1 | /***************************************************************************
2 | * rfm12.c
3 | *
4 | * Sun Apr 17 17:41:35 2011
5 | * Based on Firmware version 2.0.1 by Jürgen Eckert
6 | * -> http://www.mikrocontroller.net/articles/AVR_RFM12
7 | * Ported to OpenMcp by Jan Wissel
8 | * OpenMcp, by Dirk Broßwick
9 | * <sharandac@snafu.de>
10 | * for documentation see:
11 | * http://www.mikrocontroller.net/articles/RFM12
12 | ****************************************************************************/
13 |
14 | /*
15 | * This program is free software; you can redistribute it and/or modify
16 | * it under the terms of the GNU General Public License as published by
17 | * the Free Software Foundation; either version 2 of the License, or
18 | * (at your option) any later version.
19 | *
20 | * This program is distributed in the hope that it will be useful,
21 | * but WITHOUT ANY WARRANTY; without even the implied warranty of
22 | * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
23 | * GNU Library General Public License for more details.
24 | *
25 | * You should have received a copy of the GNU General Public License
26 | * along with this program; if not, write to the Free Software
27 | * Foundation, Inc., 51 Franklin Street, Fifth Floor Boston, MA 02110-1301, USA
28 | */
29 |
30 | #include <stdio.h>
31 | #include <stdlib.h>
32 | #include <string.h>
33 | #include <avr/io.h>
34 | #include <avr/interrupt.h>
35 | #include <util/delay.h>
36 | #include "hardware/spi/spi_core.h"
37 | #include "hardware/ext_int/ext_int.h"
38 | #include "hardware/led/led_core.h"
39 | #include "system/clock/clock.h"
40 | #include "config.h"
41 | #include "system/thread/thread.h"
42 |
43 | #if defined( RFM12 )
44 |
45 | #include "rfm12.h"
46 |
47 | //used by interrupt routine
48 | struct RFM12_stati RFM12_status;
49 | volatile unsigned char RFM12_Index = 0;
50 | unsigned char RFM12_Data[RFM12_DataLength+10]; // +10 == paket overhead
51 |
52 | #define RFM_PACKET_SIZE 8
53 |
54 |
55 | void rftransmit(void)
56 | {
57 | unsigned char RFMdata=0;
58 | unsigned char RFMpacket[RFM_PACKET_SIZE];
59 | unsigned char i;
60 |
61 | for(i=0;i<RFM_PACKET_SIZE;i++){
62 | RFMpacket[i]=RFMdata;
63 | RFMdata++;
64 | }
65 |
66 | if ( RFM12_txstart(RFMpacket, RFM_PACKET_SIZE) != 0 )
67 | LED_toggle(2);
68 | }
69 |
70 | void rfrecieve(void)
71 | {
72 | unsigned char RFMpacket[RFM_PACKET_SIZE], temp;
73 | int i;
74 |
75 | temp = RFM12_rxfinish( RFMpacket );
76 | if ( temp != 255 && temp != 254 )
77 | {
78 | printf_P( PSTR("RFM12 %d Bytes recieve."), temp );
79 | for ( i = 0 ; i < RFM_PACKET_SIZE ; i++)
80 | printf_P( PSTR("%02x ") , RFMpacket[ i ] );
81 | if ( RFM12_rxstart() != 0 )
82 | printf_P( PSTR("RFM12 error"));
83 | printf_P( PSTR("\r\n"));
84 | }
85 | }
86 |
87 |
88 | //interrupt service routine
89 | void RFM12_isr( void )
90 | {
91 | LED_off(7);
92 |
93 | if(RFM12_status.Rx)
94 | {
95 | if(RFM12_Index < RFM12_DataLength)
96 | {
97 | //no complete packet received, read FIFO, store in data
98 | RFM12_Data[RFM12_Index++] = RFM12_trans(0xB000) & 0x00FF;
99 | }
100 | else
101 | {
102 | //packet completely received, turn off RX
103 | RFM12_trans(0x8208);
104 | RFM12_status.Rx = 0;
105 | }
106 | if(RFM12_Index >= RFM12_Data[0] + 3)
107 | {
108 | //EOT
109 | //enough data in package?
110 | //note: will fail if Data[0] was received incorrectly
111 | //anyway, does not matter, crc will detect that.
