1 | /*****************************************************
2 | This program was produced by the
3 | CodeWizardAVR V2.05.2 Evaluation
4 | Automatic Program Generator
5 | © Copyright 1998-2011 Pavel Haiduc, HP InfoTech s.r.l.
6 | http://www.hpinfotech.com
7 |
8 | Project : RC-Panzer
9 | Version : 1
10 | Date : 07.07.2011
11 | Author : Sascha Albrecht
12 | Company : Modellfreunde Thüringen
13 | Comments:
14 |
15 |
16 | Chip type : ATmega168
17 | Program type : Application
18 | AVR Core Clock frequency: 16,001000 MHz
19 | Memory model : Small
20 | External RAM size : 0
21 | Data Stack size : 256
22 | *****************************************************/
23 |
24 | #include <mega168.h>
25 |
26 | //Achtung: PWM-Signal ist invertiert! - damit liegt Fall vor Rise
27 | unsigned int pwm1rise; //steigende Flanke
28 | unsigned int pwm1fall; //fallende Flanke
29 | unsigned int pwm1time; //berechneter Zeitwert des PWM-(High)-Signals
30 | unsigned int pwm1last = 1; //merkt sich den letzten Zustand des Pins (um zu prüfen, ob er geändert wurde)
31 | unsigned int pwm1flag = 0;
32 | unsigned int pwm2rise;
33 | unsigned int pwm2fall;
34 | unsigned int pwm2time;
35 | unsigned int pwm2last = 1;
36 | unsigned int pwm2flag = 0;
37 | unsigned int pwm3rise;
38 | unsigned int pwm3fall;
39 | unsigned int pwm3time;
40 | unsigned int pwm3last = 1;
41 | unsigned int pwm3flag = 0;
42 | unsigned int pwm4rise;
43 | unsigned int pwm4fall;
44 | unsigned int pwm4time;
45 | unsigned int pwm4last = 1;
46 | unsigned int pwm4flag = 0;
47 |
48 |
49 |
50 | // Pin change 0-7 interrupt service routine
51 | interrupt [PC_INT0] void pin_change_isr0(void)
52 | {
53 | int time_h, time_l;
54 | time_l = TCNT1L;
55 | time_h = TCNT1H;
56 |
57 | if(PIND.2 != pwm1last)
58 | {
59 | if(pwm1last == 1)
60 | {
61 | pwm1fall = ((int)time_h << 8) + time_l;
62 | pwm1last = 0;
63 | }
64 | else
65 | {
66 | pwm1rise = ((int)time_h << 8) + time_l;
67 | pwm1last = 1;
68 | pwm1flag = 1;
69 | }
70 | }
71 |
72 | if(PIND.4 != pwm2last)
73 | {
74 | if(pwm2last == 1)
75 | {
76 | pwm2fall = ((int)time_h << 8) + time_l; //Achtung: Signal ist invertiert -> Fall kommt vor Rise!
77 | pwm2last = 0;
78 | }
79 | else
80 | {
81 | pwm2rise = ((int)time_h << 8) + time_l;
82 | pwm2last = 1;
83 | pwm2flag = 1;
84 | }
85 | }
86 | }
87 |
88 | // Pin change 8-14 interrupt service routine
89 | interrupt [PC_INT1] void pin_change_isr1(void)
90 | {
91 | int time_h, time_l;
92 | time_l = TCNT1L;
93 | time_h = TCNT1H;
94 |
95 | if(PIND.7 != pwm3last)
96 | {
97 | if(pwm3last == 1)
98 | {
99 | pwm3fall = ((int)time_h << 8) + time_l;
100 | pwm3last = 0;
101 | }
102 | else
103 | {
104 | pwm3rise = ((int)time_h << 8) + time_l;
105 | pwm3last = 1;
106 | pwm3flag = 1;
107 | }
108 | }
109 |
110 | if(PINB.0 != pwm4last)
111 | {
112 | if(pwm4last == 1)
113 | {
114 | pwm4fall = ((int)time_h << 8) + time_l; //Achtung: Signal ist invertiert -> Fall kommt vor Rise!
