1 | /****************************************************************************
2 | * $Id:: main.c 5035 2010-09-24 23:48:55Z nxp12832 $
3 | * Project: NXP LPC11xx CAN example
4 | *
5 | * Description:
6 | * This file is part of the CAN and CANopen on-chip driver examples.
7 | *
8 | ****************************************************************************
9 | * Software that is described herein is for illustrative purposes only
10 | * which provides customers with programming information regarding the
11 | * products. This software is supplied "AS IS" without any warranties.
12 | * NXP Semiconductors assumes no responsibility or liability for the
13 | * use of the software, conveys no license or title under any patent,
14 | * copyright, or mask work right to the product. NXP Semiconductors
15 | * reserves the right to make changes in the software without
16 | * notification. NXP Semiconductors also make no representation or
17 | * warranty that such application will be suitable for the specified
18 | * use without further testing or modification.
19 | ****************************************************************************/
20 | #include "driver_config.h"
21 | #include "target_config.h"
22 |
23 | #include "rom_drivers.h"
24 | #include <cr_section_macros.h>
25 |
26 | #ifndef NULL
27 | #define NULL ((void *)0)
28 | #endif
29 |
30 | __BSS(RESERVED) char CAN_driver_memory[0xC0] ; // reserve 192 bytes for CAN driver
31 |
32 | ROM **rom = (ROM **)0x1fff1ff8;
33 |
34 | CAN_MSG_OBJ msg_obj;
35 |
36 | /* Initialize CAN Controller */
37 | uint32_t ClkInitTable[2] = {
38 | 0x00000000UL, // CANCLKDIV
39 | 0x00001C57UL // CAN_BTR
40 | };
41 |
42 | /* Callback function prototypes */
43 | void CAN_rx(uint8_t msg_obj_num);
44 | void CAN_tx(uint8_t msg_obj_num);
45 | void CAN_error(uint32_t error_info);
46 |
47 | /* CANopen Callback function prototypes */
48 | uint32_t CANOPEN_sdo_exp_read (uint16_t index, uint8_t subindex);
49 | uint32_t CANOPEN_sdo_exp_write(uint16_t index, uint8_t subindex, uint8_t *dat_ptr);
50 | uint8_t CANOPEN_sdo_req (uint8_t length, uint8_t *req_ptr, uint8_t *length_resp, uint8_t *resp_ptr);
51 |
52 | /* Publish CAN Callback Functions */
53 | CAN_CALLBACKS callbacks = {
54 | CAN_rx,
55 | CAN_tx,
56 | CAN_error,
57 | CANOPEN_sdo_exp_read,
58 | CANOPEN_sdo_exp_write,
59 | NULL,
60 | NULL,
61 | NULL
62 | };
63 |
64 | /* CANopen read-only (constant) Object Dictionary (OD) entries
65 | Used with Expidited SDO only. Lengths = 1/2/4 bytes */
66 | CAN_ODCONSTENTRY myConstOD [] = {
67 | /* index, subindex, length, value */
68 | { 0x1000, 0x00, 4, 0x54534554UL }, // "TEST"
69 | { 0x1018, 0x00, 1, 0x00000003UL },
70 | { 0x1018, 0x01, 4, 0x00000003UL },
71 | { 0x2000, 0x00, 1, (uint32_t)'M' },
72 | };
73 |
74 | /* Application variables used in variable OD */
75 | uint8_t error_register;
76 | uint32_t device_id;
77 | uint32_t fw_ver;
78 | uint16_t param;
79 |
80 | /* CANopen list of variable Object Dictionary (OD) entries
81 | Expedited SDO with length=1/2/4 bytes */
82 | CAN_ODENTRY myOD [] = {
83 | /* index, subindex, access_type | length, value_pointer */
84 | { 0x1001, 0x00, OD_EXP_RO | 1, (uint8_t *)&error_register },
85 | { 0x1018, 0x02, OD_EXP_RO | 4, (uint8_t *)&device_id },
86 | { 0x1018, 0x03, OD_EXP_RO | 4, (uint8_t *)&fw_ver },
87 | { 0x2001, 0x00, OD_EXP_RW | 2, (uint8_t *)¶m },
88 | };
89 |
90 | /* CANopen configuration structure */
91 | static const CAN_CANOPENCFG myCANopen = {
92 | 20, // node_id
93 | 5, // msgobj_rx
94 | 6, // msgobj_tx
95 | 1, // isr_handled
96 | sizeof(myConstOD)/sizeof(myConstOD[0]), // od_const_num
97 | (CAN_ODCONSTENTRY *)myConstOD, // od_const_table
98 | sizeof(myOD)/sizeof(myOD[0]), // od_num
99 | (CAN_ODENTRY *)myOD, // od_table
100 | };
101 |
102 | /* CAN receive callback */
103 | /* Function is executed by the Callback handler after
104 | a CAN message has been received */
105 | void CAN_rx(uint8_t msg_obj_num){
106 |
107 | /* Determine which CAN message has been received */
108 | msg_obj.msgobj = msg_obj_num;
109 |
110 | /* Now load up the msg_obj structure with the CAN message */
111 | (*rom)->pCAND->can_receive(&msg_obj);
112 |
113 | if (msg_obj_num == 1)
114 | {
115 | /* Simply transmit CAN frame (echo) with with ID +0x100 via buffer 2 */
116 | msg_obj.msgobj = 2;
117 | msg_obj.mode_id += 0x100;
118 | (*rom)->pCAND->can_transmit(&msg_obj);
119 | }
120 |
121 | return;
122 | }
123 |
124 | /* CAN transmit callback */
125 | /* Function is executed by the Callback handler after
126 | a CAN message has been transmitted */
127 | void CAN_tx(uint8_t msg_obj_num){
128 | return;
129 | }
130 |
131 | /* CAN error callback */
132 | /* Function is executed by the Callback handler after
133 | an error has occured on the CAN bus */
134 | void CAN_error(uint32_t error_info){
135 | return;
136 | }
137 |
138 | /* CAN interrupt handler */
139 | /* The CAN interrupt handler must be provided by the user application.