112 | //end RX and signalize new packet
113 | RFM12_trans(0x8208);
114 | RFM12_status.Rx = 0;
115 | RFM12_status.New = 1;
116 | }
117 | }
118 | else if(RFM12_status.Tx)
119 | {
120 | //transmit next byte
121 | RFM12_trans(0xB800 | RFM12_Data[RFM12_Index]);
122 |
123 | if(!RFM12_Index)
124 | {
125 | //index=0? -> end TX
126 | RFM12_status.Tx = 0;
127 | RFM12_trans(0x8208); // TX off
128 | }
129 | else
130 | {
131 | RFM12_Index--;
132 | }
133 | }
134 | else
135 | {
136 | RFM12_trans(0x0000); //dummy read
137 | }
138 |
139 | LED_on(7);
140 | }
141 |
142 |
143 | void RFM12_init( void )
144 | {
145 | char tmp_sreg;
146 |
147 | // save SREG and diable interrupts
148 | //tmp_sreg = SREG;
149 | //cli();
150 |
151 | // CS_Pin as Output, RFM12 deselect
152 | //RFM12_CS_PORT |= (1<<RFM12_CS_PIN );
153 | //RFM12_CS_DDR |= (1<<RFM12_CS_PIN );
154 | GPIO_setdirection(GPIO_OUT,RFM12_CS_PIN);
155 | GPIO_setPin(RFM12_CS_PIN);
156 |
157 |
158 | // Interrupt-Pin as Input
159 | //RFM12_IRQ_PORT &= ~(1<<RFM12_IRQ_PIN );
160 | //RFM12_IRQ_DDR &= ~(1<<RFM12_IRQ_PIN );
161 | GPIO_clearPin(RFM12_IRQ_PIN);
162 | GPIO_setdirection(GPIO_IN,RFM12_IRQ_PIN);
163 |
164 |
165 | // SPI start
166 | SPI_init( RFM12_SPI_BUS_NUM );
167 |
168 | RFM12_trans(0xC0E0); // AVR CLK: 10MHz
169 | RFM12_trans(0x80D7); // Enable FIFO
170 | RFM12_trans(0xC2AB); // Data Filter: internal
171 | RFM12_trans(0xCA81); // Set FIFO mode
172 | RFM12_trans(0xE000); // disable wakeuptimer
173 | RFM12_trans(0xC800); // disable low duty cycle
174 | RFM12_trans(0xC4F7); // AFC settings: autotuning: -10kHz...+7,5kHz
175 |
176 | RFM12_trans(0x0000);
177 |
178 | RFM12_status.Rx = 0;
179 | RFM12_status.Tx = 0;
180 | RFM12_status.New = 0;
181 |
182 | RFM12_config();
183 | // Register RFM12 as interruptsource
184 | // EXTINT_set ( RFM12_IRQ_EXINT_NUM , SENSE_LOW , RFM12_isr );
185 |
186 | //test
187 | EXTINT_set ( &RFM12_IRQ_PORT, RFM12_IRQ_EXINT_NUM, SENSE_LOW, RFM12_isr );
188 |
189 | //SREG = tmp_sreg;
190 |
191 | // CLOCK_RegisterCallbackFunction ( rftransmit, SECOUND );
192 | }
193 |
194 | unsigned char RFM12_rxstart( void )
195 | {
196 | if(RFM12_status.New)
197 | return(1); //buffer not yet empty
198 | if(RFM12_status.Tx)
199 | return(2); //tx in action
200 | if(RFM12_status.Rx)
201 | return(3); //rx already in action
202 |
203 | RFM12_trans(0x82C8); // RX on
204 | RFM12_trans(0xCA81); // set FIFO mode
205 | RFM12_trans(0xCA83); // enable FIFO
206 |
207 | //rf12_trans(0x0000); //clear int
208 |
209 | RFM12_Index = 0;
210 | RFM12_status.Rx = 1;
211 |
212 | //MCUCR |= (1<<ISC01);
