STM32 SPI Init
Gast #2843690
ich versuche grade die SPI Schnittstelle von dem STM32F407 zum laufen zu
bringen. Eig. möchte ich dann eine SD Karte ansteuern. Nur leider kommt
noch nicht mal ein Takt Signal heraus. Vielleicht könnt ihr euch mal den
Code ansehen.
#include "stm32f4xx.h"
void SDCard_InitLowLevel(void);
void SDCard_Init(void);
uint16_t response;
int main(void)
  SystemInit(); // 8MHz extern -> PLL -> 168MHz
  response = 0x00;
  SDCard_InitLowLevel();
    while(!response)
      SDCard_Init();
    response = response; // Breakpoint
    //while(1);
24
25
    return 1;
26
27
28
29
30
  GPIO_InitTypeDef GPIO_InitStruct;
31
  SPI_InitTypeDef SPI_InitStruct;
32
33
34
   * Clocks
35
36
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE);
37
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
38
39
40
  * DeInit
41
42
  SPI_I2S_DeInit(SPI1);
43
44
45
   * Alternate Function
46
47
  GPIO_PinAFConfig(GPIOA, GPIO_Pin_5, GPIO_AF_SPI1);
48
  GPIO_PinAFConfig(GPIOA, GPIO_Pin_6, GPIO_AF_SPI1);
49
  GPIO_PinAFConfig(GPIOA, GPIO_Pin_7, GPIO_AF_SPI1);
50
51
52
   * GPIO Init
53
   * PA5 (SCK) to SD card pin 5 (SCLK)   PP NOPULL
54
   * PA6 (MISO) to SD card pin 7 (DO)  PP UP
55
   * PA7 (MOSI) to SD card pin 2 (DI)  PP UP
56
   * PA8 (NSS) to SD card pin 1 (CS)  PP UP
57
58
  GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF;
59
  GPIO_InitStruct.GPIO_OType = GPIO_OType_PP;
60
  GPIO_InitStruct.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7 | GPIO_Pin_8;
61
  GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_UP;
62
  GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;
63
  GPIO_Init(GPIOA, &GPIO_InitStruct);
64
65
  GPIO_InitStruct.GPIO_Pin = GPIO_Pin_5;
66
  GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_NOPULL;
67
68
69
  GPIO_WriteBit(GPIOA, GPIO_Pin_8, Bit_SET);
70
71
72
   * SPI1 Init
73
74
  SPI_InitStruct.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256;
75
  SPI_InitStruct.SPI_CPHA = SPI_CPHA_1Edge;
76
  SPI_InitStruct.SPI_CPOL = SPI_CPOL_High;
77
  SPI_InitStruct.SPI_CRCPolynomial = 0;
78
  SPI_InitStruct.SPI_DataSize = SPI_DataSize_8b;
79
  SPI_InitStruct.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
80
  SPI_InitStruct.SPI_FirstBit = SPI_FirstBit_MSB;
81
  SPI_InitStruct.SPI_Mode = SPI_Mode_Master;
82
  SPI_InitStruct.SPI_NSS = SPI_NSS_Soft;
83
  SPI_Init(SPI1, &SPI_InitStruct);
84
85
  SPI_Cmd(SPI1, ENABLE);
86
87
88
89
90
  uint16_t CMD0[] = {0x40, 0x00, 0x00, 0x00, 0x00, 0x95};
91
92
  for(uint16_t i = 0; i < 100; i++); // min. 74 Takte an SCK warten
93
94
  while(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_BSY) == SET);
95
96
  GPIO_WriteBit(GPIOA, GPIO_Pin_8, Bit_RESET);
97
  for(uint8_t i = 0; i < 6; i++)
98
99
    SPI_I2S_SendData(SPI1, CMD0[i]);
100
101
102
103
  while(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET);
104
105
  response = SPI_I2S_ReceiveData(SPI1);
106
Moritz
Gast #2844065
Das wird sicher keine 74 SCK warten. Es kommt kein SCK
ohne das man Bytes schreibt. Die Schleife optimiert dir
sowieso der Compiler weg weil sie nichts tut.
Schau dir mal an was die Routine macht. Die prügelt Daten
ins Dataregister, mehr nicht. Du schreibst also sechs mal
schnell hintereinander Daten ohne zu warten ob die schon
gesendet wurden.
Gast #2844092
vielen Dank für die Antwort. Selbst wenn ich immer nur ein Byte senden
will und warte bis SPI_I2S_FLAG_BSY gelöscht ist, kommt kein Takt raus.
>  Ich glaube du musst noch die AFIO-Geschichte mit einem Takt versorgen
Bei den F4ern gibt es das nicht.
Moritz
#2844217
Auf den ersten Blick sieht für mich fast alles OK aus.
Ich würde aber den CS-Pin nicht als AF-Pin initialisieren, sondern als
OUT (bei NSS-Soft).
Wenn es wirklich nicht funktionieren will, kannst du ja mal alles exakt
so wie in den Beispielen von ST machen, d.h. z.B. Pull-Down und nicht
Up.
