1 | #include <avr/io.h>
2 | #include <util/delay.h>
3 | #include <math.h>
4 | #include <avr/pgmspace.h>
5 |
6 | uint16_t pwmtable[32] PROGMEM = {0, 1, 2, 2, 2, 3, 3, 4, 5, 6, 7, 8, 10, 11,
7 | 13, 16, 19, 23, 27, 32, 38, 45, 54, 64, 76,
8 | 91, 108, 128, 152, 181, 215, 255};
9 |
10 |
11 | int main(void)
12 | {
13 | DDRD = 0xFF; //Alles auf Ausgang
14 | DDRB = 0xFF; //Alles auf Ausgang
15 | PORTD = 0x00;
16 | PORTD = 0x00;
17 | DDRA = 0x00;
18 | PORTA = 0x00;
19 |
20 | uint8_t valuered = 0;
21 | uint8_t valueblue = 0;
22 | uint8_t valuegreen = 0;
23 | uint8_t adcvalue = 0;
24 | uint8_t step = 1;
25 | uint8_t stepsize = 1;
26 |
27 | // PWM 0
28 | // 8-bit PWM, Phase correct
29 | // 8 bits give us 256 levels of brightness
30 | TCCR0A |= (1<<WGM00);
31 |
32 | // Clear OC0A/OC0B on Compare Match
33 | // Set OC0A/OC0B at BOTTOM (non-inverting mode)
34 | TCCR0A |= (1<<COM0A1);
35 |
36 | // Set prescaler to 8
37 | // 1 MHz / 8*256 = ~490 Hz PWM frequency
38 | TCCR0B |= (1<<CS01);
39 |
40 |
41 | // PWM 1
42 |
43 | // 8-bit PWM, Phase correct
44 | // 8 bits give us 256 levels of brightness
45 | TCCR1A |= (1<<WGM10);
46 |
47 | // Clear OC0A/OC0B on Compare Match
48 | // Set OC0A/OC0B at BOTTOM (non-inverting mode)
49 | TCCR1A |= (1<<COM1A1);
50 |
51 | // Set prescaler to 8
52 | // 1 MHz / 8*256 = ~490 Hz PWM frequency
53 | TCCR1B |= (1<<CS11);
54 |
55 | while(1)
56 | {
57 |
58 | if(adcvalue = 191)adcvalue=0;
59 | adcvalue++;
60 |
61 | if(adcvalue<32){
62 | valuered = 32;
63 | valueblue = 0;
64 | valuegreen = adcvalue;
65 | }
66 | if(31<adcvalue<64){
67 | valuered = 32 - adcvalue;
68 | valueblue = 0;
69 | valuegreen = 32;
70 | }
71 | if(63<adcvalue<96){
72 | valuered = 0;
73 | valueblue = adcvalue;
74 | valuegreen = 32;
75 | }
76 | if(95<adcvalue<128){
77 | valuered = 0;
78 | valueblue = 32;
79 | valuegreen = 32 - adcvalue;
80 | }
81 | if(127<adcvalue<160){
82 | valuered = adcvalue;
83 | valueblue = 32;
84 | valuegreen = 0;
85 | }
86 | if(159<adcvalue<192){
87 | valuered = 32;
88 | valueblue = 32 - adcvalue;
89 | valuegreen = 0;
90 | }
91 |
92 | OCR1A = pwmtable[valuered];
93 | OCR1B = pwmtable[valuegreen];
94 | OCR0A = pwmtable[valueblue];
95 | _delay_ms(40);
96 | }
97 |
98 | return 0;
99 | }
