Hallo, Ich verwende eine Eigenbauplatine mit einem m32 und dem ENC28J60. SerialComm OK dann die Config scheint OK zu sein, er weist die IP NM etc. zu System Ready Compiliert am Mar 26 2012 um 09:37:56 Compiliert mit GCC Version 4.5.3 NIC init:enc revid 6 My IP: 192.168.1.120 TCP Anwendung wird in Liste eingetragen: Eintrag 0 TCP Anwendung wird in Liste eingetragen: Eintrag 1 IP 192.168.1.120 MASK 255.255.255.0 GW 192.168.1.1 enc_receive: EPKTCNT=1 enc_receive: 250 bytes UDP Keine Anwendung gefunden! enc_receive: EPKTCNT=1 enc_receive: 600 bytes UDP Keine Anwendung gefunden! und wenn ich ihn pinge kommt enc_receive: EPKTCNT=1 enc_receive: 60 bytes enc_receive: EPKTCNT=1 enc_receive: 60 bytes enc_receive: EPKTCNT=1 enc_receive: 60 bytes enc_receive: EPKTCNT=1 enc revid 6 enc_receive: 600 bytes enc_receive: EPKTCNT=1 enc_receive: 60 bytes enc_receive: EPKTCNT=1 enc_receive: 60 bytes enc_receive: EPKTCNT=1 enc_receive: 60 bytes enc_receive: EPKTCNT=1 enc_receive: 60 bytes enc_receive: EPKTCNT=1 enc_receive: 60 bytes enc_receive: EPKTCNT=1 enc_receive: 60 bytes enc_send: 60 bytes enc_receive: EPKTCNT=1 enc_receive: 60 bytes enc_receive: EPKTCNT=0 enc_receive: EPKTCNT=1 enc_receive: 90 bytes UDP Keine Anwendung gefunden! enc_receive: EPKTCNT=1 enc_receive: 60 bytes enc_send: 60 bytes enc_receive: EPKTCNT=1 enc_receive: 60 bytes enc_receive: EPKTCNT=1 enc_receive: 60 bytes enc_receive: EPKTCNT=1 enc revid 6 enc_receive: 600 bytes enc_receive: EPKTCNT=1 enc_receive: 60 bytes enc_receive: EPKTCNT=1 enc_receive: 60 bytes enc_send: 60 bytes enc_receive: EPKTCNT=1 enc_receive: 60 bytes enc_send: 60 bytes enc_receive: EPKTCNT=1 enc_receive: 60 bytes enc_send: 60 bytes enc_receive: EPKTCNT=1 enc_receive: 60 bytes enc_receive: EPKTCNT=1 enc revid 6 enc_receive: 60 bytes enc_receive: EPKTCNT=1 enc_receive: 60 bytes enc_receive: EPKTCNT=1 enc_receive: 60 bytes enc_receive: EPKTCNT=1 enc_receive: 60 bytes enc_send: 60 bytes enc_receive: EPKTCNT=1 enc_receive: 600 bytes enc_receive: EPKTCNT=1 enc revid 6 enc_receive: 252 bytes irgendwo da drin kommt ein enc_send: 60 bytes wenn ich aber das Osci an die TPOut pins halte hab ich nur 3.3V mit ca. 0.1V Ripple drauf der TPIn- geht mit etwa 0.4V im Takt des Pings mit ein bisschen verwunderlich ist das am Pin VDDRX nur 1.7V anliegen obwohl er an 3.3V angeschlossen ist mit einem C 100n nach Gnd Muss das so sein? Ich bin erst dabei den ENC kennen zu lernen. Ju PS: wenn ich auf dem PC arp ausfuehre bekomme ich ein HWaddress incomplete jgnoss@maverick:~$ arp Address HWtype HWaddress Flags Mask Iface 192.168.1.120 (incomplete) eth0 192.168.1.100 ether 00:21:00:aa:c1:22 C eth0 192.168.1.1 ether 00:1d:0f:fc:19:bc C eth0
