1 | ; Notes:
2 | ; Pin Connections
3 | ; RB0-RB7 Data Port
4 | ; RA0 RS
5 | ; RA1 R/W
6 | ; RA2 E
7 | ; *
8 | ; *
9 | ;**********************************************************************
10 |
11 | list p=16F628A
12 | #include <p16F628A.inc>
13 |
14 | errorlevel -302 ; suppress message 302 from list file
15 |
16 | __CONFIG _CP_OFF & DATA_CP_OFF & _LVP_OFF & _BOREN_OFF & _MCLRE_ON & _WDT_OFF & _PWRTE_ON & _XT_OSC
17 |
18 | ;**********************************************************************
19 | ; VARIABLE DEFINITIONS
20 | ;**********************************************************************
21 |
22 | VAR UDATA 0x22
23 | loops RES 1
24 | loops1 RES 1
25 | Temp RES 1
26 | Lcd_Data RES 1
27 | Lcd_Status RES 1
28 |
29 | ;**********************************************************************
30 | ; EQU Befehle
31 | ;**********************************************************************
32 | Lcd_RS equ RA0
33 | Lcd_RW equ RA1
34 | Lcd_E equ RA2
35 | Lcd_Line equ PORTB
36 | Lcd_Cont equ PORTA
37 |
38 | ;**********************************************************************
39 | ; MAIN PROGRAM
40 | ;**********************************************************************
41 |
42 | MAIN_PROG CODE
43 |
44 | START
45 | bcf STATUS, C
46 | clrf PORTA
47 | clrf PORTB
48 | call IniReg
49 | call IniLcd
50 |
51 |
52 |
53 | Main
54 | goto Main
55 |
56 |
57 |
58 | ;**********************************************************************
59 | ; SUBROUTINES
60 | ;**********************************************************************
61 | ;Zeitverzögerung um loops * 1 ms
62 | ; 4MHz externer Takt bedeutet 1MHz interner Takt
63 | ; also dauert 1 ms genau 1000 Befehle
64 | ; 110 Schleifen a 9 Befehle sind 990 Befehle = 0.99 ms
65 | ; die restlichen 10 Befehle für Einsprung und Rücksprung
66 | Wait
67 | top movlw .110 ; timing adjustment variable (1ms)
68 | movwf loops1
69 | top2 nop ; sit and wait
70 | nop
71 | nop
72 | nop
73 | nop
74 | nop
75 | decfsz loops1, F ; inner loops complete?
76 | goto top2 ; no, go again
77 | ;
78 | decfsz loops, F ; outer loops complete?
79 | goto top ; no, go again
80 | return ; yes, return from subWAIT
81 | ;**********************************************************************
82 | ;Steuerbyte 8-bittig übertragen
83 | Lcd_ContSend
84 | movwf Lcd_Data
85 | call LcdBusy
86 | movf Lcd_Data,w
87 | movwf Lcd_Line
88 | bcf Lcd_Cont, Lcd_RW
89 | bcf Lcd_Cont, Lcd_RS
90 | bsf Lcd_Cont, Lcd_E
91 | nop
92 | bcf Lcd_Cont, Lcd_E
93 | movlw D'50'
94 | movwf loops
95 | call Wait
96 | return
97 | ;**********************************************************************
98 | ;Datenbyte 8-bittig übertragen
99 | Lcd_DataSend
100 | movwf Lcd_Data
101 | call LcdBusy
102 | movf Lcd_Data,w
103 | movwf Lcd_Line
104 | bcf Lcd_Cont, Lcd_RW
105 | bsf Lcd_Cont, Lcd_RS
106 | bsf Lcd_Cont, Lcd_E
107 | nop
108 | bcf Lcd_Cont, Lcd_E
109 | movlw D'50'
110 | movwf loops
111 | call Wait
