1 | //--------------------------------------------------------------------
2 | // Configure Device for target Application Here
3 | //--------------------------------------------------------------------
4 | void DeviceInit(void)
5 | {
6 | WDogDisable(); // Disable the watchdog initially
7 | DINT; // Global Disable all Interrupts
8 | IER = 0x0000; // Disable CPU interrupts
9 | IFR = 0x0000; // Clear all CPU interrupt flags
10 |
11 | // SYSTEM CLOCK speed based on Crystal = 20 MHz
12 | // 0xA = 100 MHz (10)
13 | // 0x9 = 90 MHz (9)
14 | // 0x8 = 80 MHz (8)
15 | // 0x7 = 70 MHz (7)
16 | // 0x6 = 60 MHz (6)
17 | // 0x5 = 50 MHz (5)
18 | // 0x4 = 40 MHz (4)
19 | // 0x3 = 30 MHz (3)
20 | // 0x2 = 20 MHz (2)
21 |
22 | PLLset(0xA); // choose from options above
23 |
24 | // Initialise interrupt controller and Vector Table
25 | // to defaults for now. Application ISR mapping done later.
26 | PieCntlInit();
27 | PieVectTableInit();
28 |
29 |
30 | EALLOW; // below registers are "protected", allow access.
31 |
32 | // HIGH / LOW SPEED CLOCKS prescale register settings
33 | SysCtrlRegs.HISPCP.all = 0x0002; // Sysclk / 4 (25 MHz)
34 | SysCtrlRegs.LOSPCP.all = 0x0002; // Sysclk / 4 (25 MHz)
35 | SysCtrlRegs.XCLK.bit.XCLKOUTDIV=2;
36 |
37 | // PERIPHERAL CLOCK ENABLES
38 | //---------------------------------------------------
39 | // If you are not using a peripheral you may want to switch
40 | // the clock off to save power, i.e. set to =0
41 | //
42 | // Note: not all peripherals are available on all 280x derivates.
43 | // Refer to the datasheet for your particular device.
44 |
45 | SysCtrlRegs.PCLKCR0.bit.ADCENCLK = 1; // ADC
46 | //------------------------------------------------
47 | SysCtrlRegs.PCLKCR0.bit.I2CAENCLK = 0; // I2C
48 | //------------------------------------------------
49 | SysCtrlRegs.PCLKCR0.bit.SPIAENCLK=0; // SPI-A
50 | SysCtrlRegs.PCLKCR0.bit.SPIBENCLK=0; // SPI-B
51 | SysCtrlRegs.PCLKCR0.bit.SPICENCLK=0; // SPI-C
52 | SysCtrlRegs.PCLKCR0.bit.SPIDENCLK=0; // SPI-D
53 | //------------------------------------------------
54 | SysCtrlRegs.PCLKCR0.bit.SCIAENCLK=0; // SCI-A //mychanges was =1
55 | SysCtrlRegs.PCLKCR0.bit.SCIBENCLK=1; // SCI-B // was =0
56 | //------------------------------------------------
57 | SysCtrlRegs.PCLKCR0.bit.ECANAENCLK=0; // eCAN-A
58 | SysCtrlRegs.PCLKCR0.bit.ECANBENCLK=0; // eCAN-B
59 | //------------------------------------------------
60 | SysCtrlRegs.PCLKCR1.bit.ECAP1ENCLK = 0; // eCAP1
61 | SysCtrlRegs.PCLKCR1.bit.ECAP2ENCLK = 0; // eCAP2
62 | SysCtrlRegs.PCLKCR1.bit.ECAP3ENCLK = 0; // eCAP3
63 | SysCtrlRegs.PCLKCR1.bit.ECAP4ENCLK = 0; // eCAP4
64 | //------------------------------------------------
65 | SysCtrlRegs.PCLKCR1.bit.EPWM1ENCLK = 0; // ePWM1
