1 | ;* RFM01: RB0 = nIRQ (PIC als Ein)
2 | ;* RB2 = SDI (PIC als Aus)
3 | ;* RB3 = nSEL (PIC als Aus)
4 | ;* RB5 = SCK (PIC als Aus)
5 | ;* RA0 = SDO (PIC als Ein)
6 | ;* FSK liegt über 10k an +UB
7 |
8 | ; Includedatei einbinden
9 | list p=16F1827
10 | include <P16F1827.INC>
11 |
12 | ; Makros
13 |
14 | SPI_Kommando Macro Wert1, Wert2
15 | movlw Wert1
16 | movwf spi_tmp1
17 | movlw Wert2
18 | movwf spi_tmp2
19 | call SPI_Senden
20 | endm
21 |
22 | ; Konfiguration festlegen
23 |
24 | __CONFIG _CONFIG1, _BOREN_ON & _CP_OFF & _CPD_OFF & _PWRTE_ON & _WDTE_OFF & _MCLRE_ON & _FOSC_INTOSC
25 | __CONFIG _CONFIG2, _LVP_OFF
26 |
27 | ; Variablen festlegen
28 |
29 | zaehler equ 0x2f
30 |
31 | var_warte1 EQU 0x71
32 | var_warte2 EQU 0x72
33 | spi_tmp1 equ 0x7b
34 | spi_tmp2 equ 0x7c
35 |
36 | ; Konstanten festlegen
37 |
38 |
39 | nSEL equ 3 ; RFM01 Auswahl
40 | nIRQ equ 0 ; RFM01 IRQ
41 |
42 | org 0
43 | goto Prog_Start
44 | org 4
45 | retfie
46 |
47 |
48 |
49 |
50 | Prog_Start
51 | BANKSEL OSCCON
52 | movlw b'01101000' ;4 MHz intern
53 | ;movlw b'01011000' ;1 MHz intern
54 | movwf OSCCON
55 |
56 | BANKSEL PORTB
57 | CLRF PORTB
58 | CLRF PORTA
59 | BANKSEL LATB
60 | CLRF LATB
61 | CLRF LATA
62 | BANKSEL ANSELB
63 | CLRF ANSELB
64 | CLRF ANSELA
65 | BANKSEL TRISB
66 | movlw B'00000001'
67 | movwf TRISB ; SPI RB0 Eingang
68 | movlw B'00000001' ;
69 | movwf TRISA ; SPI RA0 Eingang
70 |
71 | BANKSEL INTCON
72 | bcf INTCON,GIE
73 |
74 |
75 | ; Einstellen SPI
76 |
77 | BANKSEL SSP2ADD
78 | movlw h'09' ; clock = 20/(4*(12+1)) = 385kHz
79 | movwf SSP2ADD ; für I2C
80 | BANKSEL SSP2CON1 ; BANK 4
81 | movlw b'01000000' ; Mode 1,1 SPI, middle of output
82 | movwf SSP2STAT ; time sampling
83 | movlw b'00110001' ; Mode 1,1 SPI Master Mode, 1/16 Tosc bit time
84 | movwf SSP2CON1 ; SSP is on
85 |
86 |
87 | ; RFM01 initialisieren
88 |
89 | BANKSEL PORTB ; BANK 0
90 | movlw d'32'
91 | movwf zaehler
92 | movlw h'20'
93 | movwf FSR0L
94 |
95 |
96 | BANKSEL PORTB
97 | bcf PORTB,nSEL
98 |
99 | movlw D'100'
100 | movwf var_warte
101 | call Warte
102 |
103 |
104 | SPI_Kommando H'00',H'00'
105 | SPI_Kommando H'95',H'7b' ;Configuration: 868MHzband, 12pf, 134kHz bandwidth
106 | SPI_Kommando H'a6',H'86' ;Frequency: MHz
107 | SPI_Kommando H'c8',H'47' ;Datarate: 4,8 kbit
108 | SPI_Kommando H'c6',H'83' ;AFC
109 | SPI_Kommando H'c4',H'ac' ;data filter
110 | SPI_Kommando H'c2',H'e0' ;low batt./ clock divider
111 | SPI_Kommando H'c0',H'42' ;receiver setting:
112 | SPI_Kommando H'e0',H'00' ;wake-up timer:
113 | SPI_Kommando H'cc',H'00' ;low duty cycle:
114 | SPI_Kommando H'ce',H'88' ;fifo config
115 | SPI_Kommando H'ce',H'8b' ;fifo enable
116 | SPI_Kommando H'c0',H'43' ;enable receiver
117 |
118 | Haupt
119 |
120 | ;Warte auf Daten
121 | BANKSEL PORTB ; BANK 0
122 | btfsc PORTB,nIRQ
123 | goto Haupt
124 | BANKSEL SSP2BUF ; BANK 4
125 | movf SSP2BUF,W ; Hole Daten aus SSPBUF
126 | BANKSEL PORTB ; BANK 0
127 | movwf INDF0
128 | incf FSR0L,F
129 | decfsz zaehler
130 | goto Haupt
131 |
132 | SPI_Kommando H'00',h'00' ;read status
133 | SPI_Kommando H'ce',h'88'
134 | SPI_Kommando H'ce',h'8b' ;fifo enable
135 |
136 | ;... irgendwas mit den Daten anstellen
137 |
138 | BANKSEL PORTB ; BANK 0
139 | movlw d'32'
140 | movwf zaehler
141 | movlw h'20'
142 | movwf FSR0L
143 |
144 | goto Haupt
145 |
146 |
147 |
148 | Warte
149 | movlw .110
150 | movwf var_warte2
151 | Warte_w1 nop
152 | nop
153 | nop
154 | nop
155 | nop
156 | nop
157 | decfsz var_warte2, F
158 | goto Warte_w1
159 | decfsz var_warte1, F
160 | goto Warte
161 | return
162 |
163 | SPI_Senden
164 | BANKSEL SSP2BUF ; BANK 4
165 | movfw spi_tmp1
166 | movwf SSP2BUF ; Schreibe in SSPBUF
167 | SPI_Senden_w1
168 | btfss SSP2STAT,BF ; Datentransfer komplett? (Puffer voll?)
169 | goto SPI_Senden_w1 ; wenn nicht, erneut prüfen
170 | movf SSP2BUF,w ; Hole Daten aus SSPBUF
171 | movfw spi_tmp2
172 | movwf SSP2BUF ; Schreibe in SSPBUF
173 | SPI_Senden_w2
174 | btfss SSP2STAT,BF ; Datentransfer komplett? (Puffer voll?)
175 | goto SPI_Senden_w2 ; wenn nicht, erneut prüfen
176 | movf SSP2BUF,w ; Hole Daten aus SSPBUF
177 | return
178 |
179 |
180 |
181 | end
