1 | ISR(TWI_vect)
2 | {
3 | //******************* SENDEN=1 ********************
4 |
5 | DEBUG_WRITES("\tTWSR=");
6 | DEBUG_ZAHLX(3,TWSR);
7 | DEBUG_WRITES(" ");
8 | DEBUG_ZAHLX(1,TWI_Aktion);
9 |
10 |
11 | if (((TWSR == TWI_START) || (TWSR == TWI_REP_START)) && TWI_Aktion == TWI_SENDEN)
12 | {
13 | DEBUG_WRITES(" #1");
14 | TWDR = (ReceiverAddress << 1) + 0; //Empfänger Adresse ins Datenregister und mit +0 SCHREIBEN
15 | TWCR = (1<<TWIE)|(1<<TWINT) | (1<<TWEN); //TWINT -> Interupt Flag löschen, TWEN -> TWI Aktivieren
16 | }
17 | else if (((TWSR == TWI_MTX_ADR_ACK) || (TWSR == TWI_MTX_DATA_ACK)) && TWI_Aktion == TWI_SENDEN)
18 | { //24 40
19 |
20 | // Puffer leer?
21 | if (twie_p_transmitRead == twie_p_transmitWrite)
22 | {
23 | DEBUG_WRITES(" #2no");
24 | TWCR = (1<<TWEN)|(1<<TWIE)|(1<<TWINT)|(0<<TWEA)|(0<<TWSTA)|(1<<TWSTO)|(0<<TWWC);
25 |
26 | //TWSTO -> Stop senden, TWINT -> Interupt Flag löschen, TWEN -> TWI Aktivieren
27 | TWI_Aktion = TWI_NO;
28 |
29 | // Wait until stop condition is executed and bus released
30 | while (TWCR & (1<<TWINT));
31 |
32 | DEBUG_WRITES(" #go on");
33 |
34 | }
35 | else
36 | {
37 | DEBUG_WRITES(" #2>");
38 | /*
39 | // Pufferfüllstand ermitteln
40 | int8_t result = twie_p_transmitWrite - twie_p_transmitRead;
41 | if (result < 0)
42 | result += TWIE_REC_BUFFER_SIZE;
43 |
44 | // Maximalen Pufferfüllstand merken
45 | if (result > twie_maxtransmit)
46 | twie_maxtransmit = result;
47 | */
48 |
49 | // Nächste Leseposition ermitteln
50 | if (++twie_p_transmitRead >= (twie_transmitBuffer + TWIE_TRA_BUFFER_SIZE))
51 | twie_p_transmitRead = twie_transmitBuffer;
52 |
53 | // Daten lesen und übergeben
54 | TWDR = *twie_p_transmitRead;
55 | DEBUG_WRITEC(*twie_p_transmitRead);
56 | DEBUG_WRITES("<");
57 | TWCR = (1<<TWIE) | (1<<TWINT) | (1<<TWEN); //TWINT -> Interupt Flag löschen, TWEN -> TWI Aktivieren
58 | }
59 | }
60 | else if(((TWSR == TWI_MTX_ADR_NACK) || (TWSR == TWI_ARB_LOST)) && (TWI_Aktion == TWI_SENDEN))
61 | { //32 56
62 | DEBUG_WRITES(" #2.5");
63 | //TWCR= (1<<TWINT)|(1<<TWEN)|(1<<TWSTO);
64 |
65 | TWCR = (1<<TWIE) | (1<<TWINT) | (1<<TWEN) | (1<<TWSTO);
66 | //TWCR = (1<<TWIE) | (1<<TWINT) | (1<<TWEN) | (1<<TWSTO) | (1<<TWEA); //TWINT -> Interupt Flag löschen, TWEN -> TWI Aktivieren, TWSTO -> Stopbedingung
67 | TWI_Aktion = TWI_NO;
68 | busy = 255;
69 | }
70 | else if (/*(TWSR == TWI_MTX_DATA_NACK) && */(TWI_Aktion == TWI_SENDEN))
71 | {
72 | DEBUG_WRITES(" #3");
73 | //Datenübertragung abschließen
74 | //TWCR = (1<<TWIE) | (1<<TWINT) | (1<<TWEN) | (1<<TWSTO) | (1<<TWEA); //TWINT -> Interupt Flag löschen, TWEN -> TWI Aktivieren, TWSTO -> Stopbedingung, TWEA -> Acknowledge mitsenden
75 | //TALPointer = TALPointer_temp;
76 | TWI_Aktion = TWI_NO;
77 | }
78 |
79 |
80 |
81 |
82 | //ACK nach empfangenen Daten senden/ ACK nach gesendeten Daten erwarten
83 | #define TWCR_ACK TWCR = (1<<TWEN)|(1<<TWIE)|(1<<TWINT)|(1<<TWEA)|(0<<TWSTA)|(0<<TWSTO)|(0<<TWWC);
84 |
85 | //NACK nach empfangenen Daten senden/ NACK nach gesendeten Daten erwarten
86 | #define TWCR_NACK TWCR = (1<<TWEN)|(1<<TWIE)|(1<<TWINT)|(0<<TWEA)|(0<<TWSTA)|(0<<TWSTO)|(0<<TWWC);
87 |
88 | //switched to the non adressed slave mode...
