1 | openocd -f interface/jlink.cfg -f target/stm32f1x.cfg -d
2 | Open On-Chip Debugger 0.5.0 (2011-12-03-10:15)
3 | Licensed under GNU GPL v2
4 | For bug reports, read
5 | http://openocd.berlios.de/doc/doxygen/bugs.html
6 | User : 11 3 command.c:557 command_print(): debug_level: 3
7 | Debug: 12 3 configuration.c:45 add_script_search_dir(): adding /home/tobi/.openocd
8 | Debug: 13 3 configuration.c:45 add_script_search_dir(): adding /usr/share/openocd/site
9 | Debug: 14 3 configuration.c:45 add_script_search_dir(): adding /usr/share/openocd/scripts
10 | Debug: 15 3 configuration.c:87 find_file(): found /usr/share/openocd/scripts/interface/jlink.cfg
11 | Debug: 16 3 command.c:151 script_debug(): command - ocd_command ocd_command type ocd_interface jlink
12 | Debug: 17 4 command.c:151 script_debug(): command - interface ocd_interface jlink
13 | Debug: 19 4 command.c:364 register_command_handler(): registering 'ocd_jlink'...
14 | Debug: 20 4 command.c:364 register_command_handler(): registering 'ocd_jlink'...
15 | Debug: 21 4 command.c:364 register_command_handler(): registering 'ocd_jlink'...
16 | Debug: 22 4 command.c:364 register_command_handler(): registering 'ocd_jlink'...
17 | Debug: 23 4 command.c:364 register_command_handler(): registering 'ocd_jlink'...
18 | Debug: 24 4 command.c:364 register_command_handler(): registering 'ocd_jlink'...
19 | Debug: 25 4 command.c:364 register_command_handler(): registering 'ocd_jlink'...
20 | Debug: 26 4 command.c:364 register_command_handler(): registering 'ocd_jlink'...
21 | Debug: 27 4 command.c:364 register_command_handler(): registering 'ocd_jlink'...
22 | Debug: 28 4 command.c:364 register_command_handler(): registering 'ocd_jlink'...
23 | Debug: 29 4 command.c:364 register_command_handler(): registering 'ocd_jlink'...
24 | Warn : 30 4 adapter.c:167 handle_interface_command(): Adapter driver 'jlink' did not declare which transports it allows; assuming legacy JTAG-only
25 | Info : 31 4 transport.c:123 allow_transports(): only one transport option; autoselect 'jtag'
26 | Debug: 32 4 command.c:364 register_command_handler(): registering 'ocd_jtag_flush_queue_sleep'...
27 | Debug: 33 4 command.c:364 register_command_handler(): registering 'ocd_jtag_rclk'...
28 | Debug: 34 4 command.c:364 register_command_handler(): registering 'ocd_jtag_ntrst_delay'...
29 | Debug: 35 4 command.c:364 register_command_handler(): registering 'ocd_jtag_ntrst_assert_width'...
30 | Debug: 36 5 command.c:364 register_command_handler(): registering 'ocd_scan_chain'...
31 | Debug: 37 5 command.c:364 register_command_handler(): registering 'ocd_jtag_reset'...
32 | Debug: 38 5 command.c:364 register_command_handler(): registering 'ocd_runtest'...
33 | Debug: 39 5 command.c:364 register_command_handler(): registering 'ocd_irscan'...
34 | Debug: 40 5 command.c:364 register_command_handler(): registering 'ocd_verify_ircapture'...
35 | Debug: 41 5 command.c:364 register_command_handler(): registering 'ocd_verify_jtag'...
36 | Debug: 42 5 command.c:364 register_command_handler(): registering 'ocd_tms_sequence'...
37 | Debug: 43 5 command.c:364 register_command_handler(): registering 'ocd_wait_srst_deassert'...
38 | Debug: 44 5 command.c:364 register_command_handler(): registering 'ocd_jtag'...
39 | Debug: 45 5 command.c:364 register_command_handler(): registering 'ocd_jtag'...
40 | Debug: 46 5 command.c:364 register_command_handler(): registering 'ocd_jtag'...
41 | Debug: 47 5 command.c:364 register_command_handler(): registering 'ocd_jtag'...