66 | SysCtrlRegs.PCLKCR1.bit.EPWM2ENCLK = 0; // ePWM2
67 | SysCtrlRegs.PCLKCR1.bit.EPWM3ENCLK = 0; // ePWM3
68 | SysCtrlRegs.PCLKCR1.bit.EPWM4ENCLK = 0; // ePWM4
69 | SysCtrlRegs.PCLKCR1.bit.EPWM5ENCLK = 0; // ePWM5
70 | SysCtrlRegs.PCLKCR1.bit.EPWM6ENCLK = 0; // ePWM6
71 | //------------------------------------------------
72 | SysCtrlRegs.PCLKCR1.bit.EQEP1ENCLK = 0; // eQEP1
73 | SysCtrlRegs.PCLKCR1.bit.EQEP2ENCLK = 0; // eQEP2
74 | //------------------------------------------------
75 | SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 1; // Enable TBCLK
76 | //------------------------------------------------
77 |
78 |
79 | // GPIO (GENERAL PURPOSE I/O) CONFIG
80 | //--------------------------------------------------------------------------------------
81 | //--------------------------------------------------------------------------------------
82 | // QUICK NOTES on USAGE:
83 | //-----------------------
84 | // If GpioCtrlRegs.GP?MUX?bit.GPIO?= 1, 2 or 3 (i.e. Non GPIO func), then leave
85 | // rest of lines commented
86 | // If GpioCtrlRegs.GP?MUX?bit.GPIO?= 0 (i.e. GPIO func), then:
87 | // 1) uncomment GpioCtrlRegs.GP?DIR.bit.GPIO? = ? and choose pin to be IN or OUT
88 | // 2) If IN, can leave next to lines commented
89 | // 3) If OUT, uncomment line with ..GPACLEAR.. to force pin LOW or
90 | // uncomment line with ..GPASET.. to force pin HIGH or
91 | //--------------------------------------------------------------------------------------
92 | //--------------------------------------------------------------------------------------
93 | // GPIO-00 - PIN FUNCTION = LTA3
94 | GpioCtrlRegs.GPAMUX1.bit.GPIO0 = 0; // 0=GPIO, 1=EPWM1A, 2=Resv, 3=Resv
95 | GpioCtrlRegs.GPADIR.bit.GPIO0 = 1; // 1=OUTput, 0=INput
96 | // GpioDataRegs.GPACLEAR.bit.GPIO0 = 1; // uncomment if --> Set Low initially
97 | // GpioDataRegs.GPASET.bit.GPIO0 = 1; // uncomment if --> Set High initially
98 | //--------------------------------------------------------------------------------------
99 | // GPIO-01 - PIN FUNCTION = SPIOD
100 | GpioCtrlRegs.GPAMUX1.bit.GPIO1 = 0; // 0=GPIO, 1=EPWM1B, 2=SPISIMO-D, 3=Resv
101 | GpioCtrlRegs.GPADIR.bit.GPIO1 = 1; // 1=OUTput, 0=INput
102 | // GpioDataRegs.GPACLEAR.bit.GPIO1 = 1; // uncomment if --> Set Low initially
103 | // GpioDataRegs.GPASET.bit.GPIO1 = 1; // uncomment if --> Set High initially
104 | //--------------------------------------------------------------------------------------
105 | // GPIO-02 - PIN FUNCTION = LTA2
106 | GpioCtrlRegs.GPAMUX1.bit.GPIO2 = 0; // 0=GPIO, 1=EPWM2A, 2=Resv, 3=Resv
107 | GpioCtrlRegs.GPADIR.bit.GPIO2 = 1; // 1=OUTput, 0=INput
108 | // GpioDataRegs.GPACLEAR.bit.GPIO2 = 1; // uncomment if --> Set Low initially
