STM32 SPI + Timer = Fehler ?
Gast #2432604
ich habe ein Problem mit dem SPI Interface des STM32F103RC.
An SPI 1 hängt ein externes Flash und ein I/O Baustein, die sich ohne
Timer-Initialisierung problemlos ansprechen lassen.
Zusätlich habe ich den Compare Ausgang von Timer 8 (Kanal 2) in
Verwendung.
Dieser wird wie folgt eingestellt:
  TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  TIM_OCInitTypeDef  TIM_OCInitStructure;
  /* RCC configuration */
  /* TIM8 clock enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM8, ENABLE);
  /* GPIOC clock enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
  /* GPIO configuration */
  GPIO_InitTypeDef GPIO_InitStructure;
  /* GPIOC Configuration: Pin 7 as output push-pull */
  GPIO_SetBits(GPIOC, GPIO_Pin_7);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
  /* GPIOC Configuration: Pin 9 as input floating */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  /* NVIC configuration */
  NVIC_InitTypeDef NVIC_InitStructure;
  /* Enable the TIM8 Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = TIM8_CC_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
  /* Time base configuration */
  TIM_TimeBaseStructure.TIM_Period = 65535;
  TIM_TimeBaseStructure.TIM_Prescaler = PrescalerValue;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM8, &TIM_TimeBaseStructure);
  /* Output Compare Inactive Mode configuration: Channel2 */
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Timing;
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Disable;
  TIM_OCInitStructure.TIM_Pulse = TE;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
  TIM_OC2Init(TIM8, &TIM_OCInitStructure);
  TIM_OC2PreloadConfig(TIM8, TIM_OCPreload_Disable);
  TIM_ARRPreloadConfig(TIM8, ENABLE);
  /* TIM IT enable */
  TIM_ITConfig(TIM8, TIM_IT_CC2, ENABLE);
Wird diese Konfiguration aufgerufen, so passiert in vielen Fällen, dass
der MOSI Pin von SPI 1 (der auch Ausgang von Timer 8 Kanal 1 sein kann)
nach dem Reset oder Power-Up deaktiviert wird. Zugriffe auf die SPI
Peripherien funktionieren danach nicht mehr. Was mich umso mehr verwirrt
ist die Tatsache, dass es völlig zufällig ist, ob es nach einem Neustart
funktioniert oder nicht.
Kann mir vielleicht jemand einen Tipp geben, was hier schief läuft?
Vielen Dank,
Andreas
Gast #2434539
hat wirklich niemand einen Tipp für mich, was hier los sein könnte?
Ich habe die Initialisierung von SPI und Timer bereits umgedreht bzw. an
andere Teile des Programms verschoben, aber immer den gleichen Effekt
erhalten.
Vielen Dank,
Andreas