42 | Debug: 48 5 command.c:364 register_command_handler(): registering 'ocd_jtag'...
43 | Debug: 49 5 command.c:364 register_command_handler(): registering 'ocd_jtag'...
44 | Debug: 50 5 command.c:364 register_command_handler(): registering 'ocd_jtag'...
45 | Debug: 51 5 command.c:364 register_command_handler(): registering 'ocd_jtag'...
46 | Debug: 52 5 command.c:364 register_command_handler(): registering 'ocd_jtag'...
47 | Debug: 53 5 command.c:364 register_command_handler(): registering 'ocd_jtag'...
48 | Debug: 54 6 command.c:364 register_command_handler(): registering 'ocd_jtag'...
49 | Debug: 55 6 command.c:364 register_command_handler(): registering 'ocd_jtag'...
50 | Debug: 56 6 command.c:364 register_command_handler(): registering 'ocd_jtag'...
51 | Debug: 57 6 command.c:364 register_command_handler(): registering 'ocd_svf'...
52 | Debug: 58 6 command.c:364 register_command_handler(): registering 'ocd_xsvf'...
53 | Debug: 59 6 configuration.c:87 find_file(): found /usr/share/openocd/scripts/target/stm32f1x.cfg
54 | Debug: 60 6 command.c:151 script_debug(): command - ocd_command ocd_command type ocd_adapter_khz 1000
55 | Debug: 61 6 command.c:151 script_debug(): command - adapter_khz ocd_adapter_khz 1000
56 | Debug: 63 6 core.c:1639 jtag_config_khz(): handle jtag khz
57 | Debug: 64 6 core.c:1602 adapter_khz_to_speed(): convert khz to interface specific speed value
58 | Debug: 65 6 core.c:1602 adapter_khz_to_speed(): convert khz to interface specific speed value
59 | User : 66 7 command.c:557 command_print(): 1000 kHz
60 | Debug: 67 7 command.c:151 script_debug(): command - ocd_command ocd_command type ocd_adapter_nsrst_delay 100
61 | Debug: 68 7 command.c:151 script_debug(): command - adapter_nsrst_delay ocd_adapter_nsrst_delay 100
62 | User : 70 7 command.c:557 command_print(): adapter_nsrst_delay: 100
63 | Debug: 71 7 command.c:151 script_debug(): command - ocd_command ocd_command type ocd_jtag_ntrst_delay 100
64 | Debug: 72 7 command.c:151 script_debug(): command - jtag_ntrst_delay ocd_jtag_ntrst_delay 100
65 | User : 74 7 command.c:557 command_print(): jtag_ntrst_delay: 100
66 | Debug: 75 7 command.c:151 script_debug(): command - ocd_command ocd_command type ocd_jtag newtap stm32 cpu -irlen 4 -ircapture 0x1 -irmask 0xf -expected-id 0x3ba00477
67 | Debug: 76 7 command.c:151 script_debug(): command - ocd_jtag ocd_jtag newtap stm32 cpu -irlen 4 -ircapture 0x1 -irmask 0xf -expected-id 0x3ba00477
68 | Debug: 77 7 tcl.c:575 jim_newtap_cmd(): Creating New Tap, Chip: stm32, Tap: cpu, Dotted: stm32.cpu, 8 params
69 | Debug: 78 7 tcl.c:592 jim_newtap_cmd(): Processing option: -irlen
70 | Debug: 79 7 tcl.c:592 jim_newtap_cmd(): Processing option: -ircapture
71 | Debug: 80 7 tcl.c:592 jim_newtap_cmd(): Processing option: -irmask
72 | Debug: 81 7 tcl.c:592 jim_newtap_cmd(): Processing option: -expected-id
73 | Debug: 82 7 core.c:1337 jtag_tap_init(): Created Tap: stm32.cpu @ abs position 0, irlen 4, capture: 0x1 mask: 0xf
74 | Debug: 83 8 command.c:151 script_debug(): command - ocd_command ocd_command type ocd_jtag newtap stm32 bs -irlen 5 -expected-id 0x06412041 -expected-id 0x06410041 -expected-id 0x16410041 -expected-id 0x06420041 -expected-id 0x06414041 -expected-id 0x06418041 -expected-id 0x06430041