109 | // GpioDataRegs.GPASET.bit.GPIO2 = 1; // uncomment if --> Set High initially
110 | //--------------------------------------------------------------------------------------
111 | // GPIO-03 - PIN FUNCTION = --Spare--
112 | GpioCtrlRegs.GPAMUX1.bit.GPIO3 = 0; // 0=GPIO, 1=EPWM2B, 2=SPISOMI-D, 3=Resv
113 | GpioCtrlRegs.GPADIR.bit.GPIO3 = 0; // 1=OUTput, 0=INput
114 | // GpioDataRegs.GPACLEAR.bit.GPIO3 = 1; // uncomment if --> Set Low initially
115 | // GpioDataRegs.GPASET.bit.GPIO3 = 1; // uncomment if --> Set High initially
116 | //--------------------------------------------------------------------------------------
117 | // GPIO-04 - PIN FUNCTION = --Spare--
118 | GpioCtrlRegs.GPAMUX1.bit.GPIO4 = 0; // 0=GPIO, 1=EPWM3A, 2=Resv, 3=Resv
119 | GpioCtrlRegs.GPADIR.bit.GPIO4 = 0; // 1=OUTput, 0=INput
120 | // GpioDataRegs.GPACLEAR.bit.GPIO4 = 1; // uncomment if --> Set Low initially
121 | // GpioDataRegs.GPASET.bit.GPIO4 = 1; // uncomment if --> Set High initially
122 | //--------------------------------------------------------------------------------------
123 | // GPIO-05 - PIN FUNCTION = SPICLKD
124 | GpioCtrlRegs.GPAMUX1.bit.GPIO5 = 0; // 0=GPIO, 1=EPWM3B, 2=SPICLK-D, 3=ECAP1
125 | GpioCtrlRegs.GPADIR.bit.GPIO5 = 1; // 1=OUTput, 0=INput
126 | // GpioDataRegs.GPACLEAR.bit.GPIO5 = 1; // uncomment if --> Set Low initially
127 | // GpioDataRegs.GPASET.bit.GPIO5 = 1; // uncomment if --> Set High initially
128 | //--------------------------------------------------------------------------------------
129 | // GPIO-06 - PIN FUNCTION = LED_C2
130 | GpioCtrlRegs.GPAMUX1.bit.GPIO6 = 0; // 0=GPIO, 1=EPWM4A, 2=SYNCI, 3=SYNCO
131 | GpioCtrlRegs.GPADIR.bit.GPIO6 = 1; // 1=OUTput, 0=INput
132 | // GpioDataRegs.GPACLEAR.bit.GPIO6 = 1; // uncomment if --> Set Low initially
133 | // GpioDataRegs.GPASET.bit.GPIO6 = 1; // uncomment if --> Set High initially
134 | //--------------------------------------------------------------------------------------
135 | // GPIO-07 - PIN FUNCTION = --Spare--
136 | GpioCtrlRegs.GPAMUX1.bit.GPIO7 = 0; // 0=GPIO, 1=EPWM4B, 2=SPISTE-D, 3=ECAP2
137 | GpioCtrlRegs.GPADIR.bit.GPIO7 = 0; // 1=OUTput, 0=INput
138 | // GpioDataRegs.GPACLEAR.bit.GPIO7 = 1; // uncomment if --> Set Low initially
139 | // GpioDataRegs.GPASET.bit.GPIO7 = 1; // uncomment if --> Set High initially
140 | //--------------------------------------------------------------------------------------
141 | // GPIO-08 - PIN FUNCTION = --Spare--
142 | GpioCtrlRegs.GPAMUX1.bit.GPIO8 = 0; // 0=GPIO, 1=EPWM5A, 2=CANTX-B, 3=ADCSOC-A
143 | GpioCtrlRegs.GPADIR.bit.GPIO8 = 1; // 1=OUTput, 0=INput
144 | // GpioDataRegs.GPACLEAR.bit.GPIO8 = 1; // uncomment if --> Set Low initially
