1 | /*
2 | * DS1307 RTC driver for an ATMEGA328 (really any AVR with TWI hardware).
3 | *
4 | * (C)opyright 2010, 2011 Peter Gammie, peteg42 at gmail dot com. All rights reserved.
5 | * Commenced September 2010.
6 | *
7 | * Redistribution and use in source and binary forms, with or without
8 | * modification, are permitted provided that the following conditions
9 | * are met:
10 | *i2c_rep_start
11 | * 1. Redistributions of source code must retain the above copyright
12 | * notice, this list of conditions and the following disclaimer.
13 | *
14 | * 2. Redistributions in binary form must reproduce the above
15 | * copyright notice, this list of conditions and the following
16 | * disclaimer in the documentation and/or other materials provided
17 | * with the distribution.
18 | *
19 | * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESS OR IMPLIED
20 | * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
21 | * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
22 | * DISCLAIMED. IN NO EVENT SHALL THE CONTRIBUTORS BE LIABLE FOR ANY
23 | * DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
24 | * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE
25 | * GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
26 | * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
27 | * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
28 | * NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
29 | * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
30 | *
31 | * Changed to work with Peter Fleury's I2C Library
32 | * Added string functions for date and time for easy LCD and UART handling
33 | * (C)opyright 2011 Mosci.to
34 | */
35 |
36 | #ifndef _ds1307_H_
37 | #define _ds1307_H_
38 |
39 | #include <stdbool.h>
40 |
41 | #include "i2cmaster.h"
42 | #include <string.h>
43 |
44 | /* **************************************** */
45 |
46 | /* DS1307-specifics: twi address 0b1101000. Note: shifted left 1. */
47 | #define DS1307_ADDR 0xD0
48 |
49 | /* reg0: Turns the clock oscillator on/off. */
50 | #define CLOCK_HALT 7
51 |
52 | /* reg7: Square-wave output. */
53 | #define SQW_CONTROL_REG 0x07
54 |
55 | #define SQW_OUT 7
56 | #define SQW_SQWE 4
57 | #define SQW_RS1_RS0_1Hz 0x0
58 |
59 | /* reg2: if TWELVE_HOUR
60 | * then 12hr mode with AMPM indictor,
61 | * otherwise 24hr mode. */
62 | #define AMPM _BV(5)
63 | #define TWELVE_HOUR _BV(6)
64 |
65 | /* Unsigned 8-bit BCD operations. */
66 | #define fromBCD(x) (((x) >> 4) * 10 + ((x) & 0xF))
67 | #define toBCD(x) ((((x) / 10) << 4) | ((x) % 10))
68 |
69 | /* FIXME add bit widths */
70 | struct ds1307_time_t {
71 | uint8_t seconds;
72 | uint8_t minutes;
73 | uint8_t hours;
74 | uint8_t day;
75 | uint8_t date;
76 | uint8_t month;
77 | uint8_t year;
78 | };
79 |
80 | /* **************************************** */
81 |
82 | static inline bool ds1307_read(struct ds1307_time_t *time_data)
83 | {
84 | uint8_t data;
85 |
86 | /* Tell the DS1307 we want to read starting at address 0. */
87 | i2c_start_wait(DS1307_ADDR+I2C_WRITE);
88 | i2c_write(0x00);
89 | /* Commence the read. */
90 | i2c_rep_start(DS1307_ADDR+I2C_READ);
91 |
92 | data=i2c_readAck();
93 | time_data->seconds = fromBCD(data & ~_BV(CLOCK_HALT));
94 |
95 | data=i2c_readAck();
96 | time_data->minutes = fromBCD(data);
97 |
98 | /* Read the hours register. */
99 | data=i2c_readAck();
100 | if(data & TWELVE_HOUR) {
101 | uint8_t hours = fromBCD(data & 0x1F);
102 | if(data & AMPM) {
103 | hours += 12;
104 | }
105 | time_data->hours = hours;
106 | } else {
107 | time_data->hours = fromBCD(data);
108 | }
109 |
110 | data=i2c_readAck();
