1 | //Pre-Processor Directives:
2 | #include <p30fxxxx.h>
3 | #include "system.h"
4 |
5 | //Werte zur Berechnung von dem Baudrateprescaler siehe dsPIC_CAN_Manual.pdf 23.10
6 | //--------------------------------------------------------------------- //Reference Manual
7 | #define FCY 15000000 // 15 MHz !!
8 | #define BITRATE 500000 // 0,5Mbps oder 500KHz
9 | #define NTQ 15 // Number of Tq cycles which will make the
10 | //CAN Bit Timing .
11 | #define BRP_VAL ((FCY/(2*NTQ*BITRATE))-1) //Formel für Baudrateprescaler C1CFG1bits.BRP
12 | //---------------------------------------------------------------------
13 |
14 |
15 | //Declaration to Link External Functions & Variables:
16 |
17 |
18 | //Functions and Variables with Global Scope:
19 | void CAN_Init ( unsigned int pos);
20 | void __attribute__((interrupt, no_auto_psv)) _C1Interrupt(void); //Interrupt Routine zum Empfangen von CAN Nachrichten
21 |
22 | // Buffer Registers for CAN data to be send out in the transmit mode.
23 | // hier stehen die Daten, die man über CAN schickt
24 |
25 | //unsigned
26 | int OutData0[2] = {0x0000, 0x0001}; //Position Byte 0&1:, Command Byte 2 z.B. 1 für Positionieren
27 |
28 |
29 | // Intilializing the receive registers to be 0
30 |
31 | unsigned int InData0[4] = {0, 0, 0, 0};
32 | unsigned int InData1[2] = {0, 0};
33 | unsigned int InData2[4] = {0, 0, 0, 0};
34 | unsigned int InData3[2] = {0, 0};
35 |
36 | //---------------------------------------------------------------------
37 |
38 |
39 |
40 |
41 |
42 | //Functions
43 | //CAN_Init() sets up the CAN-Module
44 |
45 |
46 | void CAN_Init (unsigned int pos)
47 | {
48 |
49 | //C1CTRLbits.CANCAP = 1;
50 | //--------------------------------------------------------------------------------------------------------------------
51 | //Initialization of CAN1 Module and Enabling of CAN1 Interrupts
52 | //--------------------------------------------------------------------------------------------------------------------
53 |
54 | // siehe dsPIC_CAN_Manual.pdf 23.10.1 Bit Timing und 23.2.6 CAN Baud Rate Registers
55 |
56 | C1CTRLbits.CANCKS = 1; // Select the CAN Master Clock . It is equal to Fcy here.
57 | // equal to Fcy.(Fcy=15Mhz)
58 |
59 |
60 | C1CFG1bits.SJW=2; //Synchronized jump width time is 3 x TQ when SJW is equal to 0b10
61 |
62 |
63 | C1CFG1bits.BRP = BRP_VAL; //((FCY/(2*NTQ*BITRATE))-1)
64 | // siehe dsPIC_CAN_Manual.pdf 23.2.6 CAN Baud Rate Registers, Register 23-20: CiCFG2: Baud Rate Configuration Register 2
65 | C1CFG2 = 0x02FA; // SEG1PH=8Tq, SEG2PH=2Tq, PRSEG=2Tq, Tsync=1Tq
66 | // Sample 1 times
67 | // Each bit time is Tsync+SEG1PH+SEG2PH+PRSEG=13Tq
68 | // Nach Baudrate-Berechnung sollte 15Tq rauskommen, wegen Taktabweichung sollte aber auf 13Tq gestellt werden
69 |
70 | ///Interrupt Section of CAN Peripheral
71 |
72 | C1INTF = 0; //Reset all The CAN Interrupts
73 | IFS1bits.C1IF = 0; //Reset the Interrupt Flag status register
