1 | #include <avr/interrupt.h>
2 | #include <avr/pgmspace.h>
3 | #include <stdarg.h>
4 | #include <ctype.h>
5 | #include <string.h>
6 | #include <stdlib.h>
7 | #include <avr/io.h>
8 | #include <util/delay.h>
9 |
10 | #define DDR_SCK DDRB /*!< DDR fuer Maus-SCLK */
11 | #define DDR_SDA DDRB /*!< DDR fuer Maus-SDA */
12 |
13 | #define PORT_SCK PORTB /*!< PORT fuer Maus-SCK */
14 | #define PORT_SDA PORTB /*!< PORT fuer Maus-SDA */
15 | #define PIN_SDA PINB /*!< PIN fuer Maus-SDA */
16 |
17 | #define SCK_PIN (1<<PB1) /*!< PIN nummer fuer Maus-SCK */
18 | #define SDA_PIN (1<<PB0) /*!< PIN nummer fuer Maus-SDA */
19 |
20 | #define ADNS_Produkt_ID 0x00
21 | #define ADNS_Revision_ID 0x01
22 | #define ADNS_Motion 0x02
23 | #define ADNS_DeltaX 0x03
24 | #define ADNS_DeltaY 0x04
25 | #define SQUAL 0x05
26 | #define ADNS_Average_Pixel 0x06
27 | #define ADNS_Maximum_Pixel 0x07
28 | #define ADNS_Configuration_bits 0x0a
29 | #define ADNS_Data_Out_Lower 0x0c
30 | #define ADNS_Data_Out_Upper 0x0d
31 | #define ADNS_Shutter_Lower 0x0e
32 | #define ADNS_Shutter_Upper 0x0f
33 | #define ADNS_Frame_Period_Lower 0x10
34 | #define ADNS_Frame_Period_Upper 0x11
35 |
36 |
37 | #define FOSC 3686400 // Clock Speed
38 | #define BAUD 9600
39 | #define UBRR_VAL FOSC/16/BAUD-1
40 |
41 | #define NOP asm volatile ("nop"::)
42 |
43 |
44 | void uart_init(void);
45 | int uart_putc(unsigned char);
46 | void uart_puts (char *s);
47 | void pan_writeByte(unsigned char);
48 | unsigned char pan_readByte(void);
49 | void pan_write(unsigned char, unsigned char);
50 | unsigned char pan_read(unsigned char);
51 | void pan_init(void);
52 |
53 | volatile uint8_t picture[324];
54 | volatile uint8_t temp;
55 |
56 |
57 | /* Start Hauptprogramm------------------------------------------------
58 | *
59 | -------------------------------------------------------------------*/
60 | int main (void)
61 | {
62 | char Buffer[20];
63 | uint8_t i=0;
64 | uint16_t framecounter=0;
65 | int8_t posx=0,posy=0;
66 |
67 |
68 | pan_init();
69 | _delay_ms(100);
70 | temp=pan_read(ADNS_Produkt_ID);
71 | _delay_ms(100);
72 | pan_write(ADNS_Configuration_bits,0b00000001);//LED an
73 |
74 | uart_init(); // USART initialisieren
75 | itoa(temp,Buffer,10);
76 | uart_puts(Buffer);
77 | i=0;
78 | uart_puts("\n\n\r");
79 | pan_write(ADNS_Configuration_bits,0b00001001);//Pixel Dump anfordern
80 | _delay_ms(100);
81 | for(framecounter=0;framecounter<255;)
82 | {
83 | temp=pan_read(ADNS_Data_Out_Upper);//Pixel Adresse lesen
84 | NOP;
85 | temp=pan_read(ADNS_Data_Out_Lower);//Pixel Daten lesen
86 | NOP;
87 | if(!(temp & (1<<7)))//Wenn dass MSB gesetzt ist die Daten nicht ausgeben
88 | {
89 | i++;
90 | picture[framecounter]=temp;
91 | NOP;
92 | itoa(picture[framecounter],Buffer,10);
93 | uart_puts(Buffer);
94 | uart_putc('\t');
95 | if(i==16)
96 | {
97 | NOP;
98 | uart_puts("\n\r");
99 | i=0;
100 | }
101 | framecounter++;
102 | }
103 |
104 | }
105 |
106 | return 0;
107 | }
108 |
109 |
110 |
111 | void uart_init(void)
112 | {
113 | UCSR0B |= (1<<RXEN0)|(1<<TXEN0); // UART RX, TX und RX Interrupt einschalten
114 | UBRR0H = (UBRR_VAL >> 8);
115 | UBRR0L = (UBRR_VAL & 0xFF);
116 | }
117 |
118 | // Eine Funktion zum Senden von Zeichen ber Seriellen Port
119 | int uart_putc(unsigned char c)
120 | {
121 | while (!(UCSR0A & (1<<UDRE0))) //warten bis Senden moeglich
122 | {
123 | }
124 |
125 | UDR0 = c; // sende Zeichen
126 | return 0;
127 | }
128 |
129 | /* puts ist unabhaengig vom Controllertyp */
130 | void uart_puts (char *s)
131 | {
132 | while (*s)
133 | { /* so lange *s != '\0' also ungleich dem "String-Endezeichen" */
134 | uart_putc(*s);
135 | s++;
136 | }
137 | }
138 |
139 | /*!
