1 | /* SPIx Communication boards Interface */
2 | #define SPIx SPI2
3 | #define SPIx_CLK RCC_APB1Periph_SPI2
4 | #define SPIx_CLK_INIT RCC_APB1PeriphClockCmd
5 | #define SPIx_IRQn SPI2_IRQn
6 | #define SPIx_IRQHANDLER SPI2_IRQHandler
7 |
8 | #define SPIx_SCK_PIN GPIO_Pin_1
9 | #define SPIx_SCK_GPIO_PORT GPIOI
10 | #define SPIx_SCK_GPIO_CLK RCC_AHB1Periph_GPIOI
11 | #define SPIx_SCK_SOURCE GPIO_PinSource1
12 | #define SPIx_SCK_AF GPIO_AF_SPI2
13 |
14 | #define SPIx_MISO_PIN GPIO_Pin_2
15 | #define SPIx_MISO_GPIO_PORT GPIOI
16 | #define SPIx_MISO_GPIO_CLK RCC_AHB1Periph_GPIOI
17 | #define SPIx_MISO_SOURCE GPIO_PinSource2
18 | #define SPIx_MISO_AF GPIO_AF_SPI2
19 |
20 | #define SPIx_MOSI_PIN GPIO_Pin_3
21 | #define SPIx_MOSI_GPIO_PORT GPIOI
22 | #define SPIx_MOSI_GPIO_CLK RCC_AHB1Periph_GPIOI
23 | #define SPIx_MOSI_SOURCE GPIO_PinSource3
24 | #define SPIx_MOSI_AF GPIO_AF_SPI2
25 |
26 | #define TXBUFFERSIZE (countof(TxBuffer) - 1)
27 | #define RXBUFFERSIZE TXBUFFERSIZE
28 |
29 |
30 | GPIO_InitTypeDef GPIO_InitStructure;
31 | SPI_InitTypeDef SPI_InitStructure;
32 |
33 | static void SPI_Config(void);
34 | void SPIx_IRQHANDLER(void);
35 | uint8_t GetVar_NbrOfData(void);
36 |
37 | uint8_t TxBuffer[];
38 | __IO uint8_t Counter = 0x00;
39 | __IO uint32_t TimeOut;
40 |
41 | __IO uint8_t Tx_Idx = 0x00;
42 | __IO uint8_t CmdStatus = 0x00;
43 | __IO uint8_t NumberOfByte = 0x01;
44 |
45 | int TimeStep100ms = 100;
46 | int TimeStep200ms = 200;
47 | int TimeStep500ms = 500;
48 | int NextTime = 0;
49 |
50 | void main (void)
51 | {
52 | /* SPI configuration ------------------------------------------------------*/
53 | SPI_Config();
54 |
55 | /* Initializes the SPI communication */
56 | SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
57 | SPI_Init(SPIx, &SPI_InitStructure);
58 |
59 | /* The Data transfer is performed in the SPI interrupt routine */
60 | /* Enable the SPI peripheral */
61 | SPI_Cmd(SPIx, ENABLE);
62 |
63 | while (1)
64 | {
65 | STM_EVAL_LEDToggle(LED2);
66 |
67 | /* Enable the Tx buffer empty interrupt */
68 | SPI_I2S_ITConfig(SPIx, SPI_I2S_IT_TXE, ENABLE);
69 |
70 | /* Waiting the end of Data transfer */
71 | while (Tx_Idx < GetVar_NbrOfData())
72 | {
73 | }
74 | delay(1000);
75 | }
76 | }
77 |
78 | void SPIx_IRQHANDLER(void)
79 | {
80 | /* SPI in Master Tramitter mode--------------------------------------- */
81 | if (SPI_I2S_GetITStatus(SPIx, SPI_I2S_IT_TXE) == SET)
82 | {
83 | if (Tx_Idx < GetVar_NbrOfData())
84 | {
85 | /* Send Transaction data */
86 | SPI_I2S_SendData(SPIx, TxBuffer[Tx_Idx++]);
87 | }
88 | else
89 | {
90 | /* Disable the Tx buffer empty interrupt */
91 | SPI_I2S_ITConfig(SPIx, SPI_I2S_IT_TXE, DISABLE);
92 | }
93 | }
94 | }
95 |
96 | uint8_t GetVar_NbrOfData(void)
97 | {
98 | return NumberOfByte;
99 | }
100 |
101 | static void SPI_Config(void)
102 | {
103 | GPIO_InitTypeDef GPIO_InitStructure;
104 | NVIC_InitTypeDef NVIC_InitStructure;
105 |
106 | /* Enable the SPI clock */
107 | SPIx_CLK_INIT(SPIx_CLK, ENABLE);
108 |
109 | /* Enable GPIO clocks */
110 | RCC_AHB1PeriphClockCmd(SPIx_SCK_GPIO_CLK | SPIx_MISO_GPIO_CLK | SPIx_MOSI_GPIO_CLK, ENABLE);
111 |
112 | /* Connect SPI pins to AF5 */
113 | GPIO_PinAFConfig(SPIx_SCK_GPIO_PORT, SPIx_SCK_SOURCE, SPIx_SCK_AF);
114 | GPIO_PinAFConfig(SPIx_MOSI_GPIO_PORT, SPIx_MOSI_SOURCE, SPIx_MOSI_AF);
115 |
116 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
117 | GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
118 | GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
119 | GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_DOWN;
120 |
121 | /* SPI SCK pin configuration */
122 | GPIO_InitStructure.GPIO_Pin = SPIx_SCK_PIN;
123 | GPIO_Init(SPIx_SCK_GPIO_PORT, &GPIO_InitStructure);
124 |
125 | /* SPI MOSI pin configuration */
126 | GPIO_InitStructure.GPIO_Pin = SPIx_MOSI_PIN;
127 | GPIO_Init(SPIx_MOSI_GPIO_PORT, &GPIO_InitStructure);
128 |
129 | /* SPI configuration -------------------------------------------------------*/
130 | SPI_I2S_DeInit(SPIx);
131 | SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
132 | SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
133 | SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
134 | SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;
135 | SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
136 | SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_2;
137 | SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
138 | SPI_InitStructure.SPI_CRCPolynomial = 7;
139 |
140 | /* Configure the Priority Group to 1 bit */
141 | NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
142 |
143 | /* Configure the SPI interrupt priority */
144 | NVIC_InitStructure.NVIC_IRQChannel = SPIx_IRQn;
145 | NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
146 | NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
147 | NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
148 | NVIC_Init(&NVIC_InitStructure);
149 | }
