;------------------------------------------------------------------------------
62 | ; INTERRUPT SERVICE ROUTINE
63 | ;------------------------------------------------------------------------------
64 | INT_VECTOR CODE 0x0004 ; interrupt vector location
65 | MOVWF W_TEMP ; save off current W register contents
66 | MOVF STATUS,w ; move status register into W register
67 | MOVWF STATUS_TEMP ; save off contents of STATUS register
68 |
69 | ; isr code can go here or be located as a call subroutine elsewhere
70 | btfss servo
71 | goto pulsIsOff
72 | goto pulsIsOn
73 | pulsIsOff
74 | bsf OPTION_REG,0 ;prescaler auf 1:4 umschalten
75 | bcf OPTION_REG,1 ;prescaler auf 1:4 umschalten
76 | bcf OPTION_REG,2 ;prescaler auf 1:4 umschalten
77 | bsf servo
78 | bsf wartePulsDauer
79 | movlw D'5' ;=255-250, 250=1ms
80 | movwf TMR0
81 | goto returnFromInterrupt
82 | pulsIsOn
83 | btfss wartePulsDauer
84 | goto pulsEnde
85 | movlw puls
86 | movwf TMR0
87 | bcf wartePulsDauer
88 | goto returnFromInterrupt
89 | pulsEnde
90 | bcf servo
91 | bcf OPTION_REG,0 ;prescaler auf 1:128 umschalten
92 | bsf OPTION_REG,1 ;prescaler auf 1:128 umschalten
93 | bsf OPTION_REG,2 ;prescaler auf 1:128 umschalten
94 | movlw D'111' ;18.5 ms warten (255-x)*128µs
95 | movwf TMR0
96 | goto returnFromInterrupt
97 | returnFromInterrupt
98 | bcf INTCON,T0IF ;clear flag
99 | MOVF STATUS_TEMP,w ; retrieve copy of STATUS register
100 | MOVWF STATUS ; restore pre-isr STATUS register contents
101 | SWAPF W_TEMP,f
102 | SWAPF W_TEMP,w ; restore pre-isr W register contents
103 | RETFIE ; return from interrupt
104 |
105 |
106 |
107 |
108 | ;------------------------------------------------------------------------------
109 | ; MAIN PROGRAM
110 | ;------------------------------------------------------------------------------
111 | INITIALIZATION CODE
112 | INIT
113 | ;------------------------------------------------------------------------------
114 | ; OSCCAL RESTORE (not required if internal OSC is not used)
115 | ;------------------------------------------------------------------------------
116 | errorlevel -302
117 | BSF STATUS,RP0 ; set file register bank to 1
118 | CALL 0x3FF ; retrieve factory calibration value
119 | MOVWF OSCCAL ; update register with factory cal value
120 | BCF STATUS,RP0 ; set file register bank to 0
121 | errorlevel +302
122 |
123 |
124 | ;------------------------------------------------------------------------------
125 | ; Pin I/O, pull ups und timer0:
126 | ;------------------------------------------------------------------------------
127 | bcf STATUS,RP0 ;Bank 0
128 | clrf GPIO ;Init GPIO, alle low
129 | movlw B'00000111' ;Comparators off
130 | movwf CMCON ;Comparators off
131 | bsf STATUS,RP0 ;Bank 1
132 | clrf ANSEL ;AD Off --> digital IO
133 | movlw B'00000011' ;alle output außer GP0 und GP1;
134 | movwf TRISIO
135 | clrwdt
136 | movlw B'01010001'; pull-ups on, Timer 0 internal clock, prescaler für timer0 auf 1:4
137 | movwf OPTION_REG
138 | bcf STATUS,RP0 ;Bank 0
139 | clrf TMR0 ;clear Timer0
140 | clrf GPIO ;Init GPIO, alle low
141 | movlw D'128' ; Servomittelstellung
142 | movwf puls
143 | bsf INTCON,T0IE ;Timer0 Interpt enabled
144 | bsf INTCON,GIE ;Enable interupts
145 |
146 |
147 | ;------------------------------------------------------------------------------
148 | ; Main Program
149 | ;------------------------------------------------------------------------------
150 | Main
151 |
152 | movlw D'10'
153 | movwf puls
154 | movlw D'10'
155 | call waitwds
156 |
157 | movlw D'128'
158 | movwf puls
159 | movlw D'10'
160 | call waitwds
161 |
162 |
163 | movlw D'230'
164 | movwf puls
165 | movlw D'10'
166 | call waitwds
167 |
168 | movlw D'128'
169 | movwf puls
170 | movlw D'10'
171 | call waitwds
172 |
173 | goto Main