140 | * Uebertraegt ein Byte an den Sensor
141 | * @param data das Byte
142 | */
143 | void pan_writeByte(unsigned char data)
144 | {
145 | signed char i;
146 |
147 | DDR_SDA|= SDA_PIN; // SDA auf Output
148 |
149 | for (i=7; i>=0; i--){
150 |
151 | PORT_SCK &= ~SCK_PIN; //SCK auf Low, Daten vorbereiten
152 |
153 | if(data&(1<<i)){ //Bit rausschieben
154 | PORT_SDA|=SDA_PIN;
155 | }else{
156 | PORT_SDA&=~SDA_PIN;
157 | }
158 |
159 | PORT_SCK |= SCK_PIN; // SCK =1 Sensor uebernimmt auf steigender Flanke
160 |
161 | _delay_us(1); //Sensor Zeit lassen um Bit zu holen
162 | }
163 |
164 | DDR_SDA &=~ SDA_PIN; //HI-Z state
165 | PORT_SDA &=~ SDA_PIN;
166 |
167 | }
168 |
169 | /*!
170 | * Liest ein Byte vom Sensor
171 | * @return das Byte
172 | */
173 | unsigned char pan_readByte(void)
174 | {
175 | signed char i;
176 | unsigned char data=0;
177 |
178 | _delay_us(3); //Sensor Zeit lassen um die Daten aus dem Register zu holen
179 |
180 | for (i=7; i>-1; i--){
181 | PORT_SCK &= ~SCK_PIN; // SCK =0 Sensor bereitet Daten auf fallender Flanke vor !
182 |
183 | _delay_us(1); //Sensor kurz Zeit lassen
184 |
185 |
186 | PORT_SCK |= SCK_PIN; // SCK =1 Daten lesen auf steigender Flanke
187 |
188 | if(PIN_SDA&SDA_PIN){ //BIT einlesen
189 | data |= (1<<i);
190 | }else{
191 | data &=~ (1<<i);
192 | }
193 |
194 | }
195 | return data;
196 | }
197 |
198 | /*!
199 | * Uebertraegt ein write-Kommando an den Sensor
200 | * @param adr Adresse
201 | * @param data zu schreibendes byte
202 | */
203 | void pan_write(unsigned char adr, unsigned char data)
204 | {
205 | adr|=(1<<7);
206 | pan_writeByte(adr); //rl MSB muss 1 sein f�r Write Operation
207 | pan_writeByte(data);
208 | }
209 |
210 |
211 |
212 | /*!
213 | * Schickt ein Lesekommando an den Sensor
214 | * und liest ein Byte zurueck
215 | * @param adr die Adresse
216 | * @return der registerwert
217 | */
218 | unsigned char pan_read(unsigned char adr)
219 | {
220 |
221 | pan_writeByte(adr);
222 | return pan_readByte();
223 | }
224 |
225 |
226 | /*!
227 | * Initialisiere PAN3101
228 |
229 | !! Muss unbedingt ganz am ANFANG von main stehen, sonst gibts FEHLER !!
230 | (wenn der A2610 sich initialisiert hat, bevor der Controler SCK und
231 | SDA auf Output gestellt hat)
232 | Deshalb kann es auch sinnvoll sein die Powerup Zeit in den Config Bits
233 | auf 4ms zu stellen oder noch besser mit Boden zu arbeiten.
234 |
235 | */
236 | void pan_init(void)
237 | {
238 |
239 | DDR_SCK |= SCK_PIN; // SCK auf Output
240 | DDR_SDA |= SDA_PIN; //SDA auf Output
241 |
242 | PORT_SCK |= SCK_PIN; // SCK auf high
243 | PORT_SDA|= SDA_PIN; //SDA auf high
244 | }
