Hallo, kennt jemand ein gutes Beispiel wie man den CAN auf dem Discovery configuriert?
Hab das soweit konfiguriert das im loopback modus auch wieder das zurück kommt, was ich gesendet habe. Aber im Normalen Modus wenn ich den RX und TX pin verbinde passiert nichts. Woran kann das liegen? Hier mein Code
1 | /* Includes */
2 | #include "stm32f4xx.h" |
3 | #include "stm32f4_discovery.h" |
4 | |
5 | /* Private macro */
6 | /* Private variables */
7 | CAN_InitTypeDef CAN_InitStructure; |
8 | CAN_FilterInitTypeDef CAN_FilterInitStructure; |
9 | CanTxMsg TxMessage; |
10 | CanRxMsg RxMessage; |
11 | /* Private function prototypes */
12 | void CAN_Config(void); |
13 | void NVIC_Config(void); |
14 | /* Private functions */
15 | //Pin definitions
16 | |
17 | #define CAN_RX_PIN GPIO_Pin_0
18 | #define CAN_TX_PIN GPIO_Pin_1
19 | |
20 | #define CAN_RX_SOURCE GPIO_PinSource0
21 | #define CAN_TX_SOURCE GPIO_PinSource1
22 | |
23 | //Port definitions
24 | #define CAN_COM_PORT GPIOD
25 | |
26 | //Clock definitions
27 | #define CAN_GPIO_CLK RCC_AHB1Periph_GPIOD
28 | #define CAN_CLK RCC_APB1Periph_CAN1
29 | |
30 | void CAN_Config(void) |
31 | {
32 | GPIO_InitTypeDef GPIO_InitStructure; |
33 | |
34 | /* CAN GPIOs configuration **************************************************/
35 | |
36 | /* Enable GPIO clock */
37 | RCC_AHB1PeriphClockCmd(CAN_GPIO_CLK, ENABLE); |
38 | |
39 | /* Connect CAN pins to AF9 */
40 | GPIO_PinAFConfig(CAN_COM_PORT, CAN_RX_SOURCE, GPIO_AF_CAN1); |
41 | GPIO_PinAFConfig(CAN_COM_PORT, CAN_TX_SOURCE, GPIO_AF_CAN1); |
42 | |
43 | /* Configure CAN RX and TX pins */
44 | GPIO_InitStructure.GPIO_Pin = CAN_RX_PIN | CAN_TX_PIN; |
45 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; |
46 | GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; |
47 | GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; |
48 | GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; |
49 | GPIO_Init(CAN_COM_PORT, &GPIO_InitStructure); |
50 | |
51 | /* CAN configuration ********************************************************/
52 | /* Enable CAN clock */
53 | RCC_APB1PeriphClockCmd(CAN_CLK, ENABLE); |
54 | |
55 | //CAN1
56 | /* CAN register init */
57 | CAN_DeInit(CAN1); |
58 | |
59 | /* CAN cell init */
60 | CAN_DBGFreeze(CAN1, DISABLE); |
61 | CAN_InitStructure.CAN_TTCM = DISABLE; |
62 | CAN_InitStructure.CAN_ABOM = DISABLE; |
63 | CAN_InitStructure.CAN_AWUM = DISABLE; |
64 | CAN_InitStructure.CAN_NART = DISABLE; |
65 | CAN_InitStructure.CAN_RFLM = DISABLE; |
66 | CAN_InitStructure.CAN_TXFP = DISABLE; |
67 | CAN_InitStructure.CAN_Mode = CAN_Mode_LoopBack; |
68 | CAN_InitStructure.CAN_SJW = CAN_SJW_1tq; |
69 | |
70 | /* CAN Baudrate = 50 kBps (CAN clocked at 42MHz) */
71 | CAN_InitStructure.CAN_BS1 = CAN_BS1_14tq; |
72 | CAN_InitStructure.CAN_BS2 = CAN_BS2_6tq; |
73 | CAN_InitStructure.CAN_Prescaler = 40; |
74 | CAN_Init(CAN1, &CAN_InitStructure); |
75 | |
76 | /* CAN filter init */
77 | CAN_FilterInitStructure.CAN_FilterNumber = 0; |
78 | CAN_FilterInitStructure.CAN_FilterMode = CAN_FilterMode_IdMask; |
79 | CAN_FilterInitStructure.CAN_FilterScale = CAN_FilterScale_32bit; |