145 | // GpioDataRegs.GPASET.bit.GPIO8 = 1; // uncomment if --> Set High initially
146 | //--------------------------------------------------------------------------------------
147 | // GPIO-09 - PIN FUNCTION = --Spare--
148 | // GpioCtrlRegs.GPAPUD.bit.GPIO9 = 0; // Enable pull-up for GPIO9 (SCITXDB)//mychanges
149 | GpioCtrlRegs.GPAMUX1.bit.GPIO9 = 2; // 0=GPIO, 1=EPWM5B, 2=SCITX-B, 3=ECAP3
150 | // GpioCtrlRegs.GPADIR.bit.GPIO9 = 1; // 1=OUTput, 0=INput
151 | // GpioDataRegs.GPACLEAR.bit.GPIO9 = 1; // uncomment if --> Set Low initially
152 | // GpioDataRegs.GPASET.bit.GPIO9 = 1; // uncomment if --> Set High initially
153 | //--------------------------------------------------------------------------------------
154 | // GPIO-10 - PIN FUNCTION = --Spare--
155 | GpioCtrlRegs.GPAMUX1.bit.GPIO10 = 0; // 0=GPIO, 1=EPWM6A, 2=CANRX-B, 3=ADCSOC-B
156 | GpioCtrlRegs.GPADIR.bit.GPIO10 = 1; // 1=OUTput, 0=INput
157 | // GpioDataRegs.GPACLEAR.bit.GPIO10 = 1; // uncomment if --> Set Low initially
158 | // GpioDataRegs.GPASET.bit.GPIO10 = 1; // uncomment if --> Set High initially
159 | //--------------------------------------------------------------------------------------
160 | // GPIO-11 - PIN FUNCTION = --Spare--
161 | // GpioCtrlRegs.GPAPUD.bit.GPIO11 = 0; // Enable pull-up for GPIO11 (SCIRXDB)//mychanges
162 | // GpioCtrlRegs.GPAQSEL1.bit.GPIO11 = 3; // Asynch input GPIO11 (SCIRXDB)//mychanges
163 | GpioCtrlRegs.GPAMUX1.bit.GPIO11 = 2; // 0=GPIO, 1=EPWM6B, 2=SCIRX-B, 3=ECAP4
164 | // GpioCtrlRegs.GPADIR.bit.GPIO11 = 0; // 1=OUTput, 0=INput
165 | // GpioDataRegs.GPACLEAR.bit.GPIO11 = 1; // uncomment if --> Set Low initially
166 | // GpioDataRegs.GPASET.bit.GPIO11 = 1; // uncomment if --> Set High initially
167 | //--------------------------------------------------------------------------------------
168 | // GPIO-21 - PIN FUNCTION = --Spare--
169 | GpioCtrlRegs.GPAMUX2.bit.GPIO21 = 0; // 0=GPIO, 1=EQEPB-1, 2=SPISOMI-C, 3=CANRX-B
170 | GpioCtrlRegs.GPADIR.bit.GPIO21 = 0; // 1=OUTput, 0=INput
171 | // GpioDataRegs.GPACLEAR.bit.GPIO21 = 1; // uncomment if --> Set Low initially
172 | // GpioDataRegs.GPASET.bit.GPIO21 = 1; // uncomment if --> Set High initially
173 | //--------------------------------------------------------------------------------------
174 | // GPIO-12 - PIN FUNCTION = --Spare--
175 | GpioCtrlRegs.GPAMUX1.bit.GPIO12 = 0; // 0=GPIO, 1=TZ1, 2=CANTX-B, 3=SPISIMO-B
176 | GpioCtrlRegs.GPADIR.bit.GPIO12 = 1; // 1=OUTput, 0=INput
177 | // GpioDataRegs.GPACLEAR.bit.GPIO12 = 1; // uncomment if --> Set Low initially
178 | GpioDataRegs.GPASET.bit.GPIO12 = 1; // uncomment if --> Set High initially
179 | //--------------------------------------------------------------------------------------
