1 | #include <stdio.h>
2 |
3 | #define PMC_PCER 0xFFFFFC10 // Power Management Controller: Peripheral Clock Enable Register
4 | #define TC_CMR0 0xFFFDC004 // Channel mode Register as seen in the datasheet for channel 0
5 | #define TC_CMR1 0xFFFDC044 // Channel mode Register as seen in the datasheet for channel 1
6 | #define TC_CMR2 0xFFFDC084 // Channel mode Register as seen in the datasheet for channel 2
7 | #define TC_RC0 0xFFFDC01C // Register C as seen in the datasheet for channel 0
8 | #define TC_RC1 0xFFFDC05C // Register C as seen in the datasheet for channel 1
9 | #define TC_RC2 0xFFFDC09C // Register C as seen in the datasheet for channel 2
10 | #define TC_RB0 0xFFFDC018 // Register B as seen in the datasheet for channel 0
11 | #define TC_RB1 0xFFFDC058 // Register B as seen in the datasheet for channel 1
12 | #define TC_RB2 0xFFFDC098 // Register B as seen in the datasheet for channel 2
13 | #define TC_RA0 0xFFFDC014 // Register A as seen in the datasheet for channel 0
14 | #define TC_RA1 0xFFFDC054 // Register A as seen in the datasheet for channel 1
15 | #define TC_RA2 0xFFFDC094 // Register A as seen in the datasheet for channel 2
16 | #define TC_CCR0 0xFFFDC000 // Channel Control Register as seen in the datasheet for channel 0
17 | #define TC_CCR1 0xFFFDC040 // Channel Control Register as seen in the datasheet for channel 1
18 | #define TC_CCR2 0xFFFDC080 // Channel Control Register as seen in the datasheet for channel 2
19 | #define PIO_PDR 0xFFFFF404 // PIO Controller PIO Enable Register for Port PIOA
20 | #define PIO_ASR 0xFFFFF470 // PIO Peripheral A Select Register for Port PIOA
21 | #define TC_IER0 0xFFFDC024 // Interrupt Enable Register for Channel 0
22 |
23 | #define IO_WR32(adress, value) (*((volatile unsigned long *) (adress)) = (value))
24 | #define IO_RD32(adress) (*((volatile unsigned long *) adress))
25 | #define IO_SET_MASK32(adress, mask) IO_WR32((adress), IO_RD32((adress)) | (mask))
26 |
27 | void pal_pwm_start(){
28 |
29 | // Channel-Pin-Matching:
30 | // PA26: Peripheral A: TIOA0, Peripheral B: ERX3
31 | // Timer/Counter Channel 0: Output: TIOA0, TIOB0
32 | // Timer1: TC0, TC1, TC2: TCLK0-TCLK2, TIOA0-TIOA2, TIOB0-TIOB2
33 | // PA0 - PA31: Parallel I/O Controller A (PIOA)
34 |
35 | // Power Management Controller (PMC): Peripherial Clock Enable Register
36 | // - activate the clock signal for T/C 0 (bit 17 to value 1b)
37 | IO_WR32(PMC_PCER, (1<<17)); // Peripheral ID (PID) 17 belongs to Timer/Counter 0 and to Signal TIOA0
38 | IO_WR32(PMC_PCER, (1<<2)); // Parallel I/O Controller A (PIOA)
39 |
40 | // T/C Channel Control Register for Channel 0:
41 | // - disable the clock signal: CLKDIS-Bit (bit 1 to value 1)
42 | IO_WR32(TC_CCR0, (1<<1));
43 |
44 | // PIO Disable Register for I/O-Port PIOA
45 | // - disable GPIO-functionality for Pins PA26 and PA27 and enable their Peripheral function: Set Bit 26 to value 1
46 | IO_WR32(PIO_PDR, (1<<26));
47 |
48 | // Peripheral A Select Register
49 | // - enable Peripheral A instead of Peripheral B for Pins PA26: Set Bit 26 to value 1
50 | IO_WR32(PIO_ASR, (1<<26));
51 |
52 | // T/C Channel Mode Register for Channel 0:
53 | // - set the Operating Mode to WAVEFORM: WAVE-Bit (bit 15 to value 1b)
54 | // - set the waveform to "up-mode with automatic trigger on RC compare": WAVSEL-Bits (bits 13-14 to value 10b = 2d)
55 | // - set the Clock Signal to MCKL / 2 (TIMER_CLOCK1): TCCLKS-Bits (bits 0-2 to value 000b = 0d)
56 | // - set the RA Compare Effect on TIOA output level to toogle: ACPA-bits (bit 16, 17 to value 11b = 3d)
57 | // - set the RC Compare Effect on TIOA counter to clear: ACPC-Bits (bit 18, 19 to value 10b = 2d)
58 | IO_WR32(TC_CMR0, (1<<15));
59 | IO_WR32(TC_CMR0, (0<<14) | (1<<13));
60 | IO_WR32(TC_CMR0, (0<<2) | (0<<1) | (0<<0));
61 | IO_WR32(TC_CMR0, (1<<17) | (1<<16));
62 | IO_WR32(TC_CMR0, (0<<19) | (1<<18));
63 |
64 | // T/C Interrupt Enable Register for Channel 0:
65 | // - set the RC Compare interrupt (CPCS)
66 | // - set the RA Compare interrupt (CPAS)
67 | //IO_WR32(TC_IER0, (1<<4));
68 | //IO_WR32(TC_IER0, (1<<2));
69 |
70 | // T/C Register C for Channel 0:
71 | // - set the "reset value register" to 2^11: Register C to value 2^11d = 2048d (cuts down the 16-bit-resolution to 11-bit)
72 | IO_WR32(TC_RC0, 2048);
73 |
74 | // T/C Register A for Channel 0:
75 | // - set the LOW-to-HIGH threshold to 2^11 / 2 (50% duty cycle) --> value 1024d
76 | IO_WR32(TC_RA0, 1024);
77 |
78 | // T/C Channel Control Register for Channel 0:
79 | // - enable the clock signal: CLKEN-Bit, CLKDIS-Bit (bit 1 to value 0 and bit 0 to value 1)
80 | IO_WR32(TC_CCR0, (0<<1)); // unset disable-bit
81 | IO_WR32(TC_CCR0, (1<<0)); // set enable-bit
82 | }
