Yes, I know just another entry with ADC but I did not find a hint
for my problem in the forum yet.
I have a Problem reading an adc value with ATMega328P in noise reduction
mode ( with a Interrupt Service routine ).
Because reading per polling the ADSC Bit is OK, I get the right value
that way, I suppose the error has to do with the initialization of ADC
in
my function EnableADCInt(... ).
The ISR is definitely not called !
adcValue in ISR is volatile in my header.
Where is the missing bit ?
By the way:
This forum is very helpful for me. I found already many important
hints.
Here the code:
void EnableADCInt(uint8_t channel)
// Clear PRADC to startup ADC
PRR &= ~(1<<PRADC); // Power Reduction Register
ADMUX = 0;
ADMUX |= (1 << REFS1) | (1 << REFS0);
ADMUX |= channel;
ADCSRA = ( 1 << ADPS2) | ( 0 << ADPS1) | ( 1 << ADPS0) ;
// Für Interrupt bei Free Running ?
// ADCSRA |= ( 1 << ADATE);
// Free running mode !?
// ADCSRB = 0;
// sleep Mode
set_sleep_mode(SLEEP_MODE_ADC);
// Bit 3 – ADIE: ADC Interrupt Enable
// Bit 7 – ADEN: ADC Enable
// Bit 6 – ADSC: ADC Start Conversion but not for noise reduction ?
ADCSRA |= (1 << ADEN) | (1 << ADIE);
// enable Global Int
sei();
void DisableADCInt()
// disable ADC Int
// Bit 3 – ADIE: ADC Interrupt Disable
// Bit 7 – ADEN: ADC Disable
// Bit 6 – ADSC: ADC Stop Conversion
ADCSRA = 0;
PRR |= (1<<PRADC);
// Oversampling to improve the value
int16_t GetADCTemp(uint8_t channel)
EnableADCInt(channel);
sleep_cpu(); // throw away first reading
adcCount=0;
adcValue=0;
while( adcCount < 64 )
adcCount++;
sleep_cpu();
DisableADCInt();
int16_t ticksresult = (adcValue >> 6);
return ticksresult;
ISR(ADC_vect)
adcValue = ADC; // low + high byte
