Serielle Schnittstelle in Visual Basic 2005
OP #2544997
Code für Visual Basic Express 2005:
Const COM_PORT As String = "COM9"
    Dim PufferString As String
    Private Delegate Sub DelegateSub()
    Private Datenanzeigen As New DelegateSub(AddressOf Anzeigen)
    Private Sub Form1Load(ByVal sender As System.Object, ByVal e As
System.EventArgs) _
                                Handles MyBase.Load
        Dim EinzelPort As String
        Debug.WriteLine("INFO: Folgende Ports wurden auf dem System
gefunden:")
        For Each EinzelPort In My.Computer.Ports.SerialPortNames
            Debug.WriteLine(EinzelPort)
        Next EinzelPort
        With SerialPort1
            If Not .IsOpen Then
                Try
                    '.PortName = COM_PORT
                    '.BaudRate = 57600
                    '.DataBits = 8
                    '.WriteTimeout = 2000                        ' 1000
ms = 1 Sek.
                    '.ReadTimeout = 2000                         ' 1000
ms = 1 Sek.
                    '.Handshake = IO.Ports.Handshake.None
                    '.ReceivedBytesThreshold = 1
                    .NewLine = vbCr
                    .Open()
                    Debug.WriteLine("Port Open: " & SerialPort1.IsOpen)
                Catch ex As Exception
                    MessageBox.Show(ex.Message, "Fehler beim Open", _
                                    MessageBoxButtons.OK,
MessageBoxIcon.Error)
                    Exit Sub
                End Try
            End If
        End With
        TextBox1.Multiline = True
        TextBox1.ScrollBars = ScrollBars.Both
    End Sub
    Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As
System.EventArgs) _
                                Handles Button1.Click
        Try
            PufferString = ""
            SerialPort1.WriteLine(TextBox1.Text)
            MessageBox.Show(ex.Message, "Fehler beim Senden ...")
            Exit Sub
        End Try
        Debug.WriteLine("Daten übermittelt!")
        TextBox1.Text = ""
    End Sub
    Private Sub SerialPort1_DataReceived(ByVal sender As Object, _
                                ByVal e As
System.IO.Ports.SerialDataReceivedEventArgs) _
                                Handles SerialPort1.DataReceived
'hier
        Dim response As String
        Try
            'TextBox1.Text = TextBox1.Text & SerialPort1.ReadExisting
            response = SerialPort1.ReadExisting
            Debug.WriteLine(response)
            PufferString &= response
            If PufferString.EndsWith("]") Then
                'event auslösen
            End If
            MessageBox.Show(ex.Message, "Fehler beim Empfangen ...")
        End Try
    End Sub
    Private Sub Anzeigen()
        Label1.Text = PufferString
    End Sub
    Private Sub Form1_FormClosing(ByVal sender As Object, _
                                ByVal e As
System.Windows.Forms.FormClosingEventArgs) _
                                Handles Me.FormClosing
        If SerialPort1.IsOpen Then SerialPort1.Close() ' Port wieder
Schließen
    End Sub
    Private Sub Button2_Click(ByVal sender As System.Object, ByVal e As
System.EventArgs) Handles Button2.Click
        Anzeigen()
    End Sub
    Private Sub Button3_Click(ByVal sender As System.Object, ByVal e As
System.EventArgs) Handles Button3.Click
        Try
            PufferString = ""
            SerialPort1.WriteLine("XGO")
            Exit Sub
        End Try
        TextBox1.Text = ""
    End Sub
..und die Eigenschaften:
unter serial_port :
                   -DtrEnable auf "True"
                   -RtsEnable auf "True"
Gruß Moritz
