1 | /* Zusatzinfos!
2 | static tWaveFileInfo g_psWaveFiles[5u];
3 | static tWaveHeader g_sWaveHeader;
4 |
5 | CPU_INT08S pcFilename[16];
6 | CPU_INT32U *pucFilePtr;
7 |
8 | tWaveReturnCode BSP_WaveOpen(CPU_INT32U *pulAddress, tWaveHeader *pWaveHeader);
9 | void BSP_WavePlay(tWaveHeader *pWaveHeader);
10 | */
11 |
12 | /* (1) Get pointers to the WAV files. */
13 | g_psWaveFiles[0].pucFilePtr = __section_begin("wave_1");
14 |
15 | /* (2) Name the files. */
16 | sprintf(g_psWaveFiles[0].pcFilename, "Auto");
17 |
18 | /* (3) Set the pointer to the first wave in the list.*/
19 | g_ucCurrentWaveIdx = 0;
20 | strcpy(pcCurrentWaveTitle, g_psWaveFiles[0].pcFilename);
21 |
22 | /* (4)
23 | *********************************************************************************************************
24 | * Description : This function can be used to test if a file is a wav file or not and will
25 | * also return the wav file header information in the pWaveHeader structure.
26 | *
27 | * Argument(s) : pulAddress is a pointer to the starting address of the wave file.
28 | * pWaveHeader is a pointer to the tWaveHeader data structure to be populated.
29 | *
30 | * Return(s) : WAVE_OK on success.
31 | * WAVE_INVALID_RIFF if RIFF information is not supported.
32 | * WAVE_INVALID_CHUNK if chunk size is not supported.
33 | * WAVE_INVALID_FORMAT if file format is not supported.
34 | *
35 | *********************************************************************************************************
36 | */
37 | BSP_WaveOpen(g_psWaveFiles[g_ucCurrentWaveIdx].pucFilePtr, &g_sWaveHeader);
38 |
39 | /* (5)
40 | *********************************************************************************************************
41 | * Description : This will play the file passed in via the psFileObject parameter based on
42 | * the format passed in the pWaveHeader structure. The WaveOpen() function
43 | * can be used to properly fill the pWaveHeader and psFileObject structures.
44 | *
45 | * Argument(s) : pWaveHeader is a pointer to the current wave file's header information.
46 | *********************************************************************************************************
47 | */
48 | BSP_WavePlay(&g_sWaveHeader);