89 | #define TWCR_RESET TWCR = (1<<TWEN)|(1<<TWIE)|(1<<TWINT)|(1<<TWEA)|(0<<TWSTA)|(0<<TWSTO)|(0<<TWWC);
90 |
91 | //******************* EMPFANGEN=2 ********************
92 |
93 | else if ((TWSR == TWI_SRX_ADR_ACK) && (TWI_Aktion == TWI_NO)) //96 0x60
94 | {
95 | DEBUG_WRITES(" #4");
96 | TWI_Aktion = TWI_EMPFANGEN;
97 | TWCR_ACK;
98 | }
99 | else if ((TWSR == TWI_SRX_ADR_DATA_ACK) && (TWI_Aktion == TWI_EMPFANGEN))
100 | { // 128 0x80
101 | DEBUG_WRITES(" #5>");
102 | uint8_t *twie_p_temp = twie_p_receiveWrite + 1;
103 |
104 | // Nächste Schreibposition ermitteln
105 | if (twie_p_temp >= twie_receiveBuffer + TWIE_REC_BUFFER_SIZE)
106 | twie_p_temp = twie_receiveBuffer;
107 |
108 | // Speicher im Puffer frei?
109 | if (twie_p_temp != twie_p_receiveRead)
110 | {
111 | twie_p_receiveWrite = twie_p_temp;
112 | *twie_p_receiveWrite = TWDR;
113 | DEBUG_WRITEC(*twie_p_receiveWrite);
114 | DEBUG_WRITES("<");
115 | }
116 | else
117 | {
118 | //Overflow
119 | }
120 |
121 | TWCR_ACK;
122 | }
123 | else if ((TWSR == TWI_SRX_STOP_RESTART) && (TWI_Aktion == TWI_EMPFANGEN))
124 | { //160
125 | DEBUG_WRITES(" #7");
126 | TWCR = (1<<TWIE) | (1<<TWINT) | (1<<TWEN) | (1<<TWEA) | (1<<TWSTO); //
127 | TWI_Aktion = TWI_NO;
128 | }
129 | else
130 | {
131 | TWCR_ACK;
132 | TWI_Aktion = TWI_NO;
133 | }
134 |
135 | /*
136 | else if ((TWSR == TWI_SRX_ADR_DATA_NACK) && (TWI_Aktion == TWI_EMPFANGEN))
137 | { // 136 0x88
138 | DEBUG_WRITES(" #6>");
139 | uint8_t *twie_p_temp = twie_p_receiveWrite + 1;
140 |
141 | // Nächste Schreibposition ermitteln
142 | if (twie_p_temp >= twie_receiveBuffer + TWIE_REC_BUFFER_SIZE)
143 | twie_p_temp = twie_receiveBuffer;
144 |
145 | // Speicher im Puffer frei?
146 | if (twie_p_temp != twie_p_receiveRead)
147 | {
148 | twie_p_receiveWrite = twie_p_temp;
149 | *twie_p_receiveWrite = TWDR;
150 | DEBUG_WRITEC(*twie_p_receiveWrite);
151 | DEBUG_WRITES("<");
152 | }
153 | else
154 | {
155 | //Overflow
156 | }
157 |
158 | TWCR = (1<<TWIE)|(1<<TWINT) | (1<<TWEN) | (1<<TWEA); //| (1<<TWSTO)
159 | TWI_Aktion = TWI_NO;
160 |
161 |
162 |
163 | }
164 | else if ((TWSR == TWI_SRX_STOP_RESTART) && (TWI_Aktion == TWI_EMPFANGEN))
165 | { //160
166 | DEBUG_WRITES(" #7");
167 | TWCR = (1<<TWIE) | (1<<TWINT) | (1<<TWEN) | (1<<TWEA); // | (1<<TWSTO)
168 | TWI_Aktion = TWI_NO;
169 | }
170 | */
171 | return;
172 | }