180 | // GPIO-13 - PIN FUNCTION = --Spare--
181 | GpioCtrlRegs.GPAMUX1.bit.GPIO13 = 0; // 0=GPIO, 1=TZ2, 2=CANRX-B, 3=SPISOMI-B
182 | GpioCtrlRegs.GPADIR.bit.GPIO13 = 1; // 1=OUTput, 0=INput
183 | // GpioDataRegs.GPACLEAR.bit.GPIO13 = 1; // uncomment if --> Set Low initially
184 | // GpioDataRegs.GPASET.bit.GPIO13 = 1; // uncomment if --> Set High initially
185 | //--------------------------------------------------------------------------------------
186 | // GPIO-14 - PIN FUNCTION = --Spare--
187 | GpioCtrlRegs.GPAMUX1.bit.GPIO14 = 0; // 0=GPIO, 1=TZ3, 2=SCITX-B, 3=SPICLK-B
188 | GpioCtrlRegs.GPADIR.bit.GPIO14 = 1; // 1=OUTput, 0=INput
189 | // GpioDataRegs.GPACLEAR.bit.GPIO14 = 1; // uncomment if --> Set Low initially
190 | GpioDataRegs.GPASET.bit.GPIO14 = 1; // uncomment if --> Set High initially
191 | //--------------------------------------------------------------------------------------
192 | // GPIO-15 - PIN FUNCTION = --Spare--
193 | GpioCtrlRegs.GPAMUX1.bit.GPIO15 = 0; // 0=GPIO, 1=TZ4, 2=SCIRX-B, 3=SPISTE-B
194 | GpioCtrlRegs.GPADIR.bit.GPIO15 = 1; // 1=OUTput, 0=INput
195 | // GpioDataRegs.GPACLEAR.bit.GPIO15 = 1; // uncomment if --> Set Low initially
196 | GpioDataRegs.GPASET.bit.GPIO15 = 1; // uncomment if --> Set High initially
197 | //--------------------------------------------------------------------------------------
198 | //--------------------------------------------------------------------------------------
199 | // GPIO-16 - PIN FUNCTION = --Spare--
200 | GpioCtrlRegs.GPAMUX2.bit.GPIO16 = 0; // 0=GPIO, 1=SPISIMO-A, 2=CANTX-B, 3=TZ5
201 | GpioCtrlRegs.GPADIR.bit.GPIO16 = 0; // 1=OUTput, 0=INput
202 | // GpioDataRegs.GPACLEAR.bit.GPIO16 = 1; // uncomment if --> Set Low initially
203 | // GpioDataRegs.GPASET.bit.GPIO16 = 1; // uncomment if --> Set High initially
204 | //--------------------------------------------------------------------------------------
205 | // GPIO-17 - PIN FUNCTION = --Spare--
206 | GpioCtrlRegs.GPAMUX2.bit.GPIO17 = 0; // 0=GPIO, 1=SPISOMI-A, 2=CANRX-B, 3=TZ6
207 | GpioCtrlRegs.GPADIR.bit.GPIO17 = 0; // 1=OUTput, 0=INput
208 | // GpioDataRegs.GPACLEAR.bit.GPIO17 = 1; // uncomment if --> Set Low initially
209 | // GpioDataRegs.GPASET.bit.GPIO17 = 1; // uncomment if --> Set High initially
210 | //--------------------------------------------------------------------------------------
211 | // GPIO-18 - PIN FUNCTION = LED_C3
212 | GpioCtrlRegs.GPAMUX2.bit.GPIO18 = 0; // 0=GPIO, 1=SPICLK-A, 2=SCITX-B, 3=Resv
213 | GpioCtrlRegs.GPADIR.bit.GPIO18 = 1; // 1=OUTput, 0=INput
214 | // GpioDataRegs.GPACLEAR.bit.GPIO18 = 1; // uncomment if --> Set Low initially
215 | // GpioDataRegs.GPASET.bit.GPIO18 = 1; // uncomment if --> Set High initially