115 | pwm4last = 0;
116 | }
117 | else
118 | {
119 | pwm4rise = ((int)time_h << 8) + time_l;
120 | pwm4last = 1;
121 | pwm4flag = 1;
122 | }
123 | }
124 |
125 | //Dient nur zur Überprüfung, ob die ISR ausgeführt wird, oder nicht
126 | //if(PINC.5)
127 | // PORTC.5 = 0;
128 | //else
129 | PORTC.5 = 1; //Der Ausgang sollte jett HI sein, sobald die ISR einmal ausgeführt wurde
130 | }
131 |
132 | // Standard Input/Output functions
133 | #include <stdio.h>
134 |
135 | // Declare your global variables here
136 |
137 | void main(void)
138 | {
139 | // Declare your local variables here
140 |
141 | // Crystal Oscillator division factor: 1
142 | #pragma optsize-
143 | CLKPR=0x80;
144 | CLKPR=0x00;
145 | #ifdef _OPTIMIZE_SIZE_
146 | #pragma optsize+
147 | #endif
148 |
149 | // Input/Output Ports initialization
150 | // Port B initialization
151 | // Func7=Out Func6=In Func5=In Func4=Out Func3=Out Func2=Out Func1=Out Func0=In
152 | // State7=0 State6=T State5=T State4=0 State3=0 State2=0 State1=0 State0=P
153 | PORTB=0x01;
154 | DDRB=0x9E;
155 |
156 | // Port C initialization
157 | // Func6=In Func5=Out Func4=In Func3=In Func2=Out Func1=Out Func0=Out
158 | // State6=T State5=0 State4=T State3=T State2=0 State1=0 State0=0
159 | PORTC=0x00;
160 | DDRC=0x27;
161 |
162 | // Port D initialization
163 | // Func7=In Func6=Out Func5=Out Func4=In Func3=Out Func2=In Func1=Out Func0=In
164 | // State7=P State6=0 State5=0 State4=P State3=0 State2=P State1=0 State0=T
165 | PORTD=0x94;
166 | DDRD=0x6A;
167 |
168 | // Timer/Counter 0 initialization
169 | // Clock source: System Clock
170 | // Clock value: 16001,000 kHz
171 | // Mode: Fast PWM top=0xFF
172 | // OC0A output: Non-Inverted PWM
173 | // OC0B output: Non-Inverted PWM
174 | TCCR0A=0xA3;
175 | TCCR0B=0x01;
176 | TCNT0=0x00;
177 | OCR0A=0x30;
178 | OCR0B=0xA0;
179 |
180 | // Timer/Counter 1 initialization
181 | // Clock source: System Clock
182 | // Clock value: 2000,125 kHz
183 | // Mode: Fast PWM top=ICR1
184 | // OC1A output: Non-Inv.
185 | // OC1B output: Non-Inv.
186 | // Noise Canceler: Off
187 | // Input Capture on Falling Edge
188 | // Timer1 Overflow Interrupt: Off
189 | // Input Capture Interrupt: Off
190 | // Compare A Match Interrupt: Off
191 | // Compare B Match Interrupt: Off
192 | TCCR1A=0xA2;
193 | TCCR1B=0x1A;
194 | TCNT1H=0x00;
195 | TCNT1L=0x00;
196 | //ICR1H=0x9C; //20ms Periode
197 | //ICR1L=0x40;
198 | ICR1H=0xAB; //22ms Periode
199 | ICR1L=0xE0;
200 | OCR1AH=0x0B;
201 | OCR1AL=0xB8;
202 | OCR1BH=0x0F;
203 | OCR1BL=0xA0;
204 |
205 | // Timer/Counter 2 initialization
206 | // Clock source: System Clock
207 | // Clock value: 16001,000 kHz
208 | // Mode: Fast PWM top=0xFF
209 | // OC2A output: Non-Inverted PWM
210 | // OC2B output: Non-Inverted PWM
211 | ASSR=0x00;
212 | TCCR2A=0xA3;
213 | TCCR2B=0x01;
214 | TCNT2=0x00;
215 | OCR2A=0x30;
216 | OCR2B=0xA0;
217 |
218 | // External Interrupt(s) initialization
219 | // INT0: Off
220 | // INT1: Off
221 | // Interrupt on any change on pins PCINT0-7: On
222 | // Interrupt on any change on pins PCINT8-14: On
