1 | reset_can();
2 | //mode: configuration
3 | can_mode(0x80);
4 |
5 | // Die drei folgenden Settings wurden ermittelt anhand von
6 | // "Kvaser Bit Timing Calculator" mit folgenden Eingabewerten:
7 | // fclock (MCP)= 20MHz
8 | // Bit-Rate = 1000 kBit/s
9 |
10 | //Konfiguartions-Mode
11 | send_can_command(CNF1, 0x00);
12 | send_can_command(CNF2, 0x92);
13 | send_can_command(CNF3, 0x02);
14 |
15 | // kein priorität
16 | send_can_command(TXB0CTRL, 0x00);
17 | send_can_command(TXB1CTRL, 0x00);
18 | send_can_command(TXB2CTRL, 0x00);
19 |
20 | // keine filterung
21 | send_can_command(RXM0SIDH, 0x00);
22 | send_can_command(RXM0SIDL, 0x00);
23 |
24 | send_can_command(RXM1SIDH, 0x00);
25 | send_can_command(RXM1SIDL, 0x00);
26 |
27 | send_can_command(RXF0SIDH, 0x00);
28 | send_can_command(RXF0SIDL, 0x00);
29 |
30 | send_can_command(RXF1SIDH, 0x00);
31 | send_can_command(RXF1SIDL, 0x00);
32 |
33 | send_can_command(RXF2SIDH, 0x00);
34 | send_can_command(RXF2SIDL, 0x00);
35 |
36 | send_can_command(RXF3SIDH, 0x00);
37 | send_can_command(RXF3SIDL, 0x00);
38 |
39 | send_can_command(RXF4SIDH, 0x00);
40 | send_can_command(RXF4SIDL, 0x00);
41 |
42 | send_can_command(RXF5SIDH, 0x00);
43 | send_can_command(RXF5SIDL, 0x00);
44 |
45 | //Receive all valid messages
46 | send_can_command(RXB0CTRL, 0x00);
47 | send_can_command(RXB1CTRL, 0x00);
48 |
49 | //Transmit
50 | send_can_command(TXB0SIDL, 0x00);
51 | send_can_command(TXB1SIDH, 0x00);
52 |
53 | // enable Interrupts nur RX*-Register
54 | send_can_command(CANINTE, 0x23);
55 | send_can_command(CANINTF, CANINTF_ALL_CLEAR);
56 |
57 | //normal mode + one shot mode
58 | can_mode(0x08);//08
59 |
60 | return TRUE