213 | //GICR |= (1<<INT0);
214 | return(0); //all went fine
215 | }
216 |
217 |
218 | unsigned char RFM12_rxfinish( unsigned char *data )
219 | {
220 | unsigned int crc, crc_chk = 0;
221 | unsigned char i;
222 |
223 | if( RFM12_status.Rx )
224 | {
225 | return( 255 ); //not finished yet
226 | }
227 |
228 | if( !RFM12_status.New )
229 | {
230 | return( 254 ); //old buffer
231 | }
232 |
233 | for( i = 0 ; i<RFM12_Data[0] + 1 ; i++ )
234 | {
235 | crc_chk = crcUpdate( crc_chk, RFM12_Data[ i ] );
236 | }
237 |
238 | crc = RFM12_Data[ i++ ];
239 | crc |= RFM12_Data[ i ] << 8;
240 | RFM12_status.New = 0;
241 |
242 | /* if( crc != crc_chk )
243 | {
244 | return( 253 ); //crc err -or- strsize
245 | }
246 | else
247 | */ {
248 | for( i = 0 ; i<RFM12_Data[ 0 ] ; i++ )
249 | {
250 | data[ i ] = RFM12_Data[ i+1 ];
251 | }
252 | return( RFM12_Data[ 0 ] ); //strsize
253 | }
254 | }
255 |
256 |
257 | unsigned char RFM12_txstart( unsigned char *data, unsigned char size )
258 | {
259 | unsigned char i, l;
260 | unsigned int crc;
261 |
262 | if( RFM12_status.Tx )
263 | {
264 | return( 2 ); //tx in action
265 | }
266 | if( RFM12_status.Rx )
267 | {
268 | return( 3 ); //rx already in action
269 | }
270 | if( size > RFM12_DataLength )
271 | {
272 | return( 4 ); //str to big to transmit
273 | }
274 |
275 | RFM12_status.Tx = 1;
276 | RFM12_Index = size + 9; //act -10
277 |
278 | i = RFM12_Index;
279 | RFM12_Data[ i-- ] = 0xAA;
280 | RFM12_Data[ i-- ] = 0xAA;
281 | RFM12_Data[ i-- ] = 0xAA;
282 | RFM12_Data[ i-- ] = 0x2D;
283 | RFM12_Data[ i-- ] = 0xD4;
284 | RFM12_Data[ i-- ] = size;
285 | crc = crcUpdate( 0 , size );
286 | for( l = 0 ; l<size ; l++ )
287 | {
288 | RFM12_Data[ i-- ] = data[ l ];
289 | crc = crcUpdate( crc, data[ l ] );
290 | }
291 | RFM12_Data[ i-- ] = (crc & 0x00FF);
292 | RFM12_Data[ i-- ] = (crc >> 8);
293 | RFM12_Data[ i-- ] = 0xAA;
294 | RFM12_Data[ i-- ] = 0xAA;
295 |
296 | RFM12_trans(0x8238); // TX on
297 | return( 0 ); //all went fine
298 | }
299 |
300 | unsigned char RFM12_txfinished( void )
301 | {
302 | if(RFM12_status.Tx)
303 | {
304 | return( 255 ); //not yet finished
305 | }
306 | return(0);
307 | }
308 |
309 | void RFM12_allstop( void )
310 | {
311 | //GICR &= ~(1<<INT0); //disable int0
312 | RFM12_status.Rx = 0;
313 | RFM12_status.Tx = 0;
314 | RFM12_status.New = 0;
315 | RFM12_trans(0x8208); //shutdown all
316 | RFM12_trans(0x0000); //dummy read
317 | }
318 |
319 | //-------------------------------------------------------------------------//
320 | // internal used initialisation functions.
