1 | #include "io430.h"
2 | #include "intrinsics.h"
3 |
4 |
5 | typedef signed int int8;
6 | typedef unsigned int uint8;
7 | typedef signed short int16;
8 | typedef unsigned short uint16;
9 | typedef signed long int32;
10 | typedef unsigned long uint32;
11 |
12 |
13 | #define PHASE_A (P1IN & BIT4) // P1.4 als Eingang Encoder
14 | #define PHASE_B (P1IN & BIT5) // P1.5 als Eingang Encoder
15 |
16 | volatile int8 enc_delta; // -128 ... 127
17 | static int8 last;
18 |
19 | const uint16 pwm_table[64] = {
20 | 0, 0, 2, 4, 8, 14, 21, 30, 41, 54,
21 | 69, 86, 106, 127, 151, 178, 206, 238, 271, 308,
22 | 347, 388, 433, 480, 530, 583, 638, 697, 758, 823,
23 | 890, 961, 1035, 1111, 1191, 1274, 1361, 1450, 1543, 1639,
24 | 1739, 1841, 1947, 2057, 2170, 2286, 2406, 2530, 2657, 2787,
25 | 2921, 3059, 3200, 3345, 3494, 3646, 3802, 3962, 4125, 4293,
26 | 4464, 4639, 4817, 5000
27 | };
28 |
29 | static uint8 pwm_index = 7;
30 |
31 |
32 | void encode_init( void )
33 | {
34 | int8 new;
35 |
36 | new = 0;
37 | if( PHASE_A )
38 | new = 3;
39 | if( PHASE_B )
40 | new ^= 1; // convert gray to binary
41 | last = new; // power on state
42 | enc_delta = 0;
43 | }
44 |
45 | int8 encode_read1( void ) // read single step encoders
46 | {
47 | int8 val;
48 |
49 | __disable_interrupt();
50 | val = enc_delta;
51 | enc_delta = 0;
52 | __enable_interrupt();
53 | return val; // counts since last call
54 | }
55 |
56 |
57 | // Watchdog Timer interrupt service routine used for Encoder
58 | #pragma vector=WDT_VECTOR
59 | __interrupt void watchdog_timer(void)
60 | {
61 | int8 new, diff;
62 |
63 | new = 0;
64 | if( PHASE_A )
65 | new = 3;
66 | if( PHASE_B )
67 | new ^= 1; // convert gray to binary
68 | diff = last - new; // difference last - new
69 | if( diff & 1 ){ // bit 0 = value (1)
70 | last = new; // store new as next last
71 | enc_delta += (diff & 2) - 1; // bit 1 = direction (+/-)
72 | }
73 | }
74 |
75 |
76 | void main( void )
77 | {
78 | WDTCTL = WDT_MDLY_0_5; // Set Watchdog Timer interval to ~0.5ms
79 | IE1 |= WDTIE; // Enable WDT interrupt
80 |
81 | BCSCTL1 = CALBC1_1MHZ; // 1 MHz clock
82 | DCOCTL = CALDCO_1MHZ;
83 |
84 | P1SEL = 0x00; // Port 1 als GPIO nutzen
85 | P1REN |= (BIT4 + BIT5); // P1.4 und P1.5 Resistor enabled
86 | P1OUT |= (BIT4 + BIT5); // P1.4 und P1.5 Pullup enabled
87 | P1DIR |= BIT6; // P1.6 output (green LED)
88 | P1SEL |= BIT6; // P1.6 = TA0.1 (timer A's output)
89 |
90 | TACTL = TASSEL_2 + MC_1; // Source Timer A from SMCLK (TASSEL_2), up mode (MC_1)
91 | // Up mode counts up to TACCR0
92 | TACCTL1 = OUTMOD_7; // OUTMOD_7 = CCR1 reset/set output when the timer counts to TACCR1
93 | TACCR0 = 5000; // PWM period = 1 MHz / 5000 = ~200 Hz
94 | TACCR1 = pwm_table[7]; // Initial CCR1 (= brightness)
95 |
96 | int8 val = 0;
97 |
98 | encode_init();
99 | __enable_interrupt();
100 |
101 | for(;;)
102 | {
103 | val += encode_read1();
104 |
105 | if(val > 0) // Encoder linksdrehung
106 | { // grün dunkler (LED1)
107 | if (pwm_index > 1)
108 | {
109 | pwm_index--;
110 | TACCR1 = pwm_table[pwm_index];
111 | }
112 | else {TACCR1 = pwm_table[0];}
113 | val--;
114 | }
115 |
116 | if(val < 0) // Encoder rechtsdrehung
117 | { // grün heller (LED1)
118 | if (pwm_index < 62)
119 | {
120 | pwm_index++;
121 | TACCR1 = pwm_table[pwm_index];
122 | }
123 | else {TACCR1 = pwm_table[63];}
124 | val--;
125 | }
126 | }
127 | }
