ich versuche nun seit geraumer Zeit beim Mega644 den ADC zum laufen zu
bringen.
Allerdings kommen nur seltsame Werte bei raus:
1 | #include <avr/interrupt.h>
2 | #include <avr/io.h>
3 | #include "adc/adc.h"
4 |
5 |
6 | #include <stdio.h>
7 | #include <string.h>
8 | #include <stdlib.h>
9 |
10 | #include "uart/uart.h"
11 |
12 | #define nop() asm volatile("nop")
13 | #define ADC_DEBUG
14 |
15 | void adc_init(void)
16 | {
17 | unsigned int tmp_adc_level;
18 |
19 | DDRA = 0x00; //Input
20 | PORTA = 0x00;
21 |
22 | ADMUX = (1 << REFS1) | (1 << REFS0); //AVCC with external capacitor at AREF pin
23 | ADMUX |= (0 << ADLAR); //Right adjusting
24 | ADMUX |= (0 << MUX4) | (0 << MUX3) | (1 << MUX2) | (0 << MUX1) | (0 << MUX0); //ADC4
25 |
26 | ADCSRA = (1 << ADEN) | (0 << ADSC) | (0 << ADATE); //Enable; Don't start conv here; No auto trig
27 | ADCSRA |= (1 << ADIF) | (0 << ADIE); //Clear interrupt flag; ADC interrupt disable
28 | ADCSRA |= (1 << ADPS2) | (1 << ADPS1) | (1 << ADPS0); //Prescaler = 128 (125kHz/FCPU=16MHz)
29 |
30 | ADCSRA |= (1 << ADSC); // Start ACD conversion
31 | while ((ADCSRA & (1<<ADIF))==0)
32 | nop(); //Wait for conversion finished
33 | tmp_adc_level = ADCW; //(ADCH << 8) + ADCL
34 | }
35 |
36 | unsigned int adc_get(void) //TODO uint8 channel
37 | {
38 | unsigned int tmp_adc_level;
39 | #ifdef ADC_DEBUG
40 | char buffer[20];
41 | unsigned int i = 0;
42 | #endif
43 | ADCSRA |= (1 << ADSC); // Start ACD conversion
44 |
45 | while ((ADCSRA & (1<<ADIF))==0)
46 | nop(); //Wait for conversion finished
47 |
48 | ADCSRA |= (1<<ADIF); // Clear ISR flag, usually done by HW
49 |
50 | #ifdef ADC_DEBUG
51 | sprintf(buffer, "ADCL := %i\n\r", ADCL);
52 | uart_puts("\n\r\n\r");
53 | uart_puts(buffer);
54 |
55 | sprintf(buffer, "ADCH := %i\n\r", ADCH);
56 | uart_puts(buffer);
57 | uart_puts("\n\r\n\r");
58 |
59 | sprintf(buffer, "ADCW := %i\n\r", ADCW);
60 | uart_puts(buffer);
61 | uart_puts("\n\r\n\r");
62 |
63 | cli();
64 | tmp_adc_level = ADCL + (ADCH << 8);
65 | sei();
66 | sprintf(buffer, "ADC := %i\n\r", tmp_adc_level);
67 | uart_puts(buffer);
68 | uart_puts("\n\r\n\r");
69 |
70 | uart_puts("--------------------");
71 | uart_puts("\n\r\n\r");
72 | #endif
73 | return tmp_adc_level;
74 | }
adc_get() wird periodisch in main while(1) aufgerufen.
Ich habe einen Trace mit putty aufgenommen und bekomme für
ADCL werte Zwischen 10 und 60
ADCH immer 1
ADCW Werte zwischen 270 und 330.
Das große Problem hier ist, am ADC liegen NULL VOLT an.
Ich habe das Ganze mit dem ADC4, 3, und 2 ausprobiert.
Am Referenzpin liegen 4,87 Volt an.
Ich habe auch versucht die interne 2,5V Referenz zu benutzen, gleiches
Ergebnis.
Habe ich irgend etwas bei der initialisierung vergessen?
Mache ich irgend was in meinem Code falsch?
Oder ist mein Mega hin?
