1 | void initDAC()
2 | {
3 | configureSPI1(&spi1Config);
4 |
5 | GPIO_InitTypeDef nss;
6 | nss.GPIO_Mode = GPIO_Mode_OUT;
7 | nss.GPIO_PuPd = GPIO_PuPd_UP;
8 | nss.GPIO_Pin = spi1Config.GPIO_NSS_Pin;
9 | GPIO_Init(spi1Config.NSS_PORT,&nss);
10 | GPIO_SetBits(spi1Config.NSS_PORT,spi1Config.GPIO_NSS_Pin);
11 |
12 | SPI_Ini(&spi1Config);
13 |
14 | SPI1->CR1 |= (1<<8); //set SSI flag
15 | //SPI1->CR2 |= (1<<2); //Set slave select output
16 | }
17 |
18 |
19 |
20 | void SPI_Ini(SPI_ExtConfig* conf)
21 | {
22 | //Enable clocks
23 | if(conf->SPIx == SPI1)
24 | RCC_APB2PeriphClockCmd(conf->LowSpeed_APB_PeripheralClock, ENABLE);
25 | else
26 | RCC_APB1PeriphClockCmd(conf->LowSpeed_APB_PeripheralClock, ENABLE);
27 |
28 | RCC_AHB1PeriphClockCmd(conf->PeripheralClock_NSS, ENABLE);
29 | RCC_AHB1PeriphClockCmd(conf->PeripheralClock_SCK, ENABLE);
30 | RCC_AHB1PeriphClockCmd(conf->PeripheralClock_MISO, ENABLE);
31 | RCC_AHB1PeriphClockCmd(conf->PeripheralClock_MOSI, ENABLE);
32 |
33 | //Configure GPIO Pins
34 | GPIO_PinAFConfig(conf->NSS_PORT, conf->NSS_Source, conf->GPIO_AlternativeFunction);
35 | GPIO_PinAFConfig(conf->SCK_PORT, conf->SCK_Source, conf->GPIO_AlternativeFunction);
36 | GPIO_PinAFConfig(conf->MISO_PORT, conf->MISO_Source, conf->GPIO_AlternativeFunction);
37 | GPIO_PinAFConfig(conf->MOSI_PORT, conf->MOSI_Source, conf->GPIO_AlternativeFunction);
38 |
39 | if(conf->SPI_InterfaceConfig.SPI_Mode != SPI_Mode_Master)
40 | {
41 | conf->GPIO_MyConfig.GPIO_Pin = conf->GPIO_NSS_Pin;
42 | GPIO_Init(conf->NSS_PORT,&(conf->GPIO_MyConfig));
43 | }
44 | conf->GPIO_MyConfig.GPIO_Pin = conf->GPIO_SCK_Pin;
45 | GPIO_Init(conf->SCK_PORT,&(conf->GPIO_MyConfig));
46 | conf->GPIO_MyConfig.GPIO_Pin = conf->GPIO_MISO_Pin;
47 | GPIO_Init(conf->MISO_PORT,&(conf->GPIO_MyConfig));
48 | conf->GPIO_MyConfig.GPIO_Pin = conf->GPIO_MOSI_Pin;
49 | GPIO_Init(conf->MOSI_PORT,&(conf->GPIO_MyConfig));
50 |
51 | SPI_I2S_DeInit(conf->SPIx);
52 | SPI_Init(conf->SPIx,&(conf->SPI_InterfaceConfig));
53 | SPI_Cmd(conf->SPIx,ENABLE);
54 |
55 | if(conf->precondition != 0)
56 | conf->precondition();
57 | }
58 |
59 | static inline void configureSPI1(SPI_ExtConfig* conf)
60 | {
61 | conf->NSS_Source = GPIO_PinSource4;
62 | conf->SCK_Source = GPIO_PinSource5;
63 | conf->MISO_Source = GPIO_PinSource6;
64 | conf->MOSI_Source = GPIO_PinSource7;
65 | conf->LowSpeed_APB_PeripheralClock = RCC_APB2Periph_SPI1;
66 | conf->PeripheralClock_NSS = RCC_AHB1Periph_GPIOA;
67 | conf->PeripheralClock_SCK = RCC_AHB1Periph_GPIOA;
68 | conf->PeripheralClock_MISO = RCC_AHB1Periph_GPIOA;
69 | conf->PeripheralClock_MOSI = RCC_AHB1Periph_GPIOA;
70 | conf->GPIO_NSS_Pin = GPIO_Pin_4;
71 | conf->GPIO_SCK_Pin = GPIO_Pin_5;
