2SB1116 datasheet 2SB1116 price 2SB1116 data 2SB1116 ic NEC PNP SILICON TRANSISTORS 2SB1116, 2SB1116A DESCR IPTION The 2SB1 1 16/2SB1 1 16A are designed for use in driver and output stages of AF amplifier, general purpose application. PACKAGE DIMENSIONS in millimeters 5.2 MAX. FEATURES • Low Collector Saturation Voltage. VCE(sat) = —0.20 V TYP. (Ic = —1.0 A, lB = —50 mA) • High Break Down Voltage. VCEO =—50 V/—60V (2SB1116/2SB1116A) • High Total Power Dissipation. : = 0.75 W (Ta = 25 °C) • Complementary to the NEC 2SD1616/2SD1616A NPN Transistor. ABSOLUTE MAXIMUM RATINGS Maximum Temperatures Storage Temperature Junction Temperature Maximum Power Dissipation (Ta = 25 °C) Total Power Dissipation —55to+150°C 150 C Maximum Maximum Voltages and Currents (Ta = 25 °C) VCBO Collector to Base Voltage VCEO Collector to Emitter Voltage VEBO Emitter to Base Voltage IC Collector Current (DC) Ic Collector Current (pulse)* •PW 10 ms, Duty Cycle 50 % ELECTRICAL CHARACTERISTICS (Ta = 25°C) 2SB1 11 6/2SB1 1 16A —60 V/—80 V —50V/—60V 1 2 3 r.-j 1. Emitter EIAJ : SC-43B 2. Collector JEDEC : TO-92 3. Base 1EC : PA33 2S81 116/2SB1 1 16A hFE1 ** CHARACTER ISTIC DC Current Gain DC Current Gain TYP. MAX. UNIT TEST CONDITIONS VCE = 2.0 V. IC = —100 mA VCE = —2.0 V. IC —1.0 A ‘EBO VBE** V CE (sat ) ** VBE(sat) ton tstg Gain Bandwidth Product Output Capacitance Collector Cutoff Current Emitter Cutoff Current Base to Emitter Voltage Collector Saturation Voltage Base Saturation Voltage Turn-On Time Storage Time MHz pF —100 nA —100 nA —700 mV —1.2 V Ps VCE = —2.0 V. ‘C = —100 mA VCB = —10 V. E = 0, f = 1.0 MHz VCB = —60 VI—80 V. ‘E 0 VEB = —6.0 V, IC = 0 VCE = —2.0 V. Ic = —50 mA ‘c—l•O A, IB—5OmA Jc = —1.0 A, lB = —50 mA /VCC= —10 V, I= —100 mA 1B1=—IB2—lOmA tf Fall Time **Pulsed PW 350 ps, Duty Cycle 2 % C lassification of hFE1 Rank L K U Range 135to270 200to400 300to600 Test Conditions: VCE —2.0 V, IC = —100 mA P5 \VBE(off) = 2to3 V 2SB1116,2SB1116A NEC TYPICAL CHARACTERISTICS (Ta = 25°C) TOTAL POWER DISSIPATION vs. AMBIENT TEMPERATURE JFree Airj SAFE OPERATING AREAS (TRANSIENT THERMAL RESISTANCE METHOD) tI[1[IIt I I[I1 COLLECTOR CURRENT vs. COLLECTOR TO EMITTER VOLTAGE ‘ _200 J —60 —150 jzA 25 50 75 100 125 150 Ta—Ambient Temperature—C I =—5OuA 0 —2 —4 —6 —8 —10 VCE—Collector to Emitter Voltage—V COLLECTOR CURRENT vs. COLLECTOR TO EMITTER VOLTAGE —1 —2 —5 —10—20 —50—100 VCE—Collector to Emitter Voltage—V DC CURRENT GAIN vs. > COLLECTOR CURRENT 1000 > COLLECTOR AND BASE SATURA TION VOLTAGE vs. COLLECTOR CURRENT VCE—2.OV —2 11 [11111 I -{ f[EIIfj lC=2O•IB I —0.8 —3.0 mA .E 200 VBE(sot) . ——2.5 mA— —2.0 mA —1.5 mA -1.0 mA 2-0.2 IB=—O.5 mA LIJ U -0.1 till 0.05 —(- uj,IliI —0.01—0.02 -0.05—0.1—0.2 —0.5—1 —2 0 —0.2 —0.4 —0.6 —0.8 —1.0 —0.01—0.02 —0.05—0.1 —0.2 —0.5—1 —2 —5 —10 >> IC—Collector Current—A VCE—Collector to Emitter Voltage—V IC—Collector Current—A GAIN BANDWIDTH PRODUCT vs. EMITTER CURRENT OUTPUT CAPACITANCE vs. COLLECTOR TO BASE VOLTAGE SWITCHING TIME vs. COLLECTOR CURRENT 1.11000 -t VCE—2.OV 1 HI H1[ 1=1.0 MHz 2 Vyotf)= 2 to 3 V PW2 gS 1 Duty CycIe2 % 0 Cu 0.5 tstg 0 o.1f411 ‘LL 111JJ1Nl —0.01—0.02—0.05 —0.1 —0.2 —0.5 —1 —2 —5—10 IC—Collector Current—A —1 —2 —5 —10 —20 —50—10 VCB—Collector to Base Voltage—V —0.01 —0.02 —0.05 —0.1 —0.2 —0.5 —1 IC—Collector Current—A
Verschoben durch Moderator
