1 | uint16_t SPI_MASTER_Buffer_Rx[64];
2 | uint16_t SPI_MASTER_Buffer_Tx[2];
3 |
4 |
5 | static void SPI_Config(void)
6 | {
7 | GPIO_InitTypeDef GPIO_InitStructure;
8 | NVIC_InitTypeDef NVIC_InitStructure;
9 |
10 | /* Enable the SPI clock */
11 | SPIx_CLK_INIT(SPIx_CLK, ENABLE);
12 |
13 | /* Enable GPIO clocks */
14 | RCC_AHB1PeriphClockCmd(SPIx_SCK_GPIO_CLK | SPIx_MISO_GPIO_CLK | SPIx_MOSI_GPIO_CLK, ENABLE);
15 |
16 | /* Connect SPI pins to AF5 */
17 | GPIO_PinAFConfig(SPIx_SCK_GPIO_PORT, SPIx_SCK_SOURCE, SPIx_SCK_AF);
18 | GPIO_PinAFConfig(SPIx_MOSI_GPIO_PORT, SPIx_MOSI_SOURCE, SPIx_MOSI_AF);
19 | GPIO_PinAFConfig(SPIx_MISO_GPIO_PORT, SPIx_MISO_SOURCE, SPIx_MISO_AF);
20 |
21 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
22 | GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
23 | GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
24 | GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
25 |
26 | /* SPI SCK pin configuration */
27 | GPIO_InitStructure.GPIO_Pin = SPIx_SCK_PIN;
28 | GPIO_Init(SPIx_SCK_GPIO_PORT, &GPIO_InitStructure);
29 |
30 | /* SPI MOSI pin configuration */
31 | GPIO_InitStructure.GPIO_Pin = SPIx_MOSI_PIN;
32 | GPIO_Init(SPIx_MOSI_GPIO_PORT, &GPIO_InitStructure);
33 |
34 | /* SPI MISO pin configuration */
35 | GPIO_InitStructure.GPIO_Pin = SPIx_MISO_PIN;
36 | GPIO_Init(SPIx_MISO_GPIO_PORT, &GPIO_InitStructure);
37 |
38 | /* SPI configuration -------------------------------------------------------*/
39 | SPI_I2S_DeInit(SPIx);
40 | SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
41 | SPI_InitStructure.SPI_DataSize = SPI_DataSize_16b;
42 | SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
43 | SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
44 | SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
45 | SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_2;
46 | SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
47 | SPI_InitStructure.SPI_CRCPolynomial = 7;
48 | SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
49 |
50 | SPI_Init(SPIx, &SPI_InitStructure);
51 |
52 | /* Configure the Priority Group to 1 bit */
53 | NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
54 | /* Configure the SPI interrupt priority */
55 | NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
56 | NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
57 | NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
58 | NVIC_InitStructure.NVIC_IRQChannel = SPI_DMA_RX_IRQn;
59 | NVIC_Init(&NVIC_InitStructure);
60 |
61 | SPI_I2S_DMACmd(SPI2, SPI_I2S_DMAReq_Rx, ENABLE);
62 |
63 | /* The Data transfer is performed in the SPI interrupt routine */
64 | /* Enable the SPI peripheral */
65 | SPI_Cmd(SPIx, ENABLE);
66 | }
67 |
68 | void DMA_Config(void)
69 | {
70 | /* Dma config */
71 | RCC_AHB1PeriphClockCmd(SPI_DMAx_CLK, ENABLE);
72 |
73 | /* DMA RX */
74 | DMA_StructInit(&DMA_InitStructure);
75 | DMA_DeInit(SPI_RX_DMA_STREAM);
76 | DMA_InitStructure.DMA_PeripheralBaseAddr = SPI_DR_ADDRESS;
77 | DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
78 | DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
79 | DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
80 | DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
81 | DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
82 | DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Enable;
83 | DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_Full;
84 | DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
85 | DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
86 | DMA_InitStructure.DMA_Priority = DMA_Priority_Medium;
87 | DMA_InitStructure.DMA_Channel = SPI_RX_DMA_CHANNEL;
88 | DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
89 | DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)SPI_MASTER_Buffer_Rx;
90 | DMA_InitStructure.DMA_BufferSize = 64;
91 | DMA_Init(SPI_RX_DMA_STREAM, &DMA_InitStructure);
92 |
93 | DMA_Cmd(SPI_RX_DMA_STREAM, ENABLE);
94 |
95 | /* DMA TX */
96 | DMA_StructInit(&DMA_InitStructure);
97 | DMA_DeInit(SPI_TX_DMA_STREAM);
98 | DMA_InitStructure.DMA_PeripheralBaseAddr = SPI_DR_ADDRESS;
99 | DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
100 | DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
101 | DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
102 | DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
103 | DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
104 | DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Enable;
105 | DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_Full;
106 | DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
107 | DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
108 | DMA_InitStructure.DMA_Priority = DMA_Priority_Medium;
109 | DMA_InitStructure.DMA_Channel = SPI_TX_DMA_CHANNEL;
110 | DMA_InitStructure.DMA_DIR = DMA_DIR_MemoryToPeripheral;
111 | DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)SPI_MASTER_EmptyBuffer_Tx;
112 | DMA_InitStructure.DMA_BufferSize = 2;
113 | DMA_Init(SPI_TX_DMA_STREAM, &DMA_InitStructure);
114 |
115 | DMA_Cmd(SPI_TX_DMA_STREAM, ENABLE);
116 |
117 | DMA_ITConfig(SPI_RX_DMA_STREAM, DMA_IT_TC | DMA_IT_TE | DMA_IT_FE , ENABLE);
118 | }