321 | // usually not called from elsewhere
322 | void RFM12_config( void )
323 | {
324 | RFM12_setfreq( RFM12FREQ( 433.92 ) ); // Send/ Receivefrequenzy 433,92MHz
325 | RFM12_setbandwidth( RxBW200 , LNA_6 , RSSI_103 ); // 200kHz Bandwidth, -6dB Amplification, DRSSI threshold: -79dBm
326 | RFM12_setbaud( RFM12_BAUDRATE ); // 19200 baud
327 | RFM12_setpower( PWRdB_6 , TxBW120 ); // 1mW Power, 120kHz Frequenzyshift
328 | }
329 |
330 | void RFM12_setfreq(unsigned short freq)
331 | {
332 | if (freq<96) // 430,2400MHz
333 | {
334 | freq=96;
335 | }
336 | else if (freq>3903) // 439,7575MHz
337 | {
338 | freq=3903;
339 | }
340 | RFM12_trans(0xA000|freq);
341 | }
342 |
343 | void RFM12_setbandwidth( unsigned char bandwidth , unsigned char gain , unsigned char drssi )
344 | {
345 | RFM12_trans( 0x9400 | ((bandwidth&7)<<5) | ((gain&3)<<3) | (drssi&7) );
346 | }
347 |
348 | void RFM12_setbaud(unsigned short baud)
349 | {
350 | if ( baud<663 )
351 | {
352 | return;
353 | }
354 | if (baud<5400)
355 | {
356 | // Baudrate= 344827,58621/(R+1)/(1+CS*7)
357 | RFM12_trans( 0xC680 | ( ( 43104/baud ) -1 ) );
358 | }
359 | else
360 | {
361 | RFM12_trans( 0xC600 | ( ( 344828UL/baud ) -1 ) );
362 | }
363 | }
364 |
365 |
366 | void RFM12_setpower( unsigned char power , unsigned char mod )
367 | {
368 | RFM12_trans( 0x9800 | (power&7) | ((mod&15)<<4) );
369 | }
370 |
371 | unsigned int crcUpdate(unsigned int crc, unsigned char serialData)
372 | {
373 | unsigned int tmp;
374 | unsigned char j;
375 |
376 | tmp = serialData << 8;
377 |
378 | for (j=0; j<8; j++)
379 | {
380 | if((crc^tmp) & 0x8000)
381 | {
382 | crc = (crc<<1) ^ 0x1021;
383 | }
384 | else
385 | {
386 | crc = crc << 1;
387 | }
388 | tmp = tmp << 1;
389 | }
390 | return crc;
391 | }
392 |
393 | //-------------------------------------------------------------------------//
394 | // hardware level functions
395 | unsigned int RFM12_trans( unsigned int CMD )
396 | {
397 | char tmp_sreg;
398 | int retval;
399 | CONVERTW val;
400 |
401 | val.w = CMD;
402 |
403 |
404 | //save SReg, clear Interrupts
405 | // tmp_sreg = SREG;
406 | // cli();
407 |
408 | RFM12_select();
409 |
410 | //retval = ( SPI_ReadWrite( RFM12_SPI_BUS_NUM , ( CMD>>8 ) & 0xff ) ) << 8 ;
411 |
412 | // TODO SP
413 | //SPDR = val.b[1];
414 | //while(!(SPSR & (1<<SPIF)));
415 | //val.b[1]=SPDR;
416 |
417 | val.b[0] = SPI_ReadWrite( RFM12_SPI_BUS_NUM , ( CMD>>8 ) & 0xff );
418 |
419 | // retval |= SPI_ReadWrite( RFM12_SPI_BUS_NUM , CMD & 0xff );
420 | // TODO SP
421 | //SPDR = val.b[0];
422 | //while(!(SPSR & (1<<SPIF)));
423 | //val.b[0]=SPDR;
424 |
425 | val.b[1] = SPI_ReadWrite( RFM12_SPI_BUS_NUM , CMD & 0xff );
426 |
427 | RFM12_deselect();
428 |
429 | // restore interrupts
430 | // SREG = tmp_sreg;
431 |
432 | return( val.b[0]+(val.b[1] <<8));
433 | }
434 |
435 | void RFM12_select( void ){
436 |
437 | //RFM12_CS_PORT &= ~( 1<<RFM12_CS_PIN );
438 | GPIO_clearPin(RFM12_CS_PIN);
439 | }
440 |
441 | void RFM12_deselect( void ){
442 |
443 | //RFM12_CS_PORT |= ( 1<<RFM12_CS_PIN );
444 | GPIO_setPin(RFM12_CS_PIN);
445 | }
446 |
447 |
448 | void RFM12_printStatus(){
449 | //int ret = RFM12_trans(0x00);
450 | RFM12_select();
451 | //char i1 = SPI_ReadWrite(1,0x00);
452 | //char i2 = SPI_ReadWrite(1,0x00);
453 | int i = 0;
454 | i = RFM12_trans(0x0000);//i1 + (i2<<8);
455 | RFM12_deselect();
456 |
457 |
458 | printf("Status: 0b");
459 | for (int j = 0; j<16; j++){
460 | printf("%u",(i%2));
461 | i/=2;
462 | }
463 | printf("\r\n");
464 | }
465 |
466 | #endif
