1 | #include "stm32f4xx.h"
2 |
3 | volatile unsigned int counter = 0;
4 | volatile uint16_t arr[500];
5 |
6 | /* Private macro */
7 | /* Private variables */
8 | void Delay(__IO uint32_t nCount);
9 | /* Private function prototypes */
10 | void setup_gps(void);
11 | void setup_pc(void);
12 | void setup_led(void);
13 | void setup_exti_line0(void);
14 |
15 | void setup_i2c();
16 | void write_LSM303DLH(uint8_t adr, uint8_t * data, uint8_t lenght,
17 | uint8_t offset);
18 | void read_LSM303DLH(uint8_t adr, uint8_t * data, uint8_t lenght, uint8_t index);
19 | /* Private functions */
20 |
21 | /**
22 | **===========================================================================
23 | **
24 | ** Abstract: main program
25 | **
26 | **===========================================================================
27 | */
28 | int main(void) {
29 | SystemInit();
30 |
31 | int i = 0;
32 |
33 | uint64_t adr = 0x080E0000;
34 |
35 | /*uint64_t def = *((uint64_t*)0x1FFF7A10);
36 |
37 | uint64_t read_data = *((uint64_t*)adr);
38 |
39 | *((uint64_t*)adr) = 0x00000000;
40 |
41 | uint64_t read_data2 = *((uint64_t*)adr);*/
42 | setup_gps();
43 | setup_pc();
44 | setup_led();
45 | setup_exti_line0();
46 | setup_i2c();
47 |
48 | Delay(0x3FFFFF);
49 |
50 | ///////////////////////////////////////////////////////////////////////////////
51 | /*uint8_t t[] = { 0x02, 0x00 };
52 | write_LSM303DLH(MAG_ADDRESS, t, 2, 0);
53 | t[0] = 0x00;
54 | t[1] = (1 << 3) | (1 << 4);
55 | write_LSM303DLH(MAG_ADDRESS, t, 2, 0);
56 | Delay(0x3FFFFF);
57 | t[0] = 0x20;
58 | t[1] = 0x27;
59 | write_LSM303DLH(ACC_ADDRESS, t, 2, 0);
60 | Delay(0x3FFFFF);
61 | uint8_t out[] = { 0, 0, 0, 0, 0, 0, 0 };
62 | read_LSM303DLH(MAG_ADDRESS, out, 6, 0x03);
63 | int x = 0, y = 0, z = 0;
64 | x = (out[0] << 8 | out[1]);
65 | y = (out[2] << 8 | out[3]);
66 | z = (out[4] << 8 | out[5]);*/
67 |
68 | while (I2C_GetFlagStatus(I2C2, I2C_FLAG_BUSY) == SET) {
69 | ;
70 | }
71 |
72 | I2C_GenerateSTART(I2C2, ENABLE);
73 | while (!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_MODE_SELECT) == SET) {
74 | ;
75 | }
76 |
77 | I2C_Send7bitAddress(I2C2, 0xAA >> 1, I2C_Direction_Transmitter);
78 | while (!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED)
79 | == SET) {
80 | ;
81 | }
82 |
83 | I2C_SendData(I2C2, 'H');
84 | while (!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_BYTE_TRANSMITTED) == SET) {
85 | ;
86 | }
87 |
88 | I2C_SendData(I2C2, 'E');
89 | while (!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_BYTE_TRANSMITTED) == SET) {
90 | ;
91 | }
92 | I2C_GenerateSTOP(I2C2, ENABLE);
93 |
94 | /////////////////////////////////////////////////////////////////////////////////////////////
95 |
96 | while (I2C_GetFlagStatus(I2C2, I2C_FLAG_BUSY) == SET) {
97 | ;
98 | }
99 |
100 | I2C_GenerateSTART(I2C2, ENABLE);
101 | while (!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_MODE_SELECT) == SET) {
102 | ;
103 | }
104 |
105 | I2C_Send7bitAddress(I2C2, 0xAA >> 1, I2C_Direction_Receiver);
106 | while (!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED) == SET) {
107 | ;
108 | }
109 |
110 | char abc[5];
111 |
112 | abc[0] = I2C_ReceiveData(I2C2);
113 | while (!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_BYTE_RECEIVED) == SET) {
114 | ;
115 | }
116 |
117 | abc[1] = I2C_ReceiveData(I2C2);
118 | while (!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_BYTE_RECEIVED) == SET) {
119 | ;
120 | }
121 |
122 | abc[2] = I2C_ReceiveData(I2C2);
123 | while (!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_BYTE_RECEIVED) == SET) {
124 | ;
125 | }
126 |
127 | abc[3] = I2C_ReceiveData(I2C2);
128 | while (!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_BYTE_RECEIVED) == SET) {
129 | ;
130 | }
131 |
132 | abc[4] = I2C_ReceiveData(I2C2);
133 | while (!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_BYTE_RECEIVED) == SET) {
134 | ;
135 | }
136 |
137 | I2C_GenerateSTOP(I2C2, ENABLE);
138 |
139 |
140 | USART_SendData(USART2,abc[0]);
141 | USART_SendData(USART2,abc[1]);
142 | USART_SendData(USART2,abc[2]);
143 | USART_SendData(USART2,abc[3]);
144 | USART_SendData(USART2,abc[4]);
145 | /////////////////////////////////////////////////////////////////
146 |
147 | while (1) {
148 |
149 | }
150 | }
151 |
152 | void setup_i2c() {
153 |
154 | /* GPIO Setup */
155 | RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);
156 | RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C2, ENABLE);
157 |
158 | GPIO_PinAFConfig(GPIOB, GPIO_PinSource10, GPIO_AF_I2C2);
159 | GPIO_PinAFConfig(GPIOB, GPIO_PinSource11, GPIO_AF_I2C2);
160 |
161 | GPIO_InitTypeDef GPIO_I2C;
162 | GPIO_I2C.GPIO_Pin = GPIO_Pin_10 | GPIO_Pin_11;
163 | GPIO_I2C.GPIO_Mode = GPIO_Mode_AF;
164 | GPIO_I2C.GPIO_OType = GPIO_OType_OD;
165 | GPIO_I2C.GPIO_Speed = GPIO_Speed_50MHz;
166 | GPIO_I2C.GPIO_PuPd = GPIO_PuPd_NOPULL;
167 | GPIO_Init(GPIOB, &GPIO_I2C);
168 |
169 | /* I2C Setup */
170 | I2C_InitTypeDef I2C_init;
171 | I2C_init.I2C_Mode = I2C_Mode_I2C;
172 | I2C_init.I2C_ClockSpeed = 400000;
173 | I2C_init.I2C_DutyCycle = I2C_DutyCycle_16_9;
174 | I2C_init.I2C_OwnAddress1 = 0x00;
175 | I2C_init.I2C_Ack = I2C_Ack_Enable;
176 | I2C_init.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
177 | I2C_Init(I2C2, &I2C_init);
178 |
179 | I2C_Cmd(I2C2, ENABLE);
180 | }