216 | //--------------------------------------------------------------------------------------
217 | // GPIO-19 - PIN FUNCTION = LED_C1
218 | GpioCtrlRegs.GPAMUX2.bit.GPIO19 = 0; // 0=GPIO, 1=SPISTE-A, 2=SCIRX-B, 3=Resv
219 | GpioCtrlRegs.GPADIR.bit.GPIO19 = 1; // 1=OUTput, 0=INput
220 | // GpioDataRegs.GPACLEAR.bit.GPIO19 = 1; // uncomment if --> Set Low initially
221 | // GpioDataRegs.GPASET.bit.GPIO19 = 1; // uncomment if --> Set High initially
222 | //--------------------------------------------------------------------------------------
223 | // GPIO-20 - PIN FUNCTION = --Spare--
224 | GpioCtrlRegs.GPAMUX2.bit.GPIO20 = 0; // 0=GPIO, 1=EQEPA-1, 2=SPISIMO-C, 3=CANTX-B
225 | GpioCtrlRegs.GPADIR.bit.GPIO20 = 1; // 1=OUTput, 0=INput
226 | // GpioDataRegs.GPACLEAR.bit.GPIO20 = 1; // uncomment if --> Set Low initially
227 | // GpioDataRegs.GPASET.bit.GPIO20 = 1; // uncomment if --> Set High initially
228 |
229 | //--------------------------------------------------------------------------------------
230 | // GPIO-22 - PIN FUNCTION = --Spare--
231 | GpioCtrlRegs.GPAMUX2.bit.GPIO22 = 0; // 0=GPIO, 1=EQEPS-1, 2=SPICLK-C, 3=SCITX-B
232 | GpioCtrlRegs.GPADIR.bit.GPIO22 = 1; // 1=OUTput, 0=INput
233 | // GpioDataRegs.GPACLEAR.bit.GPIO22 = 1; // uncomment if --> Set Low initially
234 | // GpioDataRegs.GPASET.bit.GPIO22 = 1; // uncomment if --> Set High initially
235 | //--------------------------------------------------------------------------------------
236 | // GPIO-23 - PIN FUNCTION = --Spare--
237 | GpioCtrlRegs.GPAMUX2.bit.GPIO23 = 0; // 0=GPIO, 1=EQEPI-1, 2=SPISTE-C, 3=SCIRX-B
238 | GpioCtrlRegs.GPADIR.bit.GPIO23 = 0; // 1=OUTput, 0=INput
239 | // GpioDataRegs.GPACLEAR.bit.GPIO23 = 1; // uncomment if --> Set Low initially
240 | // GpioDataRegs.GPASET.bit.GPIO23 = 1; // uncomment if --> Set High initially
241 | //--------------------------------------------------------------------------------------
242 | // GPIO-24 - PIN FUNCTION = --Spare--
243 | GpioCtrlRegs.GPAMUX2.bit.GPIO24 = 0; // 0=GPIO, 1=ECAP1, 2=EQEPA-2, 3=SPISIMO-B
244 | GpioCtrlRegs.GPADIR.bit.GPIO24 = 1; // 1=OUTput, 0=INput
245 | // GpioDataRegs.GPACLEAR.bit.GPIO24 = 1; // uncomment if --> Set Low initially
246 | // GpioDataRegs.GPASET.bit.GPIO24 = 1; // uncomment if --> Set High initially
247 | //--------------------------------------------------------------------------------------
248 | // GPIO-25 - PIN FUNCTION = --Spare--
249 | GpioCtrlRegs.GPAMUX2.bit.GPIO25 = 0; // 0=GPIO, 1=ECAP2, 2=EQEPB-2, 3=SPISOMI-B
250 | GpioCtrlRegs.GPADIR.bit.GPIO25 = 0; // 1=OUTput, 0=INput
251 | // GpioDataRegs.GPACLEAR.bit.GPIO25 = 1; // uncomment if --> Set Low initially
252 | // GpioDataRegs.GPASET.bit.GPIO25 = 1; // uncomment if --> Set High initially