140 | It's function is to call the isr() API located in the ROM */
141 | void CAN_IRQHandler (void){
142 | (*rom)->pCAND->isr();
143 | }
144 |
145 | /* CANopen Callback for expedited read accesses */
146 | uint32_t CANOPEN_sdo_exp_read(uint16_t index, uint8_t subindex){
147 | if (index == 0x2001)
148 | param++;
149 |
150 | return 0; // Return 0 for successs, SDO Abort code for error
151 | }
152 |
153 | /* CANopen Callback for expedited write accesses */
154 | uint32_t CANOPEN_sdo_exp_write(uint16_t index, uint8_t subindex, uint8_t *dat_ptr){
155 | if ((index == 0x2001) && (*(uint16_t *)dat_ptr != 0))
156 | return SDO_ABORT_VALUE_RANGE;
157 | else
158 | return 0; // Return 0 for successs, SDO Abort code for error
159 | }
160 |
161 |
162 | int main(void) {
163 | /* Output the Clk onto the CLKOUT Pin PIO0_1 to monitor the freq on a scope */
164 | LPC_IOCON->PIO0_1 = (1<<0);
165 | /* Select the MAIN clock as the clock out selection since it's driving the core */
166 | LPC_SYSCON->CLKOUTCLKSEL = 3;
167 | /* Set CLKOUTDIV to 6 */
168 | LPC_SYSCON->CLKOUTDIV = 10; // CLKOUT Divider = 10
169 | /* Enable CLKOUT */
170 | LPC_SYSCON->CLKOUTUEN = 0;
171 | LPC_SYSCON->CLKOUTUEN = 1;
172 | while (!(LPC_SYSCON->CLKOUTUEN & 0x01));
173 |
174 | /* Initialize the CAN controller */
175 | (*rom)->pCAND->init_can(&ClkInitTable[0], 1);
176 |
177 | /* Configure the CAN callback functions */
178 | (*rom)->pCAND->config_calb(&callbacks);
179 |
180 | /* Initialize CANopen handler and variables */
181 | error_register = 0x00;
182 | device_id = 0xAA55AA55;
183 | fw_ver = 0x00010002;
184 | param = 33;
185 | (*rom)->pCAND->config_canopen((CAN_CANOPENCFG *)&myCANopen);
186 |
187 | /* Enable the CAN Interrupt */
188 | NVIC_EnableIRQ(CAN_IRQn);
189 |
190 | /* Send a simple one time CAN message */
191 | msg_obj.msgobj = 0;
192 | msg_obj.mode_id = 0x345;
193 | msg_obj.mask = 0x0;
194 | msg_obj.dlc = 4;
195 | msg_obj.data[0] = 'T'; //0x54
196 | msg_obj.data[1] = 'E'; //0x45
197 | msg_obj.data[2] = 'S'; //0x53
198 | msg_obj.data[3] = 'T'; //0x54
199 | (*rom)->pCAND->can_transmit(&msg_obj);
200 |
201 | /* Configure message object 1 to receive all 11-bit messages 0x400-0x4FF */
202 | msg_obj.msgobj = 1;
203 | msg_obj.mode_id = 0x400;
204 | msg_obj.mask = 0x700;
205 | (*rom)->pCAND->config_rxmsgobj(&msg_obj);
206 |
207 | while(1){
208 | __WFI(); /* Go to Sleep */
209 | }
210 | }