74 | C1INTE = 0x00FF; //Enable all CAN interrupt sources
75 | IEC1bits.C1IE = 1; //Enable the CAN1 Interrupt
76 |
77 | //-----------------------------------------------------------------------------------------------------------------------
78 | // Configure Receive registers, Filters and Masks
79 | //-----------------------------------------------------------------------------------------------------------------------
80 |
81 | // We are initializing the Receive Buffer 0 and Receive Buffer 1 for CAN
82 |
83 | C1RX0CON = 0x0006; // Receive Buffer 0 -- dsPIC Family reference Manual Seite.8
84 | C1RX1CON = 0x0000; //Receive Buffer 1 and Control Register for CAN1 -- dsPIC Family reference Manual Seite.8
85 |
86 | // Identifier Actuator_to_Tool : 0x18FF0D82 Receive register wird in SID und EID aufgeteilt
87 | //von bit 0 bis bit 17 in den EID, den Rest in den SID
88 |
89 | C1RX0SID = 0x18FD; // SID 0x63F --dsPIC Family reference Manual Seite.10
90 | C1RX0EID = 0x0C36; // EID 30D82
91 | C1RX0DLC = 0x0806; //Select the Data word Length for CAN1 Receive Buffer0
92 |
93 |
94 | // Acceptance Mask Register0SID and Register1SID associated with Recieve Buffer0
95 | // and Receive Buffer1 for CAN1
96 | C1RXM0SID = C1RXM1SID = 0x18FC; //siehe dsPIC_CAN_Manual.pdf--dsPIC Family reference Manual Seite.22
97 |
98 | // Acceptance Mask Register0EIDH and Register1EIDH associated with Recieve Buffer0
99 | // and Receive Buffer1 for CAN1
100 | C1RXM0EIDH = C1RXM1EIDH = 0x0C36;
101 |
102 | // Acceptance Mask Register0EIDL and Register1EIDL associated with Recieve Buffer0
103 | //and Receive Buffer1 for CAN1
104 | C1RXM0EIDL = C1RXM1EIDL = 0x800;
105 |
106 |
107 | // Acceptance Filter wird in SID und EID aufgeteilt
108 |
109 | C1RXF0SID = C1RXF1SID = C1RXF2SID = C1RXF3SID = C1RXF4SID = C1RXF5SID = 0x18FD; //CAN1 Receive Acceptance Filter2 SID
110 | C1RXF0EIDH = C1RXF1EIDH = C1RXF2EIDH = C1RXF3EIDH = C1RXF4EIDH = C1RXF5EIDH = 0xC36; //CAN1 Receive Acceptace Filter2 Extended Identifier high byte
111 | C1RXF0EIDL = C1RXF1EIDL = C1RXF2EIDL = C1RXF3EIDL = C1RXF4EIDL = C1RXF5EIDL = 0x800; //CAN1 Receive Acceptance Filter2 Extended identifier low byte
112 |
113 | InData0[0] = C1RX0B1;
114 | InData0[1] = C1RX0B2; //Move the recieve data from Buffers to InData
115 | InData0[2] = C1RX0B3;
116 | InData0[3] = C1RX0B4;
117 | InData1[0] = C1RX1B1; //Move the data received to Indata Registers
118 | InData1[1] = C1RX1B2;
119 |
120 |
121 |
122 | // Enable reception
123 |
124 | /*C1CTRLbits.CANCAP = 1;
125 | C1CTRLbits.REQOP = 0;
126 | while(C1CTRLbits.OPMODE != 0);*/
127 |
128 |
129 | C1RX0CONbits.DBEN = 1;
130 | C1RX0CONbits.JTOFF = 1;
131 |
132 |
133 | //-----------------------------------------------------------------------------------------------------------------------
134 | // Configure Transmit Registers Buffer 0 and Transmit Buffer 1
135 | //-----------------------------------------------------------------------------------------------------------------------