253 | //--------------------------------------------------------------------------------------
254 | // GPIO-26 - PIN FUNCTION = --Spare--
255 | GpioCtrlRegs.GPAMUX2.bit.GPIO26 = 0; // 0=GPIO, 1=ECAP3, 2=EQEPI-2, 3=SPICLK-B
256 | GpioCtrlRegs.GPADIR.bit.GPIO26 = 1; // 1=OUTput, 0=INput
257 | // GpioDataRegs.GPACLEAR.bit.GPIO26 = 1; // uncomment if --> Set Low initially
258 | GpioDataRegs.GPASET.bit.GPIO26 = 1; // uncomment if --> Set High initially
259 | //--------------------------------------------------------------------------------------
260 | // GPIO-27 - PIN FUNCTION = --Spare--
261 | GpioCtrlRegs.GPAMUX2.bit.GPIO27 = 0; // 0=GPIO, 1=ECAP4, 2=EQEPS-2, 3=SPISTE-B
262 | GpioCtrlRegs.GPADIR.bit.GPIO27 = 1; // 1=OUTput, 0=INput
263 | // GpioDataRegs.GPACLEAR.bit.GPIO27 = 1; // uncomment if --> Set Low initially
264 | // GpioDataRegs.GPASET.bit.GPIO27 = 1; // uncomment if --> Set High initially
265 | //--------------------------------------------------------------------------------------
266 | // GPIO-28 - PIN FUNCTION = SCI-RX
267 | GpioCtrlRegs.GPAMUX2.bit.GPIO28 = 0; // 0=GPIO, 1=SCIRX-A, 2=Resv, 3=TZ5
268 | // GpioCtrlRegs.GPADIR.bit.GPIO28 = 1; // 1=OUTput, 0=INput
269 | // GpioDataRegs.GPACLEAR.bit.GPIO28 = 1; // uncomment if --> Set Low initially
270 | // GpioDataRegs.GPASET.bit.GPIO28 = 1; // uncomment if --> Set High initially
271 | //--------------------------------------------------------------------------------------
272 | // GPIO-29 - PIN FUNCTION = SCI-TX
273 | GpioCtrlRegs.GPAMUX2.bit.GPIO29 = 0; // 0=GPIO, 1=SCITXD-A, 2=Resv, 3=TZ6
274 | // GpioCtrlRegs.GPADIR.bit.GPIO29 = 0; // 1=OUTput, 0=INput
275 | // GpioDataRegs.GPACLEAR.bit.GPIO29 = 1; // uncomment if --> Set Low initially
276 | // GpioDataRegs.GPASET.bit.GPIO29 = 1; // uncomment if --> Set High initially
277 | //--------------------------------------------------------------------------------------
278 | // GPIO-30 - PIN FUNCTION = --Spare--
279 | GpioCtrlRegs.GPAMUX2.bit.GPIO30 = 0; // 0=GPIO, 1=CANRX-A, 2=Resv, 3=Resv
280 | GpioCtrlRegs.GPADIR.bit.GPIO30 = 1; // 1=OUTput, 0=INput
281 | // GpioDataRegs.GPACLEAR.bit.GPIO30 = 1; // uncomment if --> Set Low initially
282 | GpioDataRegs.GPASET.bit.GPIO30 = 1; // uncomment if --> Set High initially
283 | //--------------------------------------------------------------------------------------
284 | // GPIO-31 - PIN FUNCTION = LED2 on controlCARD
285 | GpioCtrlRegs.GPAMUX2.bit.GPIO31 = 0; // 0=GPIO, 1=CANTX-A, 2=Resv, 3=Resv
286 | GpioCtrlRegs.GPADIR.bit.GPIO31 = 1; // 1=OUTput, 0=INput
287 | // GpioDataRegs.GPACLEAR.bit.GPIO31 = 1; // uncomment if --> Set Low initially
288 | GpioDataRegs.GPASET.bit.GPIO31 = 1; // uncomment if --> Set High initially