223 | // Interrupt on any change on pins PCINT16-23: Off
224 | EICRA=0x00;
225 | EIMSK=0x00;
226 | PCICR=0x03;
227 | PCMSK0=0x28;
228 | PCMSK1=0x60;
229 | PCIFR=0x03;
230 |
231 | // Timer/Counter 0 Interrupt(s) initialization
232 | TIMSK0=0x00;
233 |
234 | // Timer/Counter 1 Interrupt(s) initialization
235 | TIMSK1=0x00;
236 |
237 | // Timer/Counter 2 Interrupt(s) initialization
238 | TIMSK2=0x00;
239 |
240 | // USART initialization
241 | // Communication Parameters: 8 Data, 1 Stop, No Parity
242 | // USART Receiver: On
243 | // USART Transmitter: On
244 | // USART0 Mode: Asynchronous
245 | // USART Baud Rate: 19200
246 | UCSR0A=0x00;
247 | UCSR0B=0x18;
248 | UCSR0C=0x06;
249 | UBRR0H=0x00;
250 | UBRR0L=0x33;
251 |
252 | // Analog Comparator initialization
253 | // Analog Comparator: Off
254 | // Analog Comparator Input Capture by Timer/Counter 1: Off
255 | ACSR=0x80;
256 | ADCSRB=0x00;
257 | DIDR1=0x00;
258 |
259 | // ADC initialization
260 | // ADC disabled
261 | ADCSRA=0x00;
262 |
263 | // SPI initialization
264 | // SPI disabled
265 | SPCR=0x00;
266 |
267 | // TWI initialization
268 | // TWI disabled
269 | TWCR=0x00;
270 |
271 | // Global enable interrupts
272 | #asm("sei")
273 |
274 | while (1)
275 | {
276 | if(pwm1flag == 1)
277 | {
278 | //if(pwm1fall > pwm1rise) //für den Fall, dass zwischen pwmXfall und pwmXrise ein TimerOverflow stattgefunden hat
279 | // pwm1time = ((int)(((int)ICR1H << 8) + ICR1L)) - pwm1fall + pwm1rise;
280 | //else
281 | pwm1time = pwm1rise - pwm1fall; //Zeit berechnen
282 |
283 | if(pwm1time >= 1800 && pwm1time <= 4200) //nur Werte zwischen 900us und 2100us sind gültig!
284 | {
285 | #asm("cli")
286 | //OCR1AH = pwm1time >> 8; //setze den PWM-Ausgang mit der eingelesenen Zeit
287 | //OCR1AL = pwm1time & 0xFF; //-"- --> nur zum Test!
288 | #asm("sei")
289 | }
290 | pwm1flag = 0;
291 | }
292 |
293 | if(pwm2flag == 1)
294 | {
295 | pwm2time = pwm2rise - pwm2fall; //Zeit berechnen
296 | if(pwm2time >= 1800 && pwm2time <= 4200) //nur Werte zwischen 900us und 2100us sind gültig!
297 | {
298 | #asm("cli")
299 | //OCR1BH = pwm2time >> 8; //setze den PWM-Ausgang mit der eingelesenen Zeit
300 | //OCR1BL = pwm2time & 0xFF; //-"- --> nur zum Test!
301 | #asm("sei")
302 | }
303 | pwm2flag = 0;
304 | }
305 |
306 | if(pwm3flag == 1)
307 | {
308 | pwm3time = pwm3rise - pwm3fall; //Zeit berechnen
309 | if(pwm3time >= 1800 && pwm3time <= 4200) //nur Werte zwischen 900us und 2100us sind gültig!
310 | {
311 | #asm("cli")
312 | OCR1AH = pwm3time >> 8; //setze den PWM-Ausgang mit der eingelesenen Zeit
313 | OCR1AL = pwm3time & 0xFF; //-"- --> nur zum Test!
314 | #asm("sei")
315 | }
316 | pwm3flag = 0;
317 | }
318 |
319 | if(pwm4flag == 1)
320 | {
321 | pwm4time = pwm4rise - pwm4fall; //Zeit berechnen
322 | if(pwm4time >= 1800 && pwm4time <= 4200) //nur Werte zwischen 900us und 2100us sind gültig!
323 | {
324 | #asm("cli")
325 | OCR1BH = pwm4time >> 8; //setze den PWM-Ausgang mit der eingelesenen Zeit
326 | OCR1BL = pwm4time & 0xFF; //-"- --> nur zum Test!
327 | #asm("sei")
328 | }
329 | pwm4flag = 0;
330 | }
331 | }
332 | }
