1 | #include <avr/io.h>
2 | #include <avr/sleep.h>
3 | #include <avr/interrupt.h>
4 | #include <util/delay.h>
5 | #include <stdio.h>
6 | #include <stdlib.h>
7 | #include <stdarg.h>
8 | #include <string.h>
9 |
10 | //Makros==============================
11 |
12 | #define SET_LED(x) PORTB=PORTB&(~(1<<x))
13 | #define CLEAR_LED(x) PORTB=PORTB|(1<<x)
14 |
15 | #define cb_SIZE 10
16 |
17 | uint8_t init_uart(uint16_t baud,uint8_t data_bits,uint8_t stop_bits);
18 | void rs232_send_char(unsigned char data);
19 | unsigned char USART_Receive(void);
20 | void USART_Init(unsigned int baud);
21 | int init(void);
22 |
23 | int main(void)
24 | {
25 | init();
26 |
27 | _delay_ms(2000);
28 | rs232_send_char(0x55);
29 | SET_LED(1);
30 |
31 | rs232_send_char(0x45);//Befehl für Hintergrund löschen
32 | SET_LED(2);
33 | rs232_send_char(0x42);//Befehl für Hintergrundfarbe ändern
34 | //Farbe ROT:
35 | rs232_send_char(0xF0);
36 | rs232_send_char(0x00);
37 | SET_LED(3);
38 |
39 | while(1)
40 | {
41 |
42 | }
43 | return 0;
44 | }
45 |
46 | //Die init Funktion initialsiert LEDs, CPU Tackt und USART=============
47 |
48 | int init(void)
49 | {
50 | DDRB=0xFF; /* set the Port PORTB to output */
51 | PORTB=0xFF; /* write all 1s to PORTB */
52 | DDRC=0x04; /* set the Port Pin PORTC.2 to output */
53 | PORTC=0x04; /* set the Port Pin PORTC.2 (LE) */
54 |
55 | //Clock Konfiguration====================================================
56 | CLKPR=0x80;
57 | CLKPR=0x00;//16MHz
58 | //USART Konfiguration====================================================
59 |
60 | init_uart(9600,8,1);
61 |
62 | return 0;
63 | }
64 |
65 | uint8_t init_uart(uint16_t baud,uint8_t data_bits,uint8_t stop_bits)
66 | {
67 |
68 | uint16_t temp; //temporary work var
69 | temp = (((F_CPU)/16)/baud)-1; //baud rate calculation. see at90usb162 datasheet page 149
70 | temp = (((F_CPU+baud*8)/16)/baud)-1;// better formula...
71 |
72 | if((data_bits >=5)&&(data_bits <=8))
73 | data_bits -=5; // 00 = 5 ; 11 = 8
74 | else
75 | return 1;
76 |
77 | if((stop_bits == 1)|(stop_bits == 2))
78 | stop_bits -= 1; //0 = 1bit 1 = 2bit
79 | else
80 | return 1;
81 |
82 | UCSR1B = (1<<RXEN1)|(1<<TXEN1)|(1<<RXCIE1); // Transmit, Receive enable
83 | UCSR1C = (stop_bits<<USBS1)|(data_bits<<UCSZ10); // 8Databits 1stopbits
84 | UBRR1H = (unsigned char)((temp & 0xFF00)>>8); //mask high byte and write it to UBBR1H
85 | UBRR1L = (unsigned char)(temp & 0x00FF); //mask low byte and write it to UBBR1L
86 |
87 | return 0;
88 |
89 | }
90 |
91 | void USART_Init(unsigned int baud)
92 | {
93 | /* Set baud rate */
94 | UBRR1H = (unsigned char)(baud>>8);
95 | UBRR1L = (unsigned char)baud;
96 | /* Enable receiver and transmitter */
97 | UCSR1B = (1<<RXEN1)|(1<<TXEN1);
98 | /* Set frame format: 8data, 2stop bit */
99 | //UCSR1C = (1<<USBS1)|(3<<UCSZ10);
100 | UCSR1C=UCSR1C|6;
101 | //UCSR1C = (3<<UCSZ10);
102 | }
103 |
104 | void rs232_send_char(unsigned char data)
105 | {
106 | /* Wait for empty transmit buffer */
107 | while(!(UCSR1A&(1<<UDRE1)))
108 | ;
109 | /* Put data into buffer, sends the data */
110 | UDR1 = data;
111 | }
112 |
113 | unsigned char USART_Receive(void)
114 | {
115 | /* Wait for data to be received */
116 | while(!(UCSR1A&(1<<RXC1)))
117 | ;
118 | /* Get and return received data from buffer */
119 | return UDR1;
120 | }