80 | CAN_FilterInitStructure.CAN_FilterIdHigh = 0x0000; |
81 | CAN_FilterInitStructure.CAN_FilterIdLow = 0x0000; |
82 | CAN_FilterInitStructure.CAN_FilterMaskIdHigh = 0x0000; |
83 | CAN_FilterInitStructure.CAN_FilterMaskIdLow = 0x0000; |
84 | CAN_FilterInitStructure.CAN_FilterFIFOAssignment = 0; |
85 | CAN_FilterInitStructure.CAN_FilterActivation = ENABLE; |
86 | CAN_FilterInit(&CAN_FilterInitStructure); |
87 | |
88 | /* Transmit Structure preparation */
89 | TxMessage.StdId = 0x321; |
90 | TxMessage.ExtId = 0x01; |
91 | TxMessage.RTR = CAN_RTR_DATA; |
92 | TxMessage.IDE = CAN_ID_STD; |
93 | TxMessage.DLC = 1; |
94 | |
95 | /* Enable FIFO 0 message pending Interrupt */
96 | CAN_ITConfig(CAN1, CAN_IT_FMP0, ENABLE); |
97 | }
98 | |
99 | void NVIC_Config(void) |
100 | {
101 | NVIC_InitTypeDef NVIC_InitStructure; |
102 | NVIC_InitStructure.NVIC_IRQChannel = CAN1_RX0_IRQn; |
103 | NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0; |
104 | NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0; |
105 | NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; |
106 | NVIC_Init(&NVIC_InitStructure); |
107 | }
108 | |
109 | void Init_RxMes(CanRxMsg *RxMessage) |
110 | {
111 | uint8_t i = 0; |
112 | |
113 | RxMessage->StdId = 0x00; |
114 | RxMessage->ExtId = 0x00; |
115 | RxMessage->IDE = CAN_ID_STD; |
116 | RxMessage->DLC = 0; |
117 | RxMessage->FMI = 0; |
118 | for (i = 0;i < 8;i++) |
119 | {
120 | RxMessage->Data[i] = 0x00; |
121 | }
122 | }
123 | |
124 | /**
125 | **===========================================================================
126 | **
127 | ** Abstract: main program
128 | **
129 | **===========================================================================
130 | */
131 | int main(void) |
132 | {
133 | |
134 | /* Initialize LEDs */
135 | STM_EVAL_LEDInit(LED3); |
136 | STM_EVAL_LEDInit(LED4); |
137 | STM_EVAL_LEDInit(LED5); |
138 | STM_EVAL_LEDInit(LED6); |
139 | |
140 | /* Turn on LEDs */
141 | STM_EVAL_LEDOn(LED3); |
142 | STM_EVAL_LEDOn(LED4); |
143 | STM_EVAL_LEDOn(LED5); |
144 | STM_EVAL_LEDOn(LED6); |
145 | |
146 | NVIC_Config(); |
147 | CAN_Config(); |
148 | uint8_t test1 = 1; |
149 | Init_RxMes(&RxMessage); |
150 | /* Infinite loop */
151 | while (1) |
152 | {
153 | TxMessage.Data[0] = test1; |
154 | CAN_Transmit(CAN1, &TxMessage); |
155 | }
156 | }
157 | |
158 | void CAN1_RX0_IRQHandler(void) |
159 | {
160 | |
161 | CAN_Receive(CAN1, CAN_FIFO0, &RxMessage); |
162 | STM_EVAL_LEDToggle(RxMessage.Data[0]); |
163 | |
164 | |
165 | }
Hi, du hast aber schon CAN_InitStructure.CAN_Mode = CAN_Mode_LoopBack; auf normal geschaltet. Und per Default empfängt ein Knoten nicht seinen eigenen Rahmen (d.h. er führt schon Bitmonitoring durch, allerdings wird er den Rahmen nicht in dem Empfangsbuffer ablegen). Daran ändert auch die Verbindung von RX/TX nichts. Viele Grüße, Narfie
Ja wenn ich auf Normal stelle und dann RX und TX mit nem kabel verbinde dann löst der Interrupt nicht aus und er empfängt auch nichts, im loopback Modus geht es aber warum funktioniert es nicht wenn ich RX und TX verbinde und auf Normal stelle?