111 | time_data->day = fromBCD(data);
112 |
113 | data=i2c_readAck();
114 | time_data->date = fromBCD(data);
115 |
116 | data=i2c_readAck();
117 | time_data->month = fromBCD(data);
118 |
119 | /* Last read, send NACK. */
120 | data=i2c_readNak();
121 | time_data->year = fromBCD(data);
122 |
123 | i2c_stop();
124 | return true;
125 |
126 | }
127 |
128 | /* FIXME Assumes the time is sane and is a bit hardwired. */
129 | static inline bool ds1307_write(struct ds1307_time_t *time_data)
130 | {
131 |
132 | /* Tell the DS1307 we want to start writing at address 0. */
133 | i2c_start_wait(DS1307_ADDR+I2C_WRITE);
134 | i2c_write(0x00);
135 | /* Keep the oscillator running. */
136 | i2c_write(toBCD(time_data->seconds) & ~_BV(CLOCK_HALT));
137 | i2c_write(toBCD(time_data->minutes));
138 | /* FIXME 24hr time. */
139 | i2c_write(toBCD(time_data->hours));
140 | i2c_write(toBCD(time_data->day));
141 | i2c_write(toBCD(time_data->date));
142 | i2c_write(toBCD(time_data->month));
143 | i2c_write(toBCD(time_data->year));
144 |
145 | i2c_stop();
146 | return true;
147 |
148 | }
149 |
150 | /* Initialise the DS11307. Assumes the TWI interface is already initialised. */
151 | static inline bool ds1307_init(bool interrupts)
152 | {
153 | /* Tell the DS1307 to start the oscillator (turn off CLOCK HALT) in
154 | * case it has lost power. */
155 | uint8_t reg0;
156 |
157 | /* Address, say read from memory slot 0, then read data. */
158 | i2c_start_wait(DS1307_ADDR+I2C_WRITE);
159 | i2c_write(0x0);
160 | i2c_rep_start(DS1307_ADDR+I2C_READ);
161 | reg0=i2c_readNak();
162 |
163 | /* Turn off the clock halt if necessary. */
164 | if(reg0 & _BV(CLOCK_HALT)) {
165 | i2c_start_wait(DS1307_ADDR+I2C_WRITE);
166 | i2c_write(0x0);
167 | i2c_write(reg0 & ~_BV(CLOCK_HALT));
168 | }
169 |
170 | /* Fire up the 1Hz interrupt. */
171 | if(interrupts) {
172 | i2c_start_wait(DS1307_ADDR+I2C_WRITE);
173 | i2c_write(SQW_CONTROL_REG);
174 | i2c_write(_BV(SQW_SQWE) | SQW_RS1_RS0_1Hz);
175 | }
176 |
177 | i2c_stop();
178 |
179 | return true;
180 |
181 | }
182 |
183 |
184 | void set_time_string(char *time_str2)
185 | {
186 | /* Function will use a formatted string containing the current time to set RTC clock
187 | Format: hh:mm:ss
188 | */
189 |
190 | char time_str1 [3]; // Temporary string array
191 | struct ds1307_time_t t; // Declare structure "t" as a copy of structure ds1307_time_t
192 |
193 | ds1307_read(&t); // Read DS1307 and put data in "t struct" so we can write back the date
194 | memset( time_str1, 0, sizeof( time_str1)); // Empty the temporary string
195 | time_str1[0]=time_str2[0]; // Copy first character from source string to temporary string
196 | time_str1[1]=time_str2[1]; // Copy second character from source string to temporary string
197 | t.hours=atoi (time_str1); // Convert temporary string to integer value and store in t structure
198 | time_str1[0]=time_str2[3]; //
199 | time_str1[1]=time_str2[4]; // ... same for the rest of the string
200 | t.minutes=atoi (time_str1); //
201 | time_str1[0]=time_str2[6]; //
202 | time_str1[1]=time_str2[7]; //
203 | t.seconds=atoi (time_str1); //
204 | ds1307_write(&t); // Write structure to RTC
205 |
206 | return; // Return
207 | }
208 |
209 | void set_date_string(char *date_str2)
210 | {
211 | /* Function will use a formatted string containing the current time to set RTC clock
212 | Format: dd.mm.yyyy
213 | */
214 |
215 | char date_str1 [3]; // Temporary string array
216 | struct ds1307_time_t t; // Declare structure "t" as a copy of structure ds1307_time_t
217 |
