1 | #include <avr/io.h>
2 | #include <string.h>
3 | #include <avr/boot.h>
4 | #include <avr/pgmspace.h>
5 | #include <util/crc16.h>
6 | #include <util/delay.h>
7 | #include "fat1216.h"
8 |
9 | #define USE_FLASH_LED
10 | #define FLASH_LED_PORT PORTG
11 | #define FLASH_LED_DDR DDRG
12 | #define FLASH_LED_PIN PG0
13 | #define FLASH_LED_POLARITY 0
14 |
15 | #define LEDGRUEN PG0 // Anzeige Bottloader erfolgreich beendet
16 | #define LEDROT PG1 // Anzeige Bottloader Fehler in der CRC
17 | #define SOUND PA5 // Nur zum Testen
18 |
19 |
20 |
21 | typedef struct
22 | {
23 | uint32_t dev_id;
24 | uint16_t app_version;
25 | uint16_t crc;
26 | } bootldrinfo_t;
27 |
28 |
29 | uint16_t startcluster;
30 | uint16_t updatecluster; //is set when update is available
31 | bootldrinfo_t current_bootldrinfo;
32 |
33 | void (*app_start)(void) = 0x0000;
34 |
35 | static inline void check_file(void)
36 | {
37 | //Check filesize
38 |
39 | if (filesize != FLASHEND - BOOTLDRSIZE + 1) return;
40 |
41 | bootldrinfo_t *file_bootldrinfo;
42 | fat1216_readfilesector(startcluster, (FLASHEND - BOOTLDRSIZE + 1) / 512 - 1);
43 |
44 | file_bootldrinfo = (bootldrinfo_t*) (uint8_t*) (fat_buf + (FLASHEND - BOOTLDRSIZE - sizeof(bootldrinfo_t) + 1) % 512);
45 |
46 | //Check DEVID
47 | if (file_bootldrinfo->dev_id != DEVID) return;
48 |
49 | //Check application version
50 | if (file_bootldrinfo->app_version < current_bootldrinfo.app_version) return;
51 |
52 | current_bootldrinfo.app_version = file_bootldrinfo->app_version;
53 | updatecluster = startcluster;
54 | }
55 |
56 | int main(void)
57 | {
58 | EIND = 1;
59 | uint16_t i;
60 |
61 | uint16_t filesector, j;
62 | uint16_t *lpword;
63 | uint32_t adr;
64 |
65 | DDRG |= (1<<LEDGRUEN); // Port Pin als Ausgang - Bootloader erfolgreich beendet
66 | DDRG |= (1<<LEDROT); // Port Pin als Ausgang - Fehlerhafte CRC
67 | DDRA |= (1<<SOUND); // Port Pin als Ausgang - Nur zum testen
68 |
69 | //LED On
70 | #ifdef USE_FLASH_LED
71 | FLASH_LED_DDR = 1<<FLASH_LED_PIN;
72 | #if !FLASH_LED_POLARITY
73 | FLASH_LED_PORT |= 1<<FLASH_LED_PIN;
74 | #endif
75 | #endif
76 |
77 | // Blinken lassen um den Eintritt in den Bootloader zu erkennen
78 | PORTG |= (1<<LEDROT);
79 | PORTG ^= 1<<FLASH_LED_PIN;
80 | _delay_ms(100);
81 | PORTG ^= 1<<FLASH_LED_PIN;
82 | _delay_ms(100);
83 | PORTG ^= 1<<FLASH_LED_PIN;
84 | _delay_ms(100);
85 | PORTG ^= 1<<FLASH_LED_PIN;
86 | PORTG &= ~ (1<<LEDROT);
87 |
88 |
89 | for (i=0; i<8; i++)
90 | ((uint8_t *)¤t_bootldrinfo)[i] = pgm_read_byte_far(FLASHEND - BOOTLDRSIZE - sizeof(bootldrinfo_t) + 1 + i);
91 |
92 | //memcpy_P(¤t_bootldrinfo, (uint8_t*) FLASHEND - BOOTLDRSIZE - sizeof(bootldrinfo_t) + 1, sizeof(bootldrinfo_t));
93 |
94 | if (current_bootldrinfo.app_version == 0xFFFF)
95 | current_bootldrinfo.app_version = 0; //application not flashed yet
96 |
97 | if (fat1216_init() == 0)
98 | {
99 | for (i=0; i<512; i++)
100 | {
101 | startcluster = fat1216_readRootDirEntry(i);
102 |
103 | if (startcluster == 0xFFFF)
104 | continue;
105 |
106 | check_file();
107 | }
108 |
109 | if (updatecluster)
110 | {
111 | for (filesector = 0; filesector < (FLASHEND - BOOTLDRSIZE + 1) / 512; filesector++)
112 | {
113 | #ifdef USE_FLASH_LED
114 | FLASH_LED_PORT ^= 1<<FLASH_LED_PIN;
115 | #endif
116 |
117 | lpword = (uint16_t*) fat_buf;
118 | fat1216_readfilesector(updatecluster, filesector);
119 |
120 | for (i=0; i<(512 / SPM_PAGESIZE); i++)
121 | {
122 | adr = (filesector * 512) + i * SPM_PAGESIZE;
123 | boot_page_erase(adr);
124 | while (boot_rww_busy())
125 | boot_rww_enable();
126 |
127 | for (j=0; j<SPM_PAGESIZE; j+=2)
128 | boot_page_fill(adr + j, *lpword++);
129 |
130 | boot_page_write(adr);
131 | while (boot_rww_busy())
132 | boot_rww_enable();
133 | }
134 | }
135 |
136 | //LED on
137 | #ifdef USE_FLASH_LED
138 | #if FLASH_LED_POLARITY
139 | FLASH_LED_PORT &= ~(1<<FLASH_LED_PIN);
140 | #else
141 | FLASH_LED_PORT |= 1<<FLASH_LED_PIN;
142 | #endif
143 | #endif
144 | }
145 | }
146 |
147 | unsigned short flash_crc = 0xFFFF;
148 |
149 | for (adr=0; adr<FLASHEND - BOOTLDRSIZE + 1; adr++)
150 | flash_crc = _crc_ccitt_update(flash_crc, pgm_read_byte_far(adr));
151 |
152 | if (flash_crc == 0)
153 | {
154 | //Led off
155 | #ifdef USE_FLASH_LED
156 | FLASH_LED_DDR = 0x00;
157 | #endif
158 | PORTG |= (1<<LEDGRUEN);
159 | _delay_ms(1000);
160 | PORTG &= ~(1<<LEDGRUEN);
161 | //EIND = 1;
162 | app_start();
163 | //asm volatile("jmp 0000");
164 | }
165 | else
166 | {
167 | PORTG |= (1<<LEDROT);
168 | _delay_ms(2000);
169 |
170 | }
171 | // Nur zum Testen für den Bestücker
172 | PORTA |= (1<<SOUND);
173 | _delay_ms(2000);
174 | PORTA &= ~(1<<SOUND);
175 | while (1);
176 | }
