Ich habe ein Porblem mit der SPI Kommunikation!!! ATMega16 -> MCP41010 MOSI -> SI SCK -> SCK SS -> CS(inv.) Mein Code: #include <stdlib.h> #include <avr/io.h> #include <avr/interrupt.h> #include <avr/signal.h> #include <avr/pgmspace.h> #include <util/delay.h> #include "uart.h" #include "ADC.h" /* define CPU frequency in Mhz here if not defined in Makefile */ #ifndef F_CPU #define F_CPU 16000000UL #endif /* 9600 baud */ #define UART_BAUD_RATE 9600 void adc(char mux) { int ad = ADC_Read(mux); char buffer[10]; itoa(ad,buffer,10); uart_puts(buffer); uart_puts("\n\r"); return; } void spi_init(void) { SPCR|=(1<<SPE)|(1<<MSTR)|(1<<SPR1)|(1<<SPR0); //SPI enable, Master, Freq/128; } void spi_write(char data) { PORTB |= (1<<PB4); //CS high SPDR = 0x11; // 11 für write und pot1 SPDR = data; PORTB &= ~(1<<PB4); //CS low } int main(void) { DDRD &=~((1<<PD2)|(1<<PD3)|(1<<PD4)); DDRA = 0x00; DDRD|=(1<<PD7)|(1<<PD6)|(1<<PD5); DDRB |= (1<<PB5)|(1<<PB7); //MOSI u SCK als OUTPUT DDRB |= (1<<PB4); // SS als OUTPUT uart_init( UART_BAUD_SELECT(UART_BAUD_RATE,F_CPU)); ADC_Init(); spi_init(); sei(); while (1) { int read = uart_getc(); if (read==48) adc(0); if (read==49) adc(1); if (read==50) adc(2); if (read==51) adc(3); if (read==52) adc(4); if (read==53) adc(5); if (read==54) adc(6); if (read==55) adc(7); if (PIND &(1<<PD2)) spi_write(0xFF); //255 else spi_write(0x50); // 80 _delay_ms(1000); } } Kann mir jemand sagen was ich falsch mache??? Der wert des potis verändert sich nicht!!!
