Hallo, Ich habe einen PIC 18F2585 in einer schaltung. Als Testsoftware lasse ich einfach ein relais anziehen und eien LED blinken. Der Pic macht ziemlich genau alle 2 Minuten und einigen Seckunden selbstständig ein RESET und startet neu. Hat jemand eine Idee an was das liegen könnte ?? Vielen Dank mk
Hier das Testprogram:
1 | #include "D:\Projeckte\OpenBMS\test.h" |
2 | |
3 | int32 c; |
4 | void main() |
5 | {
6 | |
7 | setup_adc_ports(AN0_TO_AN9|VSS_VREF); |
8 | setup_adc(ADC_CLOCK_DIV_32|ADC_TAD_MUL_20); |
9 | setup_spi(FALSE); |
10 | setup_wdt(WDT_OFF); |
11 | setup_timer_0(RTCC_INTERNAL); |
12 | setup_timer_1(T1_DISABLED); |
13 | setup_timer_2(T2_DISABLED,0,1); |
14 | setup_vref(FALSE); |
15 | setup_oscillator(False); |
16 | |
17 | // TODO: USER CODE!!
18 | c=0; |
19 | output_high(PIN_B0); |
20 | while(1) |
21 | {
22 | c++; |
23 | output_high(PIN_C5); |
24 | printf("+%ld\r\n",c); |
25 | delay_ms(500); |
26 | output_low(PIN_C5); |
27 | delay_ms(500); |
28 | }
29 | }
1 | #include <18F2585.h> |
2 | #device adc=16
3 | |
4 | #FUSES NOWDT //No Watch Dog Timer
5 | #FUSES WDT128 //Watch Dog Timer uses 1:128 Postscale
6 | #FUSES HS //High speed Osc (> 4mhz)
7 | #FUSES NOPROTECT //Code not protected from reading
8 | #FUSES NOBROWNOUT //No brownout reset
9 | #FUSES BORV21 //Brownout reset at 2.1V
10 | #FUSES NOPUT //No Power Up Timer
11 | #FUSES NOCPD //No EE protection
12 | #FUSES STVREN //Stack full/underflow will cause reset
13 | #FUSES NODEBUG //No Debug mode for ICD
14 | #FUSES LVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
15 | #FUSES NOWRT //Program memory not write protected
16 | #FUSES NOWRTD //Data EEPROM not write protected
17 | #FUSES IESO //Internal External Switch Over mode enabled
18 | #FUSES FCMEN //Fail-safe clock monitor enabled
19 | #FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
20 | #FUSES BBSIZ4K //4K words Boot Block size
21 | #FUSES NOWRTC //configuration not registers write protected
22 | #FUSES NOWRTB //Boot block not write protected
23 | #FUSES NOEBTR //Memory not protected from table reads
24 | #FUSES NOEBTRB //Boot block not protected from table reads
25 | #FUSES NOCPB //No Boot Block code protection
26 | #FUSES LPT1OSC //Timer1 configured for low-power operation
27 | #FUSES MCLR //Master Clear pin enabled
28 | #FUSES NOXINST //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
29 | |
30 | #use delay(clock=20000000)
31 | #use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
MK
Für welchen Compiler soll denn der Code sein? Les doch mal das RCON Register aus, dann weißt du was den Reset ausgelöst hat.