75 | Debug: 84 8 command.c:151 script_debug(): command - ocd_jtag ocd_jtag newtap stm32 bs -irlen 5 -expected-id 0x06412041 -expected-id 0x06410041 -expected-id 0x16410041 -expected-id 0x06420041 -expected-id 0x06414041 -expected-id 0x06418041 -expected-id 0x06430041
76 | Debug: 85 8 tcl.c:575 jim_newtap_cmd(): Creating New Tap, Chip: stm32, Tap: bs, Dotted: stm32.bs, 16 params
77 | Debug: 86 8 tcl.c:592 jim_newtap_cmd(): Processing option: -irlen
78 | Debug: 87 8 tcl.c:592 jim_newtap_cmd(): Processing option: -expected-id
79 | Debug: 88 8 tcl.c:592 jim_newtap_cmd(): Processing option: -expected-id
80 | Debug: 89 8 tcl.c:592 jim_newtap_cmd(): Processing option: -expected-id
81 | Debug: 90 8 tcl.c:592 jim_newtap_cmd(): Processing option: -expected-id
82 | Debug: 91 8 tcl.c:592 jim_newtap_cmd(): Processing option: -expected-id
83 | Debug: 92 8 tcl.c:592 jim_newtap_cmd(): Processing option: -expected-id
84 | Debug: 93 8 tcl.c:592 jim_newtap_cmd(): Processing option: -expected-id
85 | Debug: 94 8 core.c:1337 jtag_tap_init(): Created Tap: stm32.bs @ abs position 0, irlen 5, capture: 0x1 mask: 0x3
86 | Debug: 95 8 command.c:151 script_debug(): command - ocd_command ocd_command type ocd_target create stm32.cpu cortex_m3 -endian little -chain-position stm32.cpu
87 | Debug: 96 8 command.c:151 script_debug(): command - ocd_target ocd_target create stm32.cpu cortex_m3 -endian little -chain-position stm32.cpu
88 | Debug: 97 8 command.c:364 register_command_handler(): registering 'ocd_arm'...
89 | Debug: 98 9 command.c:364 register_command_handler(): registering 'ocd_arm'...
90 | Debug: 99 9 command.c:364 register_command_handler(): registering 'ocd_arm'...
91 | Debug: 100 9 command.c:364 register_command_handler(): registering 'ocd_arm'...
92 | Debug: 101 9 command.c:364 register_command_handler(): registering 'ocd_arm'...
93 | Debug: 102 9 command.c:364 register_command_handler(): registering 'ocd_arm'...
94 | Debug: 103 9 command.c:364 register_command_handler(): registering 'ocd_dap'...
95 | Debug: 104 9 command.c:364 register_command_handler(): registering 'ocd_dap'...
96 | Debug: 105 9 command.c:364 register_command_handler(): registering 'ocd_dap'...
97 | Debug: 106 9 command.c:364 register_command_handler(): registering 'ocd_dap'...
98 | Debug: 107 9 command.c:364 register_command_handler(): registering 'ocd_dap'...
99 | Debug: 108 9 command.c:364 register_command_handler(): registering 'ocd_cortex_m3'...
100 | Debug: 109 9 command.c:364 register_command_handler(): registering 'ocd_cortex_m3'...
101 | Debug: 110 9 command.c:364 register_command_handler(): registering 'ocd_cortex_m3'...
102 | Debug: 111 9 command.c:364 register_command_handler(): registering 'ocd_stm32.cpu'...
103 | Debug: 112 9 command.c:364 register_command_handler(): registering 'ocd_stm32.cpu'...
104 | Debug: 113 9 command.c:364 register_command_handler(): registering 'ocd_stm32.cpu'...
105 | Debug: 114 9 command.c:364 register_command_handler(): registering 'ocd_stm32.cpu'...
106 | Debug: 115 9 command.c:364 register_command_handler(): registering 'ocd_stm32.cpu'...
107 | Debug: 116 10 command.c:364 register_command_handler(): registering 'ocd_stm32.cpu'...
108 | Debug: 117 10 command.c:364 register_command_handler(): registering 'ocd_stm32.cpu'...
109 | Debug: 118 10 command.c:364 register_command_handler(): registering 'ocd_stm32.cpu'...
