2SB1015 price 2SB1015 for sale 2SB1015 data TOSHIBA TRANSISTOR SILICON PNP TRIPLE DIFFUSED TYPE 2SB1015A AUDIO FREQUENCY POWER AMPLIFIER APPLICATIONS Unit in mm Low Collector Saturation Voltage : V。E (sat) = —1.7 V (Max.) (IC = 一 3A,IB = 一 0.3 A) 10 + 0.3 _ £3.2 ±0.2 2.7±0.2 Collector Power Dissipation : Pq = 25W(Tc = 25。C) 0.75±0.15 2.54±0.25 2.54 + 0.25 COLLECTOR EMITTER EIAJ SC-67 TOSHIBA 2-10R1A MAXIMUM RATINGS (Ta = 25°C) CHARACTERISTIC SYMBOL RATING Collector-Base Voltage Collector-Emitter Voltage Emitter-Base Voltage Collector Current Base Current Collector PowerDissipation Ta = 25°C Tc = 25°C Junction Temperature Storage Temperature Range -55 〜150 961001EAA1 TOSHIBA is continually working to improve the quality and the reliability of its products. Nevertheless, semiconductordevices in general can malfunction or fail due to their inherent electrical sensitivity and vulnerability to physical stress.It is the responsibility of the buyer, when utilizing TOSHIBA products, to observe standards of safety, and to avoidsituations in which a malfunction or failure of a TOSHIBA product could cause loss of human life, bodily injury ordamage to property. In developing your designs, please ensure that TOSHIBA products are used within specifiedoperating ranges as set forth in the most recent products specifications. Also, please keep in mind the precautionsand conditions set forth in the TOSHIBA Semiconductor Reliability Handbook. The information contained herein is presented only as a guide for the applications of our products. No responsibilityis assumed by TOSHIBA CORPORATION for any infringements of intellectual property or other rights of the thirdparties which may result from its use. No license is granted by implication or otherwise under any intellectualproperty or other rights of TOSHIBA CORPORATION or others. The information contained herein is subject to change without notice. ELECTRICAL CHARACTERISTICS (Ta = 25°C) CHARACTERISTIC SYMBOL TEST CONDITION Collector Cut-off Current VCB = -60 V, Ie = 0 Emitter Cut-off Current VEB= -7V, IC = 0 Collector-EmitterBreakdown Voltage V (BR) CEO IC = -50 mA, Ib = 0 DC Current Gain hFE(l)(Note) VCE = -5V, Ic = -0.5 A hFE (2) VCE= -5V, IC= -3A Collector-EmitterSaturation Voltage VCE (sat) IC = -3 A, IB = -0.3 A Base-Emitter Voltage VCE = -5 A, Ic = -0.5 A Transition Frequency VCE = -5V, Ic = -0.5 A Collector Output Capacitance VCB = -10 V,IE = 0,f = 1 MHz SwitchingTime Turn-on Time NIIB2 ib1 outputTbiIL input ^^^ Vcc = -30 V -IB1 = IB2 = 0.2 A,DUTY CYCLE ^ 1% Storage Time Fall Time (Note) : hFE (l) Classification O : 60〜120,Y : 100〜200 COMMONEMITTERTc = 25°C Ic 一 VCE I^syHno ^OSSJOO COLLECTOR-EMITTER VOLTAGE VqE (V) COMMON EMITTER Vr.F.= hFE 一 IC o o o o o o o 55 3 1 a』q 之 XNaHHno Ic 一 VBE BASE-EMITTER VOLTAGE VRE (V) (V) 01HM3D5D5no ば olQanoo VCE (sat) 一 IC -0.1 -0.3 -1 -3 -5 II I 三三 I \\\l.02 丄石ぷ 1' 5 2-0 || lo.o (A) lwo> aoVJ/IOA NOIHVHnHvs 20-0.02 COLLECTOR CURRENT In (A) COLLECTOR CURRENT In (A) SAFE OPERATING AREA Rth ⑴ 一 tw ⑴ WITHOUT HEAT SINK (9) TNFTNTTF, HF.AT STNK ⑴ Ta = 9E°C ^9^ tv> — 9K°r, 10"3 10"2 10"1 1 10 102TIME t (s) (V) 01HM3D5D5no ば olQanoo (M/o。) s J | | | | | I I I I II-IQ MAX. (PULSED) X '10 ms》 '100 msX〜※ I I I I I I I I I I I I IQ MAX. (CONTINUOUS) DC OPERATc = 25c i i i i i ^ SINGLE NONREPETITIVE PULSE Tc - 25°CCURVES MUST BE DERATEDLINEARLY WITH INCREASEIN TEMPERATURE. \ -1 -3 -10 -30 -100 COLLECTOR-EMITTER VOLTAGE VqE (V)
Verschoben durch Moderator
