1 | ;-------------------------------------------------------------------------
2 | ; Titel : myAVR Beispiel "UART senden" für den ATmega8
3 | ;-------------------------------------------------------------------------
4 | ; Funktion : sendet den String "Test" mit 9600 Baud per serieller
5 | ; : Schnittstelle
6 | ; Schaltung : Nullmodemkabel an PC & AVR-Board
7 | ;-------------------------------------------------------------------------
8 | ; Prozessor : ATmega8
9 | ; Takt : 3,6864 MHz
10 | ; Sprache : Assembler
11 | ; Datum : 09.11.2007
12 | ; Version : 1.0
13 | ; Autor : Renaldo Badke
14 | ; Programmer :
15 | ; Port :
16 | ;-------------------------------------------------------------------------
17 | .equ F_CPU = 3686400
18 | .include "m8def.inc"
19 | ;----------------------------------------------------------------------
20 | ;Reset and Interruptvectoren ;VNr. Beschreibung
21 | begin:
22 | rjmp main ; 1 POWER ON RESET
23 | reti ; 2 Int0-Interrupt
24 | reti ; 3 Int1-Interrupt
25 | reti ; 4 TC2 Compare Match
26 | reti ; 5 TC2 Overflow
27 | reti ; 6 TC1 Capture
28 | reti ; 7 TC1 Compare Match A
29 | reti ; 8 TC1 Compare Match B
30 | reti ; 9 TC1 Overflow
31 | reti ;10 TC0 Overflow
32 | reti ;11 SPI, STC Serial Transfer Complete
33 | reti ;12 UART Rx Complete
34 | reti ;13 UART Data Register Empty
35 | reti ;14 UART Tx Complete
36 | reti ;15 ADC Conversion Complete
37 | reti ;16 EEPROM Ready
38 | reti ;17 Analog Comperator
39 | reti ;18 TWI (I²C) Serial Interface
40 | reti ;19 Strore Program Memory Ready
41 | ;------------------------------------------------------------------------
42 | ;Start, Power ON, Reset
43 | main:
44 | ldi r16,high(RAMEND)
45 | out SPH,r16
46 | ldi r16,low(RAMEND) ;Stack Initialisierung
47 | out SPL,r16 ;Init Stackpointer
48 |
49 | sbi UCSRB,3 ;USR=UCSRB=0x0A TXEN=Bit3 TX aktivieren
50 | ldi r16,3686400/(9600*16)-1 ;Baudrate 9600 einstellen
51 | out UBRRL,r16
52 |
53 | ldi r16,0b01000000 ;Messbereich 0-5V, Kanal 0
54 | out ADMUX,r16
55 | ldi r16,0b10000111 ;ADC an, CLK=8MHz/128
56 | out ADCSRA,r16
57 | ;------------------------------------------------------------------------
58 | mainloop:
59 | sbi ADCSR,ADSC
60 |
61 | subloop:
62 | sbis ADCSR,ADIF ;Warten bis Wandlung beendet ist
63 | rjmp subloop
64 | in r17,ADCL ;Die unteren 8 Bit in r17 merken
65 | in r18,ADCH
66 | rcall warte3 ;EDIT-----------------------auf warte 2 setzen für größere werte
67 | rjmp mainloop
68 |
69 | ;------------------------------------------------------------------------
70 | warte2: sbis UCSRA,UDRE ;Warten bis Senderegister frei ist
71 | rjmp warte2
72 | out UDR,r18 ;dann die oberen 2 Bit senden
73 | warte3: sbis UCSRA,UDRE ;Warten bis Senderegister frei ist
74 | rjmp warte3
75 | out UDR,r17 ;dann die unteren 8 Bit senden
76 | rjmp mainloop ;dann die unteren 8 Bit senden
77 |
78 | ;-----------------------------------------------------------------------