72 | conf->GPIO_MISO_Pin = GPIO_Pin_6;
73 | conf->GPIO_MOSI_Pin = GPIO_Pin_7;
74 | conf->GPIO_AlternativeFunction = GPIO_AF_SPI1;
75 | conf->NSS_PORT = GPIOA;
76 | conf->SCK_PORT = GPIOA;
77 | conf->MISO_PORT = GPIOA;
78 | conf->MOSI_PORT = GPIOA;
79 | conf->SPIx = SPI1;
80 | SPI_StructInit(&(conf->SPI_InterfaceConfig));
81 | conf->SPI_InterfaceConfig.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_32;
82 | conf->SPI_InterfaceConfig.SPI_CPHA = SPI_CPHA_1Edge;
83 | conf->SPI_InterfaceConfig.SPI_CPOL = SPI_CPOL_Low;
84 | conf->SPI_InterfaceConfig.SPI_CRCPolynomial = 0;
85 | conf->SPI_InterfaceConfig.SPI_DataSize = SPI_DataSize_8b;
86 | conf->SPI_InterfaceConfig.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
87 | conf->SPI_InterfaceConfig.SPI_FirstBit = SPI_FirstBit_MSB;
88 | conf->SPI_InterfaceConfig.SPI_Mode = SPI_Mode_Master;
89 | conf->SPI_InterfaceConfig.SPI_NSS = SPI_NSS_Soft;
90 |
91 | conf->GPIO_MyConfig.GPIO_Mode = GPIO_Mode_AF;
92 | conf->GPIO_MyConfig.GPIO_OType = GPIO_OType_PP;
93 | conf->GPIO_MyConfig.GPIO_PuPd = GPIO_PuPd_NOPULL;
94 | conf->GPIO_MyConfig.GPIO_Speed = GPIO_Speed_50MHz;
95 |
96 | conf->precondition = 0;
97 | };
98 |
99 | inline SendErrorCode SPI_Send32Bit(uint32_t data,SPI_ExtConfig* conf)
100 | {
101 | volatile uint32_t delayCounter = 0;
102 | while(SPI_GetFlagStatus(SPI1, SPI_FLAG_TXE) == RESET && delayCounter < SPI_ERROR_DELAY)
103 | {
104 | //Handle Mode Fault
105 | while (SPI_I2S_GetFlagStatus(SPI1,SPI_FLAG_MODF))
106 | {
107 | volatile int temp1, temp2; //Clear MODF and enable SPI again
108 | temp1=SPI1->CR1;
109 | temp2=SPI1->SR;
110 | SPI1->CR1=temp1;
111 | SPI_Init(SPI1,&(conf->SPI_InterfaceConfig));
112 | SPI_Cmd(SPI1,ENABLE);
113 | }
114 | delayCounter ++;
115 | }
116 | if(delayCounter == SPI_ERROR_DELAY)
117 | return DEVICE_UNREAD;
118 |
119 | GPIO_ResetBits(GPIOA,GPIO_Pin_4);
120 | volatile uint32_t delay;
121 | for(delay = 0; delay < 10; delay ++){}
122 |
123 | SPI_I2S_SendData(conf->SPIx, (data>>24) & 0xFF);
124 | // be sure that the character goes to the shift register
125 | if(controlledWaiting() != OK)
126 | return TIME_OUT;
127 |
128 | SPI_I2S_SendData(conf->SPIx, (data>>16) & 0xFF);
129 | // be sure that the character goes to the shift register
130 | if(controlledWaiting() != OK)
131 | return TIME_OUT;
132 |
133 | SPI_I2S_SendData(conf->SPIx, (data>>8) & 0xFF);
134 | // be sure that the character goes to the shift register
135 | if(controlledWaiting() != OK)
136 | return TIME_OUT;
137 |
138 | SPI_I2S_SendData(conf->SPIx, data & 0xFF);
139 | if(controlledWaiting() != OK)
140 | return TIME_OUT;
141 |
142 | GPIO_SetBits(GPIOA,GPIO_Pin_4);
143 |
144 | return OK;
145 | };
