Hallo!
Beim Versuch in Java eine FTP Verbindung mit dem Code
1 |
2 |
3 | import org.apache.commons.net.ftp.FTPClient;
4 | import org.apache.commons.net.ftp.FTPFile;
5 | import org.apache.commons.io.FileUtils;
6 | import java.io.IOException;
7 |
8 | public class UpdateNeues {
9 |
10 |
11 | public static void main(String[] args) {
12 | FTPClient client = new FTPClient();
13 | try{
14 | client.connect("server");
15 | if ( client.login("user", "pass")){
16 | System.out.append("Userdaten akzeptiert");
17 | client.listFiles();
18 | };
19 |
20 |
21 |
22 |
23 |
24 | client.disconnect();
25 |
26 | } catch (Exception ex){
27 | ex.printStackTrace();
28 | }
29 |
30 |
31 | }
32 | }
aufzubauen, erscheint folgende Fehlermeldung
1 | tjava.net.SocketException: Software caused connection abort: socket write error
2 | at java.net.SocketOutputStream.socketWrite0(Native Method)
3 | at java.net.SocketOutputStream.socketWrite(SocketOutputStream.java:109)
4 | at java.net.SocketOutputStream.write(SocketOutputStream.java:153)
5 | at sun.nio.cs.StreamEncoder.writeBytes(StreamEncoder.java:221)
6 | at sun.nio.cs.StreamEncoder.implFlushBuffer(StreamEncoder.java:291)
7 | at sun.nio.cs.StreamEncoder.implFlush(StreamEncoder.java:295)
8 | at sun.nio.cs.StreamEncoder.flush(StreamEncoder.java:141)
9 | at java.io.OutputStreamWriter.flush(OutputStreamWriter.java:229)
10 | at java.io.BufferedWriter.flush(BufferedWriter.java:254)
11 | at org.apache.commons.net.ftp.FTP.__send(FTP.java:501)
12 | at org.apache.commons.net.ftp.FTP.sendCommand(FTP.java:475)
13 | at org.apache.commons.net.ftp.FTP.sendCommand(FTP.java:552)
14 | at org.apache.commons.net.ftp.FTP.port(FTP.java:877)
15 | at org.apache.commons.net.ftp.FTPClient._openDataConnection_(FTPClient.java:709)
16 | at org.apache.commons.net.ftp.FTPClient._openDataConnection_(FTPClient.java:657)
17 | at org.apache.commons.net.ftp.FTPClient.initiateListParsing(FTPClient.java:3097)
18 | at org.apache.commons.net.ftp.FTPClient.initiateListParsing(FTPClient.java:3072)
19 | at org.apache.commons.net.ftp.FTPClient.listFiles(FTPClient.java:2731)
20 | at org.apache.commons.net.ftp.FTPClient.listFiles(FTPClient.java:2778)
21 | at updateneues.UpdateNeues.main(UpdateNeues.java:18)
woran könnte das liegen?
Danke,
Grüße
Chris
