1 | #include <stdio.h>
2 | #include <avr\io.h>
3 | #define F_CPU 32000000UL
4 | #include <util\delay.h>
5 | #include <math.h>
6 |
7 | #define VERSION "0.0.1"
8 |
9 |
10 | void SetWaveFreq(unsigned long int freq);
11 | void SetWaveCount(char count);
12 | void LoadSineWave(int len);
13 |
14 | void Config32MHzClock(void);
15 |
16 |
17 |
18 |
19 | void DoSineWave(unsigned int freq);
20 |
21 |
22 |
23 | volatile int data12[100];
24 | volatile int gWaveNumSamp=50;
25 | volatile int gWaveCount=0;
26 |
27 |
28 | int main(void)
29 | {
30 | int Reading, index;
31 | char data;
32 | char buffer[100];
33 |
34 |
35 | Config32MHzClock();
36 |
37 | CLK.PSCTRL = 0x00; // no division on peripheral clock
38 |
39 | PORTCFG.CLKEVOUT = PORTCFG_CLKOUT_PE7_gc;
40 | PORTE.DIR = (1<<7); // clkout
41 | TCC0.CTRLA = 4;
42 |
43 | // setup DAC output on PORTB:1 as GND reference
44 | PORTB.DIR |= 0x02;
45 | PORTB.OUT &= 0xFD;
46 |
47 |
48 |
49 |
50 | LoadSineWave(gWaveNumSamp);
51 |
52 |
53 |
54 | while(1)
55 | {
56 |
57 | };
58 |
59 | }
60 |
61 |
62 | void DoDAC(unsigned int ch, unsigned int value, unsigned int ref)
63 | {
64 | if(ref<4)
65 | DACB.CTRLC = (ref << 3); // select reference
66 | else return; // early return for bad parameter
67 |
68 | DACB.CTRLB = DAC_CHSEL_DUAL_gc; // select dual output DAC
69 | if(ch==0)
70 | {
71 | DACB.CTRLA = (1<<2) | (1<<0); // enable DACB, CH0
72 | DACB.CH0DATA = value;
73 | }
74 | if(ch==1)
75 | {
76 | DACB.CTRLA |= (1<<3) | (1<<0); // enable DACB, CH1
77 | DACB.CH1DATA = value;
78 | };
79 |
80 | };
81 |
82 | void DoSineWave(unsigned int freq)
83 | {
84 | gWaveNumSamp=50;
85 |
86 | LoadSineWave(gWaveNumSamp);
87 |
88 | SetWaveFreq(freq);
89 | };
90 |
91 |
92 |
93 |
94 | void DoNCycles(char num)
95 | {
96 | SetWaveCount(num);
97 | };
98 |
99 | void DoOutputOff()
100 | {
101 | DMA.CTRL = 0x00; // stop dma
102 | DoDAC(0,0,1); // drive DAC to 0
103 | };
104 |
105 |
106 |
107 | void LoadSineWave(int len)
108 | {
109 | int i;
110 |
111 | for(i=0;i<len;i++)
112 | {
113 | data12[i]=((sin((2.0/(float)len)*(float)i*M_PI)*0.5 + 0.5)*4095);
114 | };
115 |
116 | };
117 |
118 |
119 |
120 |
121 |
122 | void SetWaveFreq(unsigned long int freq)
123 | {
124 | if(freq > 10000)
125 | {
126 | TCD0.CTRLA = 0x1;
127 | TCD0.PER = (int) ((F_CPU/freq/gWaveNumSamp));
128 | }
129 | else
130 | {
131 | TCD0.CTRLA = 0x2;
132 | TCD0.PER = (int) ((F_CPU/freq/gWaveNumSamp)/2.0);
133 |
134 | };
135 | };
136 |
137 | void SetWaveCount(char count)
138 | {
139 | gWaveCount = count; // if count = 0 then repeat count is infinite
140 | };
141 |
142 |
143 |
144 |
145 | void Config32MHzClock(void)
146 | {
147 | CCP = CCP_IOREG_gc; //Security Signature to modify clock
148 | // initialize clock source to be 32MHz internal oscillator (no PLL)
149 | OSC.CTRL = OSC_RC32MEN_bm; // enable internal 32MHz oscillator
150 | while(!(OSC.STATUS & OSC_RC32MRDY_bm)); // wait for oscillator ready
151 | CCP = CCP_IOREG_gc; //Security Signature to modify clock
152 | CLK.CTRL = 0x01; //select sysclock 32MHz osc
153 |
154 | };