218 | ds1307_read(&t); // Read DS1307 and put data in "t struct" so we can write back the time
219 | memset( date_str1, 0, sizeof( date_str1)); // Empty the string
220 | date_str1[0]=date_str2[0]; // Copy first character from source string to temporary string
221 | date_str1[1]=date_str2[1]; // Copy second character from source string to temporary string
222 | t.date=atoi (date_str1); // Convert temporary string to integer value and store in t structure
223 | date_str1[0]=date_str2[3]; //
224 | date_str1[1]=date_str2[4]; // ... same for the rest of the string
225 | t.month=atoi (date_str1); //
226 | date_str1[0]=date_str2[8]; //
227 | date_str1[1]=date_str2[9]; //
228 | t.year=atoi (date_str1); //
229 | ds1307_write(&t); // Write structure to RTC
230 |
231 | return; // Return
232 | }
233 |
234 |
235 | char* get_time_string(void)
236 | {
237 | /* Function will return a formatted string containing the current time for easy use on LCD and UART
238 | Format: hh:mm:ss
239 | */
240 |
241 | char time_str1 [3]; // Temporary string array
242 | static char time_str2 [11]; // Needs to be static to survive function exit
243 | struct ds1307_time_t t; // Declare structure "t" as a copy of structure ds1307_time_t
244 |
245 | memset( time_str2, 0, sizeof( time_str2)); // Empty the string to avoid appending
246 |
247 | ds1307_read(&t); // Read DS1307 and put data in "t struct"
248 | if (t.hours<10) strcat (time_str2,"0"); // Add leading zero if required
249 | itoa (t.hours,time_str1,10); // Convert hours into ASCII
250 | strncat (time_str2,time_str1,2); // Append hours string to output string
251 | strcat (time_str2,":"); // Append ":"
252 | if (t.minutes<10) strcat (time_str2,"0"); // Add leading zero if required
253 | itoa (t.minutes,time_str1,10); // Convert minutes to ASCII
254 | strncat (time_str2,time_str1,2); // Append minutes string to output string
255 | strcat (time_str2,":"); // Append ":"
256 | if (t.seconds<10) strcat (time_str2,"0"); // Add leading zero if required
257 | itoa (t.seconds,time_str1,10); // Convert seconds to ASCII
258 | strncat (time_str2,time_str1,2); // Append seconds string to output string
259 |
260 | return time_str2; // Return output string
261 | }
262 |
263 |
264 | char* get_date_string(void)
265 | {
266 | /* Function will return a formatted string containing the current date for easy use on LCD and UART
267 | Format: dd.mm.yyyy
268 | */
269 |
270 | char date_str1 [3]; // Temporary string array
271 | static char date_str2 [11]; // Needs to be static to survive function exit
272 | struct ds1307_time_t t; // Declare structure "t" as a copy of structure ds1307_time_t
273 |
274 | memset( date_str2, 0, sizeof( date_str2)); // Empty the string to avoid appending
275 |
276 | ds1307_read(&t); // Read DS1307 and put data in "t struct"
277 | if (t.date<10) strcat (date_str2,"0"); // Add leading zero if required
278 | itoa (t.date,date_str1,10); // Convert date into ASCII
279 | strncat (date_str2,date_str1,2); // Append date string to output string
280 | strcat (date_str2,"."); // Append "."
281 | if (t.month<10) strcat (date_str2,"0"); // Add leading zero if required
282 | itoa (t.month,date_str1,10); // Convert month to ASCII
283 | strncat (date_str2,date_str1,2); // Append month string to output string
284 | strcat (date_str2,".20"); // Append ".20"
285 | if (t.year<10) strcat (date_str2,"0"); // Add leading zero if required
286 | itoa (t.year,date_str1,10); // Convert year to ASCII
287 | strncat (date_str2,date_str1,2); // Append year string to output string
288 |
289 | return date_str2; // Return output string
290 | }
291 |
292 | #endif /* _ds1307_H_ */