136 |
137 | C1TX0CON = 0x0003; // High priority
138 | //Steller identifier SRA 0x08FF8201 wird in SID und EID aufgeteilt
139 | //von bit 0 bis bit 17 in den EID, den Rest in den SID
140 | C1TX0SID = 0x40FD; // SID 0x23F
141 | C1TX0EID = 0xE008; // EID 0x38201
142 | C1TX0DLC = 0x0420; //Select the Data word Length for CAN1 Transmit Buffer0 which is 4 byte
143 | // identifier SRA 0x08FF8201 wird aufgeteilt auf Extended und Standard Identifier
144 |
145 |
146 |
147 |
148 | // Data Field 1,Data Field 2, Data Field 3, Data Field 4 // 4 bytes selected by DLC
149 |
150 | OutData0[0]=pos; //Übergabeparameter pos umgerechnet von Analogspannung Poti, oder Messgalgen
151 |
152 | C1TX0B1 = OutData0[0]; //Zuweisung der Pos. Byte 0&1 ind den Buffer 1 schreiben
153 | C1TX0B2 = OutData0[1]; //Zuweisung des Behehls z.B. 1 für Positionieren, 2 für Einlernen
154 |
155 |
156 |
157 |
158 | //Change to Normal Operation Mode from Configuration Mode
159 |
160 | C1CTRLbits.REQOP = 0;
161 | while(C1CTRLbits.OPMODE != 0);//Wait for CAN1 mode change from Configuration Mode to Normal mode
162 |
163 | //Enable transmission
164 |
165 | C1TX0CONbits.TXREQ = 1;
166 | C1TX1CONbits.TXREQ = 1;
167 |
168 |
169 |
170 |
171 | }
172 |
173 | //--------------------------------------------------------------------------------------------------------------------------
174 | //Interrupt Section for CAN1
175 | //--------------------------------------------------------------------------------------------------------------------------
176 |
177 | void __attribute__((interrupt, no_auto_psv)) _C1Interrupt(void)
178 | {
179 |
180 | IFS1bits.C1IF = 0; //Clear interrupt flag
181 |
182 | if(C1INTFbits.TX0IF)
183 | {
184 | LATBbits.LATB1 =~ LATBbits.LATB1; //Toggle LATB1 (LED D4 blinkt beim Senden)
185 | C1INTFbits.TX0IF = 0; //If the Interrupt is due to Transmit0 of CAN1 Clear the Interrupt
186 |
187 | }
188 | else if(C1INTFbits.TX1IF)
189 | {
190 | LATBbits.LATB1 =~ LATBbits.LATB1;
191 | C1INTFbits.TX1IF = 0; //If the Interrupt is due to Transmit1 of CAN1 Clear the Interrupt
192 |
193 | }
194 |
195 | if(C1INTFbits.RX0IF )
196 | {
197 | LATBbits.LATB0 =~ LATBbits.LATB0; //Toggle LATB0 (LED D3 soll beim Empfang blinken...tut aber nichts)
198 | C1INTFbits.RX0IF = 0; //If the Interrupt is due to Receive0 of CAN1 Clear the Interrupt
199 |
200 | InData0[0] = C1RX0B1;
201 | InData0[1] = C1RX0B2; //Move the recieve data from Buffers to InData
202 | InData0[2] = C1RX0B3;
203 | InData0[3] = C1RX0B4;
204 |
205 | //InData - Empfangene Daten können ausgewertet werden
206 | }
207 |
208 | else if(C1INTFbits.RX1IF)
209 | {
210 | LATBbits.LATB0 =~ LATBbits.LATB0; //Toggle LATB0 (LED D3soll beim Empfang blinken...tut aber nichts)
211 | C1INTFbits.RX1IF = 0; //If the Interrupt is due to Receive1 of CAN1 Clear the Interrupt
212 | InData1[0] = C1RX1B1; //Move the data received to Indata Registers
213 | InData1[1] = C1RX1B2;
214 | }
215 | }