Oder du versuchst gleich das Beispiel von ST zum laufen zu bringen.
Gast #2844286
Hallo nochmal.
Könnte es sein, das der SCK Prescaler vielleicht falsch eingestellt ist.
(SCK = APB2 / Prescaler)? Ich hab HCLK = 168MHz APB1 = 42MHz APB2 =
84MHz
Also müsste doch SCK eig. 84MHz / 256 = 328,8125kHz sein oder?
Moritz
Gast #2844303
Woher weisst du das da kein Takt rauskommt?
Hoffentlich hast du da ein Osci dran. Aus SCK kommt kein
Takt wenn du nicht sendest. Also senden, senden, senden, senden...
Nicht nur ein popeliges Byte.
Gast #2844327
ja ich hab nen Oszi dran. Und ich sende immer 100x 0b10101010 direkt
hintereinander.
Ich hab das ganze mal auf SPI2 umgeändert. Das Problem ist jetzt, dass
wenn ich den MISO Pin(PB14) auf SPI2 mittels GPIO_PinAFConfig() remappen
möchte, in der Funktion GPIO_PinAFConfig() an der Stelle:
GPIOx->AFR[GPIO_PinSource >> 0x03] &= ~((uint32_t)0xF << ((uint32_t)((uint32_t)GPIO_PinSource & (uint32_t)0x07) * 4)) ;
der Defaul-Handler angesprungen wird.
Moritz
Gast #2846400
Hier nochmal mein Code mit SPI2:
int main(void)
  SystemInit();
    while(1)
      SDCard_Init();
    return 1;
23
24
25
26
   * Clocks
27
28
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE);
29
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA | RCC_AHB1Periph_GPIOB, ENABLE);
30
31
32
  * DeInit
33
34
  SPI_I2S_DeInit(SPI2);
35
36
37
38
39
  GPIO_PinAFConfig(GPIOB, GPIO_Pin_10, GPIO_AF_SPI2);
40
  //GPIO_PinAFConfig(GPIOB, GPIO_Pin_14, GPIO_AF_SPI2);
41
  GPIO_PinAFConfig(GPIOB, GPIO_Pin_15, GPIO_AF_SPI2);
42
43
44
   * GPIO Init
45
   * PB10 (SCK) to SD card pin 5 (SCLK)   PP UP AF
46
   * PB14 (MISO) to SD card pin 7 (DO)  PP UP AF
47
   * PB15 (MOSI) to SD card pin 2 (DI)  PP UP AF
48
   * PA8 (NSS) to SD card pin 1 (CS)    PP UP OUT
49
50
51
52
  GPIO_InitStruct.GPIO_Pin = GPIO_Pin_10 | /*GPIO_Pin_14 |*/ GPIO_Pin_15;
53
  GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_DOWN;
54
55
  GPIO_Init(GPIOB, &GPIO_InitStruct);
56
57
  GPIO_InitStruct.GPIO_Pin = GPIO_Pin_8;
58
59
  GPIO_InitStruct.GPIO_Mode = GPIO_Mode_OUT;
60
61
62
63
64
65
   * SPI2 Init
66
67
  SPI_InitStruct.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_128;
68
69
70
  SPI_InitStruct.SPI_CRCPolynomial = 7;
71
72
  SPI_InitStruct.SPI_Direction = SPI_Direction_1Line_Tx;
73
74
75
76
  SPI_Init(SPI2, &SPI_InitStruct);
77
78
  SPI_Cmd(SPI2, ENABLE);
79
80
81
82
83
  while(SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_BSY) == SET);
84
85
86
87
  for(int i = 0; i < 1000; i++)
88
89
    SPI_I2S_SendData(SPI2, 0b10101010);
90
91
92
93
94
95
Moritz
Gast #2846420
Hör auf im dunkeln rumzustochern.
In der StandardPeripheralLib zum STM32F4 ist ein Beispiel
für ein SPI Flash. Da ist alles drin was du brauchst.
Vergiss das hier:
RXNE ist das was du abfragen musst. SPI_I2S_FLAG_BSY kommt in dem
Code überhaupt nicht vor. Im Datenblatt steht warum.
#2846680
Ich habe es mal kurz mit meinem Code verglichen und auf die Schnelle
folgende Unterschiede gefunden:
- GPIO_Speed_100MHz und GPIO_PuPd_UP
- SPI_BaudRatePrescaler_256
- beim Senden teste ich auf:
    while (SET != SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_TXE));
- ganz am Anfang der Initialisierung:
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE);
    RCC_APB1PeriphResetCmd(RCC_APB1Periph_SPI2, ENABLE);
    RCC_APB1PeriphResetCmd(RCC_APB1Periph_SPI2, DISABLE);
    GPIO_PinAFConfig(GPIOB, GPIO_PinSource13, GPIO_AF_SPI2); //sck
    GPIO_PinAFConfig(GPIOB, GPIO_PinSource15, GPIO_AF_SPI2); //mosi
