Hallo, nach viel Lektüre habe ich nur noch diese Frage: kann Das überhaupt funktionieren???? void LCD_vString(char str[]) { byte max = 0; byte i; while (str[max] != '\0') //Loop until the end of the string has been reached { max++; //Get the length of the string } for (i = 0;i < max;i++) //Loop until the end of the string is reached { LCD_Send(str[i]); //Display each character in the string on the LCD } } /*********************************************************************** ******** * Function: LCD_String(auto const far rom char *str) * * * * Variables: * * *str -> Points to the constant string that is passed into the function * * * * Description: * * This function will display a constant string for the user on the LCD. * ************************************************************************ *******/ void LCD_String(auto const far rom char *str) { byte max = 0; byte i; while (str[max] != '\0') //Loop until the end of the string has been reached { max++; //Get the length of the string } for (i = 0;i < max;i++) //Loop until the end of the string is reached { LCD_Send(str[i]); //Display each character in the string on the LCD } }