289 | //--------------------------------------------------------------------------------------
290 | //--------------------------------------------------------------------------------------
291 | // GPIO-32 - PIN FUNCTION = --Spare--
292 | GpioCtrlRegs.GPBMUX1.bit.GPIO32 = 0; // 0=GPIO, 1=I2C-SDA, 2=SYNCI, 3=ADCSOCA
293 | GpioCtrlRegs.GPBDIR.bit.GPIO32 = 1; // 1=OUTput, 0=INput
294 | // GpioDataRegs.GPBCLEAR.bit.GPIO32 = 1; // uncomment if --> Set Low initially
295 | // GpioDataRegs.GPBSET.bit.GPIO32 = 1; // uncomment if --> Set High initially
296 | //--------------------------------------------------------------------------------------
297 | // GPIO-33 - PIN FUNCTION = --Spare--
298 | GpioCtrlRegs.GPBMUX1.bit.GPIO33 = 0; // 0=GPIO, 1=I2C-SCL, 2=SYNCO, 3=ADCSOCB
299 | GpioCtrlRegs.GPBDIR.bit.GPIO33 = 1; // 1=OUTput, 0=INput
300 | // GpioDataRegs.GPBCLEAR.bit.GPIO33 = 1; // uncomment if --> Set Low initially
301 | // GpioDataRegs.GPBSET.bit.GPIO33 = 1; // uncomment if --> Set High initially
302 | //--------------------------------------------------------------------------------------
303 | // GPIO-34 - PIN FUNCTION = LTA1
304 | GpioCtrlRegs.GPBMUX1.bit.GPIO34 = 0; // 0=GPIO, 1=Resv, 2=Resv, 3=Resv
305 | GpioCtrlRegs.GPBDIR.bit.GPIO34 = 1; // 1=OUTput, 0=INput
306 | // GpioDataRegs.GPBCLEAR.bit.GPIO34 = 1; // uncomment if --> Set Low initially
307 | GpioDataRegs.GPBSET.bit.GPIO34 = 1; // uncomment if --> Set High initially
308 | //--------------------------------------------------------------------------------------
309 |
310 |
311 | //mychanges
312 | // Interrupts that are used in this example are re-mapped to
313 | // ISR functions found within this file.
314 | // EALLOW; // This is needed to write to EALLOW protected registers
315 | // PieVectTable.TINT0 = &cpu_timer0_isr;
316 | // EDIS; // This is needed to disable write to EALLOW protected registers
317 |
318 |
319 | // Step 4. Initialize all the Device Peripherals:
320 | // This function is found in DSP280x_InitPeripherals.c
321 | // InitPeripherals(); // Not required for this example
322 | // InitCpuTimers(); // For this example, only initialize the Cpu Timers
323 | //mychanges
324 |
325 | // Configure CPU-Timer 0 to interrupt every second:
326 | // 100MHz CPU Freq, 1 second Period (in uSeconds)
327 | // ConfigCpuTimer(&CpuTimer0, 100, 1000000);
328 | // StartCpuTimer0();
329 | // Enable CPU INT1 which is connected to CPU-Timer 0:
330 | // IER |= M_INT1;
331 |
332 | // Enable TINT0 in the PIE: Group 1 interrupt 7
333 | // PieCtrlRegs.PIEIER1.bit.INTx7 = 1;
334 |
335 | EINT;//mychanges
336 | ERTM; // Enable Global realtime interrupt DBGM, mychanges
337 |
338 | EDIS; // Disable register access
339 | }