110 | Debug: 119 10 command.c:364 register_command_handler(): registering 'ocd_stm32.cpu'...
111 | Debug: 120 10 command.c:364 register_command_handler(): registering 'ocd_stm32.cpu'...
112 | Debug: 121 10 command.c:364 register_command_handler(): registering 'ocd_stm32.cpu'...
113 | Debug: 122 10 command.c:364 register_command_handler(): registering 'ocd_stm32.cpu'...
114 | Debug: 123 10 command.c:364 register_command_handler(): registering 'ocd_stm32.cpu'...
115 | Debug: 124 10 command.c:364 register_command_handler(): registering 'ocd_stm32.cpu'...
116 | Debug: 125 10 command.c:364 register_command_handler(): registering 'ocd_stm32.cpu'...
117 | Debug: 126 10 command.c:364 register_command_handler(): registering 'ocd_stm32.cpu'...
118 | Debug: 127 10 command.c:364 register_command_handler(): registering 'ocd_stm32.cpu'...
119 | Debug: 128 10 command.c:364 register_command_handler(): registering 'ocd_stm32.cpu'...
120 | Debug: 129 10 command.c:364 register_command_handler(): registering 'ocd_stm32.cpu'...
121 | Debug: 130 10 command.c:364 register_command_handler(): registering 'ocd_stm32.cpu'...
122 | Debug: 131 10 command.c:364 register_command_handler(): registering 'ocd_stm32.cpu'...
123 | Debug: 132 10 command.c:364 register_command_handler(): registering 'ocd_stm32.cpu'...
124 | Debug: 133 10 command.c:364 register_command_handler(): registering 'ocd_stm32.cpu'...
125 | Debug: 134 10 command.c:364 register_command_handler(): registering 'ocd_stm32.cpu'...
126 | Debug: 135 10 command.c:364 register_command_handler(): registering 'ocd_stm32.cpu'...
127 | Debug: 136 10 command.c:364 register_command_handler(): registering 'ocd_stm32.cpu'...
128 | Debug: 137 10 command.c:364 register_command_handler(): registering 'ocd_stm32.cpu'...
129 | Debug: 138 10 command.c:364 register_command_handler(): registering 'ocd_stm32.cpu'...
130 | Debug: 139 10 command.c:364 register_command_handler(): registering 'ocd_stm32.cpu'...
131 | Debug: 140 10 command.c:364 register_command_handler(): registering 'ocd_stm32.cpu'...
132 | Debug: 141 10 command.c:364 register_command_handler(): registering 'ocd_stm32.cpu'...
133 | Debug: 142 10 command.c:364 register_command_handler(): registering 'ocd_stm32.cpu'...
134 | Debug: 143 10 command.c:364 register_command_handler(): registering 'ocd_stm32.cpu'...
135 | Debug: 144 10 command.c:364 register_command_handler(): registering 'ocd_stm32.cpu'...
136 | Debug: 145 10 command.c:364 register_command_handler(): registering 'ocd_stm32.cpu'...
137 | Debug: 146 10 command.c:364 register_command_handler(): registering 'ocd_stm32.cpu'...
138 | Debug: 147 10 command.c:151 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu configure -work-area-phys 0x20000000 -work-area-size 0x4000 -work-area-backup 0
139 | Debug: 148 11 command.c:151 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu configure -work-area-phys 0x20000000 -work-area-size 0x4000 -work-area-backup 0
140 | Debug: 149 11 command.c:151 script_debug(): command - ocd_command ocd_command type ocd_flash bank stm32.flash stm32f1x 0x08000000 0 0 0 stm32.cpu
141 | Debug: 150 11 command.c:151 script_debug(): command - ocd_flash ocd_flash bank stm32.flash stm32f1x 0x08000000 0 0 0 stm32.cpu
142 | Debug: 152 11 command.c:364 register_command_handler(): registering 'ocd_stm32f1x'...
143 | Debug: 153 11 command.c:364 register_command_handler(): registering 'ocd_stm32f1x'...
144 | Debug: 154 11 command.c:364 register_command_handler(): registering 'ocd_stm32f1x'...
145 | Debug: 155 11 command.c:364 register_command_handler(): registering 'ocd_stm32f1x'...
146 | Debug: 156 11 command.c:364 register_command_handler(): registering 'ocd_stm32f1x'...
