Hier gibt es die neueste Beta Version von Diptrace vom 2.August 2012: http://www.diptrace.com/downloads/?M=D Version 2.2.9.0 (August 2, 2012) 1. Online DRC - dynamically checks design rules while you add objects, route traces or edit anything in layout. Static DRC check was improved and optimized. 2. 3D VRML 2.0 Export of PC board (see in 3D preview). 3. Custom Non-Signal layers. 4. Arranging PCB components by hierarchical blocks. Copying routing/placement between similar blocks. 5. Automatic showing/hiding ratlines for copper pours depending on pouring and traces ("Hide Ratlines" option was removed). 6. Pour priority for copper pour. 7. Separate "Place Ratline" mode, no more ratlines in "default" and "edit traces" modes. 8. Configuring and saving filenames for Gerber export by layers (name and extension for each layer). 9. Exporting dimensions into Gerber and DXF. 10. Checking pin/wire superimposing without connection in Schematic ERC. 11. Backward compatibility of binary file formats starting from this version (it can open files of further versions). 12. Library update: 8000+ new components, euro symbols, new patterns. ...many speed/size optimization improvements and bug fixes.
Jop, ich bin begeistert, der Online DRC funktioniert sehr gut. Ich kann das Programm einfach nur empfehlen. gruß Zippi
