1 | /*******************Includes*************************************/
2 |
3 | #include <avr/io.h>
4 | #include <stdio.h>
5 | #include <stdbool.h>
6 |
7 |
8 |
9 | /******************Macros and Defines*********************/
10 |
11 | #define BAUD 19200
12 | #define MYUBRR F_CPU/16/BAUD-1
13 |
14 |
15 |
16 | /**************Function Prototypes*********************************/
17 |
18 | void usart_init(uint16_t ubrr);
19 | char usart_getchar( void );
20 | void usart_putchar( char data );
21 | void usart_pstr (char *s);
22 | unsigned char usart_kbhit(void);
23 |
24 |
25 |
26 | /*******************Main***********************/
27 |
28 | int main( void ) {
29 |
30 | // configure PORTA as output
31 |
32 | DDRA = 0xFF;
33 |
34 | // setup PORTB data direction as an input
35 |
36 | DDRB = 0;
37 |
38 | // make sure it is high impedance and will not source
39 |
40 | PORTB = 0;
41 |
42 | // fire up the usart
43 |
44 | usart_init ( MYUBRR );
45 |
46 | // dump some strings to the screen at power on
47 |
48 | usart_pstr("Ready to rock and roll!\n\r");
49 | usart_pstr("Type in a character, and I will transpose it up by 1:\n\r");
50 |
51 | // main loop
52 |
53 | while(true) {
54 |
55 | // if a key has been pressed, then process it
56 |
57 | if(usart_kbhit()) {
58 | usart_putchar(usart_getchar() + 1);
59 | }
60 |
61 |
62 | // map the PINB inputs to the PORTA outputs
63 |
64 | PORTA = PINB;
65 |
66 |
67 |
68 | // a little humor is always good, PB0 gets the user yelled at
69 |
70 | if(bit_is_clear(PINB,PB0)) {
71 |
72 | usart_pstr("OUCH! Stop poking me!\n\r");
73 | }
74 | }
75 | }
76 | /*****************usart Related****************/
77 |
78 | void usart_init( uint16_t ubrr) {
79 |
80 | // Set baud rate
81 |
82 | UBRRH = (uint8_t)(ubrr>>8);
83 | UBRRL = (uint8_t)ubrr;
84 |
85 | // Enable receiver and transmitter
86 |
87 | UCSRB = (1<<RXEN)|(1<<TXEN);
88 |
89 | // Set frame format: 8data, 1stop bit
90 |
91 | UCSRC = (1<<URSEL)|(3<<UCSZ0);
92 | }
93 |
94 | void usart_putchar(char data) {
95 |
96 | // Wait for empty transmit buffer
97 |
98 | while ( !(UCSRA & (_BV(UDRE))) );
99 |
100 | // Start transmission
101 |
102 | UDR = data;
103 | }
104 | char usart_getchar(void) {
105 |
106 | // Wait for incoming data
107 |
108 | while ( !(UCSRA & (_BV(RXC))) );
109 |
110 | // Return the data
111 |
112 | return UDR;
113 | }
114 |
115 | unsigned char usart_kbhit(void) {
116 |
117 | //return nonzero if char waiting polled version
118 |
119 | unsigned char b;
120 | b=0;
121 | if(UCSRA & (1<<RXC)) b=1;
122 | return b;
123 | }
124 |
125 | void usart_pstr(char *s) {
126 |
127 | // loop through entire string
128 |
129 | while (*s) {
130 | usart_putchar(*s);
131 | s++;
132 | }
133 | }