147 | Debug: 157 11 command.c:151 script_debug(): command - ocd_command ocd_command type ocd_cortex_m3 reset_config sysresetreq
148 | Debug: 158 11 command.c:151 script_debug(): command - ocd_cortex_m3 ocd_cortex_m3 reset_config sysresetreq
149 | User : 160 11 command.c:557 command_print(): cortex_m3 reset_config sysresetreq
150 | Debug: 161 11 command.c:151 script_debug(): command - ocd_command ocd_command type ocd_init
151 | Debug: 162 11 command.c:151 script_debug(): command - init ocd_init
152 | Debug: 164 11 command.c:151 script_debug(): command - ocd_command ocd_command type ocd_target init
153 | Debug: 165 11 command.c:151 script_debug(): command - ocd_target ocd_target init
154 | Debug: 167 11 target.c:930 handle_target_init_command(): Initializing targets...
155 | Debug: 168 11 command.c:364 register_command_handler(): registering 'ocd_target_request'...
156 | Debug: 169 11 command.c:364 register_command_handler(): registering 'ocd_trace'...
157 | Debug: 170 11 command.c:364 register_command_handler(): registering 'ocd_trace'...
158 | Debug: 171 11 command.c:364 register_command_handler(): registering 'ocd_fast_load_image'...
159 | Debug: 172 11 command.c:364 register_command_handler(): registering 'ocd_fast_load'...
160 | Debug: 173 11 command.c:364 register_command_handler(): registering 'ocd_profile'...
161 | Debug: 174 11 command.c:364 register_command_handler(): registering 'ocd_virt2phys'...
162 | Debug: 175 11 command.c:364 register_command_handler(): registering 'ocd_reg'...
163 | Debug: 176 11 command.c:364 register_command_handler(): registering 'ocd_poll'...
164 | Debug: 177 11 command.c:364 register_command_handler(): registering 'ocd_wait_halt'...
165 | Debug: 178 11 command.c:364 register_command_handler(): registering 'ocd_halt'...
166 | Debug: 179 11 command.c:364 register_command_handler(): registering 'ocd_resume'...
167 | Debug: 180 11 command.c:364 register_command_handler(): registering 'ocd_reset'...
168 | Debug: 181 11 command.c:364 register_command_handler(): registering 'ocd_soft_reset_halt'...
169 | Debug: 182 11 command.c:364 register_command_handler(): registering 'ocd_step'...
170 | Debug: 183 11 command.c:364 register_command_handler(): registering 'ocd_mdw'...
171 | Debug: 184 11 command.c:364 register_command_handler(): registering 'ocd_mdh'...
172 | Debug: 185 11 command.c:364 register_command_handler(): registering 'ocd_mdb'...
173 | Debug: 186 11 command.c:364 register_command_handler(): registering 'ocd_mww'...
174 | Debug: 187 11 command.c:364 register_command_handler(): registering 'ocd_mwh'...
175 | Debug: 188 11 command.c:364 register_command_handler(): registering 'ocd_mwb'...
176 | Debug: 189 11 command.c:364 register_command_handler(): registering 'ocd_bp'...
177 | Debug: 190 11 command.c:364 register_command_handler(): registering 'ocd_rbp'...
178 | Debug: 191 11 command.c:364 register_command_handler(): registering 'ocd_wp'...
179 | Debug: 192 11 command.c:364 register_command_handler(): registering 'ocd_rwp'...
180 | Debug: 193 11 command.c:364 register_command_handler(): registering 'ocd_load_image'...
181 | Debug: 194 11 command.c:364 register_command_handler(): registering 'ocd_dump_image'...
182 | Debug: 195 11 command.c:364 register_command_handler(): registering 'ocd_verify_image'...
183 | Debug: 196 11 command.c:364 register_command_handler(): registering 'ocd_test_image'...
184 | Debug: 197 11 command.c:364 register_command_handler(): registering 'ocd_reset_nag'...