112 | return
113 | ;**********************************************************************
114 | ; darauf warten, daß das Display bereit zur Datenannahme ist
115 | LcdBusy
116 | banksel TRISB
117 | movlw B'11111111'
118 | movwf TRISB
119 | banksel PORTB
120 | BusyLoop
121 | bcf Lcd_Cont, Lcd_RS
122 | bsf Lcd_Cont, Lcd_RW ; Lesen
123 | bsf Lcd_Cont, Lcd_E
124 | nop
125 | movf Lcd_Line, w
126 | movwf Lcd_Status
127 | bcf Lcd_Cont, Lcd_E
128 | nop
129 | bsf Lcd_Cont, Lcd_E ; Enable
130 | nop
131 | bcf Lcd_Cont, Lcd_E
132 | btfsc Lcd_Status, 7 ; teste bit 7
133 | goto BusyLoop
134 | bcf Lcd_Cont, Lcd_RW
135 | banksel TRISB
136 | movlw B'00000000'
137 | movwf TRISB
138 | banksel PORTB
139 | return
140 | ;**********************************************************************
141 | ;Iinitialisierung der Resgister
142 | IniReg
143 | bcf STATUS,C
144 | banksel OPTION_REG ;Bank1
145 | movlw B'00000010' ; pull-up enalbled
146 | movwf OPTION_REG
147 | movlw B'00000000' ;PortA RA0-RA2 Output
148 | movwf TRISA
149 | movlw B'00000000' ;PortB Outputs
150 | movwf TRISB
151 | movlw B'00000000' ;
152 | movwf PIE1
153 | movlw B'00000011' ;
154 | movwf PCON
155 | movlw B'00000010' ;
156 | movwf TXSTA
157 | movlw B'00000000' ;
158 | movwf EECON1
159 | movlw B'00000000' ;
160 | movwf VRCON
161 | banksel TMR0 ;Bank 0
162 | movlw B'00000000'
163 | movwf PORTA
164 | movlw B'00000000'
165 | movwf PORTB
166 | movlw B'00000000' ;
167 | movwf INTCON
168 | movlw B'00010000' ;
169 | movwf PIR1
170 | movlw B'00000000' ;
171 | movwf T1CON
172 | movlw B'00000000' ;
173 | movwf T2CON
174 | movlw B'00000000' ;
175 | movwf CCP1CON
176 | movlw B'00000000' ;
177 | movwf RCSTA
178 | movlw B'00000111' ;
179 | movwf CMCON
180 | return
181 | ;**********************************************************
182 | ; Initialisierung des LCD-Displays
183 |
184 | IniLcd
185 | movlw D'250' ; 250 ms Pause nach dem Einschalten
186 | movwf loops
187 | call Wait
188 |
189 | movlw B'00110000' ; 1
190 | movwf Lcd_Line
191 | bsf Lcd_Cont, Lcd_E
192 | nop
193 | bcf Lcd_Cont, Lcd_E
194 |
195 | movlw D'100' ; 100 ms Pause
196 | movwf loops
197 | call Wait
198 |
199 | movlw B'00110000' ; 2
200 | call Lcd_ContSend
201 | movlw B'00110000' ; 3
202 | call Lcd_ContSend
203 |
204 | movlw B'00000001' ; löschen und cusor home
205 | call Lcd_ContSend
206 | movlw B'00111000' ; 5 function set, 8-bit 2-zeilig, 5x7
207 | call Lcd_ContSend
208 | movlw B'00001000' ; 6 display off
209 | call Lcd_ContSend
210 | movlw B'00000110' ; 7 entry mode, increment, disable display-shift
211 | call Lcd_ContSend
212 | movlw B'00000011' ; 8 cursor home, cursor home
213 | call Lcd_ContSend
214 | movlw B'00001111' ; 9 display on
215 | call Lcd_ContSend
216 | return
217 |
218 |
219 | ;**********************************************************************
220 | ; END OF PROGRAM
221 | ;**********************************************************************
222 |
223 | END
