1 | make program
2 | avrdude -p atmega168p -P usb -c usbasp -B 2 -v -v -y -U flash:w:main_rx.hex -U eeprom:w:main_rx.eep
3 |
4 | avrdude: Version 5.11.1, compiled on Feb 16 2012 at 22:11:20
5 | Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
6 | Copyright (c) 2007-2009 Joerg Wunsch
7 |
8 | System wide configuration file is "/usr/local/CrossPack-AVR-20120217/etc/avrdude.conf"
9 | User configuration file is "/Users/c0d3z3r0/.avrduderc"
10 | User configuration file does not exist or is not a regular file, skipping
11 |
12 | Using Port : usb
13 | Using Programmer : usbasp
14 | Setting bit clk period : 2.0
15 | avrdude: seen device from vendor ->www.fischl.de<-
16 | avrdude: seen product ->USBasp<-
17 | AVR Part : ATMEGA168P
18 | Chip Erase delay : 9000 us
19 | PAGEL : PD7
20 | BS2 : PC2
21 | RESET disposition : dedicated
22 | RETRY pulse : SCK
23 | serial program mode : yes
24 | parallel program mode : yes
25 | Timeout : 200
26 | StabDelay : 100
27 | CmdexeDelay : 25
28 | SyncLoops : 32
29 | ByteDelay : 0
30 | PollIndex : 3
31 | PollValue : 0x53
32 | Memory Detail :
33 |
34 | Block Poll Page Polled
35 | Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
36 | ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- ---------
37 | eeprom 65 20 4 0 no 512 4 0 3600 3600 0xff 0xff
38 | flash 65 6 128 0 yes 16384 128 128 4500 4500 0xff 0xff
39 | lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
40 | hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
41 | efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
42 | lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
43 | calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
44 | signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
45 |
46 | Programmer Type : usbasp
47 | Description : USBasp, http://www.fischl.de/usbasp/
48 |
49 | avrdude: try to set SCK period to 2e-06 s (= 500000 Hz)
50 | avrdude: set SCK frequency to 375000 Hz
51 | avrdude: error: usbasp_transmit: Broken pipe
52 | avrdude: error: usbasp_transmit: Result too large
53 | avrdude: error: programm enable: target doesn't answer. 0
54 | avrdude: initialization failed, rc=-1
55 | Double check connections and try again, or use -F to override
56 | this check.
57 |
58 | avrdude: error: usbasp_transmit: Broken pipe
59 |
60 | avrdude done. Thank you.
61 |
62 | make: *** [program] Error 1