185 | Debug: 198 499 jlink.c:1469 jlink_usb_open(): usb ep in 81
186 | Debug: 199 499 jlink.c:1469 jlink_usb_open(): usb ep out 02
187 | Info : 200 499 jlink.c:424 jlink_init(): J-Link initialization started / target CPU reset initiated
188 | Info : 201 505 jlink.c:798 jlink_get_version_info(): J-Link ARM V8 compiled May 20 2010 17:07:46
189 | Info : 202 507 jlink.c:811 jlink_get_version_info(): J-Link caps 0xb9ff7bbf
190 | Info : 203 509 jlink.c:831 jlink_get_version_info(): J-Link hw version 80000
191 | Info : 204 509 jlink.c:836 jlink_get_version_info(): J-Link hw type J-Link
192 | Info : 205 511 jlink.c:852 jlink_get_version_info(): J-Link max mem block 9464
193 | Info : 206 514 jlink.c:712 jlink_config_dump(): J-Link configuration
194 | Info : 207 514 jlink.c:671 jlink_config_usb_address_dump(): USB-Address: 0xff
195 | Info : 208 514 jlink.c:680 jlink_config_kickstart_dump(): Kickstart power on JTAG-pin 19: 0xffffffff
196 | Info : 209 516 jlink.c:638 jlink_get_status(): Vref = 3.267 TCK = 1 TDI = 0 TDO = 1 TMS = 0 SRST = 0 TRST = 0
197 | Info : 210 516 jlink.c:437 jlink_init(): J-Link JTAG Interface ready
198 | Debug: 211 516 jlink.c:583 jlink_reset(): trst: 0, srst: 0
199 | Debug: 213 524 core.c:1602 adapter_khz_to_speed(): convert khz to interface specific speed value
200 | Debug: 214 524 core.c:1606 adapter_khz_to_speed(): have interface set up
201 | Debug: 215 525 core.c:1602 adapter_khz_to_speed(): convert khz to interface specific speed value
202 | Debug: 216 525 core.c:1606 adapter_khz_to_speed(): have interface set up
203 | Info : 217 525 core.c:1421 adapter_init(): clock speed 1000 kHz
204 | Debug: 218 525 openocd.c:137 handle_init_command(): Debug Adapter init complete
205 | Debug: 219 525 command.c:151 script_debug(): command - ocd_command ocd_command type ocd_transport init
206 | Debug: 220 525 command.c:151 script_debug(): command - ocd_transport ocd_transport init
207 | Debug: 222 525 transport.c:255 handle_transport_init(): handle_transport_init
208 | Debug: 223 525 jlink.c:583 jlink_reset(): trst: 0, srst: 0
209 | Debug: 224 527 core.c:713 jtag_add_reset(): SRST line released
210 | Debug: 225 527 core.c:737 jtag_add_reset(): TRST line released
211 | Debug: 226 527 core.c:329 jtag_call_event_callbacks(): jtag event: TAP reset
212 | Debug: 227 730 command.c:151 script_debug(): command - ocd_command ocd_command type ocd_jtag arp_init
213 | Debug: 228 730 command.c:151 script_debug(): command - ocd_jtag ocd_jtag arp_init
214 | Debug: 229 730 core.c:1435 jtag_init_inner(): Init JTAG chain
215 | Debug: 230 730 core.c:329 jtag_call_event_callbacks(): jtag event: TAP reset
216 | Debug: 231 733 core.c:1055 jtag_examine_chain(): DR scan interrogation for IDCODE/BYPASS
217 | Debug: 232 733 core.c:329 jtag_call_event_callbacks(): jtag event: TAP reset
218 | Info : 233 736 core.c:955 jtag_examine_chain_display(): JTAG tap: stm32.cpu tap/device found: 0x3ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x3)
219 | Info : 234 736 core.c:955 jtag_examine_chain_display(): JTAG tap: stm32.bs tap/device found: 0x06418041 (mfg: 0x020, part: 0x6418, ver: 0x0)
220 | Debug: 235 736 core.c:1219 jtag_validate_ircapture(): IR capture validation scan
221 | Debug: 236 739 core.c:1280 jtag_validate_ircapture(): stm32.cpu: IR capture 0x01
222 | Debug: 237 739 core.c:1280 jtag_validate_ircapture(): stm32.bs: IR capture 0x01
223 | Debug: 238 739 openocd.c:150 handle_init_command(): Examining targets...
224 | Debug: 239 739 arm_adi_v5.c:987 ahbap_debugport_init():
