Forum: FPGA, VHDL & Co. Connecting multiply models to an output bus.
von Bence (Gast)
There are a 32 bit output bus, which is connected to two modules.
There is a 5 bit Address bus, and a read signal controlled by bus
master.
The task is to have 2 readable registers on the bus, with address 1 and
2, and data 1 and 2.
The problem is, that if both is in one process,
then it works, and if they are in different processes (does not matter,
if in different file, or in the same file), they does not work.
--Works:
  Decode: process(read)
    begin
      outbus <= (others => 'Z');
      if read = '1' then
        if A(10 downto 5) = "000001" then
          outbus <= x"00000001";
        end if;
        if A(10 downto 5) = "000010" then
          outbus <= x"00000002";
        end if;
      end if;
    end process;
--Does Not work:
  begin
    if read = '1' then
      end if;
    end if;
  end process;
Decode2: process(read)
  begin
    if read = '1' then
      end if;
    end if;
  end process;
Any help would be highly appreciated.
Thank You,
Bence
von PittyJ (Gast)
In the first process (which should work), I would have used an else:
        elsif A(10 downto 5) = "000010" then
        end if;
The second processes: As far as I know, this should not work because
only one process may drive an output signal. (But I might be wrong)
von Duke Scarring (Gast)
You could use tristate busses. But I can't really recommend this:
  begin
    outbus1 <= (others => 'Z');
    if read = '1' then
        outbus1 <= x"00000001";
      end if;
    end if;
  end process;
  begin
    outbus2 <= (others => 'Z');
    if read = '1' then
        outbus2 <= x"00000002";
      end if;
    end if;
  end process;
  outbus <= outbus1 or outbus2;
This will be replaced on synthesis by an multiplexer. So you can do this
replacement by your own.
Duke
