1 | #ifndef F_CPU
2 | #define F_CPU 8000000UL
3 | #endif
4 |
5 | #include <avr/io.h>
6 | #include <util/delay.h>
7 |
8 | #define I2C_DDR DDRC // Register für die I2C Kommunikation
9 | #define I2C_DDR_REG_BIT DDC7 //
10 | #define I2C_PORT PORTC // I2C Port definition
11 |
12 | #define SCL PC6 // Port C Pin 6
13 | #define SDA PC7 // Port C Pin 7
14 |
15 | #define SDA_LESE_PIN PINC
16 | #define SDA_LESE_BIT SDA
17 |
18 | /*~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~*/
19 | void sda_low()
20 | {
21 | I2C_PORT &= ~(1<<SDA); // internen Pull-Up aus
22 | I2C_DDR |= (1<<I2C_DDR_REG_BIT); // Pin von SDA als Ausgang
23 |
24 | }
25 | /*~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~*/
26 | void sda_high()
27 | {
28 | I2C_DDR &= ~(1<<I2C_DDR_REG_BIT); // Pin von SDA als Eingang
29 | I2C_PORT |= (1<<SDA); // internen Pull-Up an
30 | }
31 | /*~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~*/
32 | ////////////////////////////////////////////////////////////////////////////////////////////
33 |
34 | #define I2C_SCL_LOW I2C_PORT &= ~(1 << SCL) // Clock Low Output
35 | #define I2C_SCL_HIGH I2C_PORT |= (1 << SCL) // Clock High Output
36 |
37 | #define I2C_SDA_LOW sda_low() // Daten Leitung Low
38 | #define I2C_SDA_HIGH sda_high() // Daten Leitung High
39 |
40 | #define ACK 0 // Ack empfangen
41 | #define NACK 1 // Ack nicht empfangen
42 |
43 | #define S_DELAY _delay_loop_1(1); // ca. 2.76µs H-Time
44 | #define M_DELAY _delay_us(1);
45 | #define DELAY _delay_ms(1);
46 |
47 | /*~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~*/
48 | unsigned char i2c_try_scl(unsigned char start_trials)
49 | {
50 | // 10 Mal kurz warten, wenn SCL auf LOW gehalten wird
51 | while((!SCL) && (start_trials <50))
52 | {
53 | start_trials++;
54 | S_DELAY;
55 | }
56 | if(!SCL) return 0 ; return 1;
57 | }
58 |
59 | void i2c_master_stop(void);
60 | /*~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~*/
61 |
62 | ////////////////////////////////////////////////////////////////////////////////////////////
63 | // I2C-Master Interface Standard Routinen
64 | ////////////////////////////////////////////////////////////////////////////////////////////
65 | void i2c_master_init(void)
66 | {
67 | I2C_DDR |= (1<<SCL); // SCL Leitung als Ausgang definieren
68 | S_DELAY;
69 | I2C_SCL_HIGH; // Cockleitung auf H setzen
70 | I2C_SDA_HIGH; // Datenleitung auf H setzen
71 | S_DELAY; // kurz warten
72 | i2c_master_stop();
73 | }
74 | /*~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~*/
75 | void i2c_master_clk_toggle(void)
76 | {
77 | i2c_try_scl(0x0A);
78 |
79 | I2C_SCL_HIGH;
80 | S_DELAY;
81 | S_DELAY;
82 | I2C_SCL_LOW;
83 | S_DELAY;
84 | }
85 | /*~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~*/
86 | void i2c_master_start(void){
87 | // Übergang von H->L auf SDA, wobei SCL H ist.
88 | i2c_try_scl(0x0A);
89 |
90 | I2C_SDA_HIGH; // SDA vorsichtshalber auf HIGH ziehen
91 | // S_DELAY;
92 | I2C_SCL_HIGH; // SCL auf High
93 | S_DELAY;
94 | I2C_SDA_LOW; // SDA auf Low ziehen
95 | M_DELAY;
96 | M_DELAY;
97 | M_DELAY;
98 | I2C_SCL_LOW; // SCL auf low
99 | S_DELAY;
100 | }
101 | /*~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~*/
102 | void i2c_master_stop(void)
103 | {
104 | // Übergang von L->H auf SDA, wobei SCL H ist.
105 | i2c_try_scl(0x0A);
106 | S_DELAY;
107 | I2C_SDA_LOW; // SDA vorsichtshalber auf LOW ziehen
108 | S_DELAY; // Kurz abwarten
109 | I2C_SCL_HIGH; // SCL auf High setzen
110 | S_DELAY;
111 | I2C_SDA_HIGH; // SDA von L auf H ziehen
112 | S_DELAY;
113 | }
114 | /*~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~*/
115 | unsigned char i2c_master_write(unsigned char b)
116 | {
117 | char i=0;
118 | for(i=0;i<8;i++)
119 | {
120 | if (b & 0x80) // Wenn höchstes Bit=1
121 | {
122 | I2C_SDA_HIGH;
123 | }
124 | else // Wenn höchstes Bit=0
125 | {
126 | I2C_SDA_LOW;
127 | }
128 | b=b<<1; // Daten Linksshift
129 | S_DELAY;
130 | i2c_master_clk_toggle();
131 | }
132 | // Auf ACK vom Slave Prüfen
133 | I2C_SDA_HIGH;
134 | i2c_master_clk_toggle();
135 | if(SDA==1)
136 | {
137 | return 0;
138 | }
139 | else
140 | {
141 | return 1;
142 | }
143 | }
144 | /*~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~*/
145 | unsigned char i2c_master_read(unsigned char a)
146 | {
147 | unsigned char i,c=0b00000000;
148 | I2C_SDA_HIGH;
149 |
150 | for(i=0;i<8;i++)
151 | {
152 | c=c<<1;
153 |
154 | // Bitweise OR verknüpfen mit dem Eingang, MSB zuerst
155 | if(SDA_LESE_PIN & (1 << SDA_LESE_BIT)) c|=1;
156 | i2c_master_clk_toggle();
157 | }
158 |
159 | // ACK oder NACK | ACK=0; NACK=1
160 | if(a==ACK) {I2C_SDA_LOW;} else {I2C_SDA_HIGH;}
161 | i2c_master_clk_toggle();
162 | return c;
163 | }
164 |
165 |
166 | int main(void)
167 | { DDRD=0b00000000;
168 | DDRB=0b11111111;
169 | uint8_t low_byte=0b00001000;
170 |
171 | while(1)
172 | {
173 | switch(PIND){
174 | case 0b11111110:
175 | PORTB=0b00000000;
176 | i2c_master_start();
177 | i2c_master_write(0xE0);
178 | i2c_master_write(0x00);
179 | i2c_master_write(0x51);
180 | i2c_master_stop();
181 | break;
182 |
183 | case 0b11111101:
184 | i2c_master_start();
185 | i2c_master_write(0xE0);
186 | i2c_master_write(0x03);
187 | i2c_master_stop();
188 | i2c_master_start();
189 | i2c_master_write(0xE1);
190 | low_byte=i2c_master_read(1);
191 | i2c_master_stop();
192 | break;
193 |
194 | case 0b11011111:
195 | PORTB=low_byte;
196 | break;
197 |
198 | default:
199 | PORTB=0b11111111;
200 |
201 |
202 | }
203 | }
204 |
205 | }
